Question about Brother Office Equipment & Supplies
I need to remove the drum to clean it. - Brother Office Equipment & Supplies
  • 488 Answers
  1. 1 I need to remove the - clean-printer-drum-1.1-120x120.jpg Open the printer and remove the toner cartridge.
  2. 2 Inspect the drum for obvious damage. If it's damaged, don't try to clean it; replace it.
  3. 3 clean-printer-drum-1.3-120x120.jpg Remove any large spots of toner on the drum with tweezers or pliers. Be careful not to scratch the surface.
  4. 4 clean-printer-drum-1.4-120x120.jpg Dip a cotton swab in a rubbing alcohol. Gently swipe any visible soil.
  5. 5 Put a couple of drops of alcohol on a soft, lint-free cloth if the entire drum looks dirty. Carefully wipe the drum.
  6. 6 Check the other parts for dirt while you have the cartridge out. Carefully clean them.
  7. 7 Reinstall the cartridge and print a couple of test pages. If the problem persists, you probably need a new drum.
Posted on Jan 03, 2011
How or what needs to be cleaned, to remove an equal distant mark on center of the page every 76mm (3 inches).
Remove the drum unit and toner from the printer. Separate the toner from the drum. Look at the surface of the drum, rotating using the drive sprocket at one end. Look for a mark or foreign material on the surface of the drum in the same position as it is on the printed page. If you find anything, use a clean, dry kleenex tissue folded into a pad to carefully remove the mark and clean the drum. The 3 inches corresponds to the distance around the drum as it rolls down the page. If the mark cannot be removed, the drum should be replaced, it is a consumable that wears out in any case.
Oct 04, 2016 | Brother HL 2140 Laser Printer
There is a Black line on the Ricoh Aficio 3045 Drum Help for Remove ????
if you can clean the black line with a cloth, than you need just to replace the cleaning blade, but if the black line is not removing without a cloth, then you need to replace the opc drum and the cleaning blade or both blades, some machines of this type have only one cleaning blade but some have two cleaning blade.
Sep 28, 2016 | Ricoh Aficio Office Equipment & Supplies
Model ar5516. Why is drum not cleaning?
Sir,
Did you prime the cleaning blade with toner when you installed it?, and did you ensure the new cleaning blade did not flip!!!!, re-check the new installed cleaning blade, place a small amount of toner from the toner bottle on the drum along the whole drum. and using your hands at both end of the drum DO NOT TOUCH THE DRUM" turn just a 1/4" CCW (To ensure the cleaning blade is set) then CW to see if the toner is removed. your drum might need to be replaced and or the fuser unit have a example of the copy?
Dec 28, 2015 | Sharp Office Equipment & Supplies
How to remove a samsung 8kg top loader drum to pressure clean and remove black rubber like build up
No need to remove the drum. You can buy cleaning agents for the washing machine at the local supermarket. You have to actually run the machine in cleaner solution and you have to do this every 3 months at least.
Jan 16, 2014 | Samsung SW62ASP Top Load Washer
Change drum kit
Remove the old drum unit,remove the drum and the drum cleaning blade,clean the charge corona wire and grid,install the new drum and drum cleaning blade,clean the image transfer /separator corona wire,clean the optical parts(mirrors ,lens,glass)clean the AIDC sensoe located under OPC drum,reinstall the drum unit in the copier,enter in the technical Rep mode,place 5 sheets A3 paper on the original glass and perform F5 AIDC sensor(Auto image density control).
Mar 19, 2013 | Minolta EP4000/5000 CS/PRO Copier
My dryer is squeaking loudly when I first put clothes in it, quiets down after 10 minutes or so. What do I need to do to fix it? Do I need a new belt of some kind. Can't find manual:(
The dryer needs to be dis-assembled and the drum removed.
Then remove and clean the drum support roller wheels and shafts.
Inspect the front drum glides for wear.
Also remove and clean the tension roller shaft wear the belt rides at the motor.
Inspect the drum felt seal for tear and wear.
Feb 20, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
White streaks on printed pages. how to clean LSU on SCX 4725FN
LSU is next to drum area. Remove the drum/toner/developer cartridges/assemblies as required. You will see the Laser Shield glass and opening near where the photoconductor drum sets. may need a flashlight. Some models have a removable shield glass that slides out for cleaning. Check your manual. The charger roller and wire if installed id also a source for this problem. If cleaning does not resolve, replace drum/photoconductor.
Thanks
Jan 06, 2011 | Samsung Office Equipment & Supplies
How to replace copier drum Cleaning Blade UCLEZ0069FCZZ
Improper installation may damage the copier. Before disassembly, be sure to disconnect the power cord for safety. 1) Remove the drum cover. (4 Lock Tabs.)
2) Remove the drum fixing plate and the photo conductor drum.
•Dispose the drum fixing plate which was removed.
3) Check the cleaning blade and the red felt for damage.
•If there is damage, go to step 5
•If there is no damage, go to step 12
4) Remove the main charger. (Cleaning the screen grid and the sawteeth.)
5) Remove the cleaning blade.
•Dispose the cleaning blade which was removed.
6) Clean the cleaning section and the waste toner pipe to remove waste toner completely with a vacuum cleaner.
7) Remove the felt and duplex tape completely.
•Be careful not to scratch or bend the sub blade.
8) Attach the cleaning blade.
•Securely insert the plate section of the cleaning blade into the unit and fix it with a screw.
•Do not touch the cleaning blade rubber with your hand.
•When attaching the cleaning blade, press the cleaning blade in the arrow direction and attach.
9) Attach the felt.
•Attach the mocket with slightly pressing section A of the cleaning blade.
•Do not touch the tip of the cleaning blade.
•Do not put the mocket under the cleaning blade.
•Do not put the mocket on the sub blade.
•Do not press the sub blade with the mocket.
10) Attach the main charger.
•Securely set the MC holder on the projection of the process frame.
•Securely insert two projections of the MC holder into the groove in the process frame.
•When attaching the MC holder assembly, be careful not to make contact with the cleaning blade.
11) attach the drum fixing plate and the photoconductor drum. Apply grease to the inside of the photoconductor drum. (Diagram 2)
•Attach the drum from (b). (Prevention against the sub blade edge breakage)
•Attach the drum so that its position with the sub blade shown
12) Attach the detection gear.
•The detection gear is not installed to the drum cartridge package with the main body. Add a new one.
13) Attach the drum cover.
•After attaching the drum cover, do no make a copy
•When attaching the drum cover, engage the detection gear 20T rib with the 30T gear rib, and attach the drum to the process frame.)
14) Important.
•Insure proper drum rotation by rotating the drum counter-clockwise (as viewed from the front)
•If the drum does not rotate with reasonable effort the drum blade may need to be re-positioned or lubricated with a small amount of toner.
Dec 16, 2010 | Sharp Office Equipment & Supplies
Unable to remove drum for cleaning
Remove the toner cartridge from the drum casing using the release lever. The drum is not to be removed from the drum casing. Just rotate the drum using the side button until you see the dirt mentioned. Use cotton swab to wipe dirt off. Be careful not to damage it. If that doesn't work, you need a need drum which is closely the same price as getting a toner cartridge. Refer to your Brother MFC 8840D manual that came with the machine. Alternatively, you can refer to the online manual.
Jan 07, 2009 | Brother MFC 8840D All-In-One Laser Printer
Need to replace the drum cleaning brush how do I get it out????
The drum cleaning blade removal is pretty straight forward.
1. Remove the charge unit above the drum.
2. Remove the cover that sits above the cleaning blade.
3. Release the pressure spring at front of drum unit.
4. Remove 1 screw (front side of blade at top) holding blade in place.
I noticed that you had also had a E3-40 code previously. If toner is dropping on to your copies, the toner support blade will also have to be replaced.
Jan 31, 2008 | Panasonic FP-7735 Black and White Copier
66 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
