Question about Bugatti Diva Espresso Machine
We've got a Bugatti espresso machine type: MACC.CAFFE'. Serial number N 001000605. It suddenly quit pumping water. Still makes the noise but not water is pushed through the system. I can't find a home page for Bugatti coffee makers. Can anyone help?
Starbucks Barista (Saeco) Espresso machine Quit pumping
Hi
If it makes a noise when you turn the brew switch on you may have a blockage in the out let line. If it doesn't make a noise but every so often you may have a bad pump.
Mar 06, 2010 | Saeco Starbucks Sirena Espresso Machine
No water comes out
you have "Hard water residue". built up in the pump, try using 80/20 Vinigar, to water and keep letting it set/then run it through, even if it takes a while, just don't let it get "burned up, this should fix your problem, also you could try CLR in the Green Bottle, JUST MAKE SURE YOU READ THE DIRECTIONS AS TO COFFEE MAKERS, and hard water deposits,god bless
Jul 03, 2009 | DeLonghi Caffe Nabucco BCO70...
I have an old ariete centro caffe espresso machine with a coffee grinder. I filled up the resevoir with water and it seems that the pump is not pumping the water through the machine. My question is does it...
Hi Hi rolo 124,
does the pump make noise? If so, you can try to fill up the hose with water, sometimes it works. If the noise ist first loud then less loud may be that the water cant flow, because the whole maschine is calcified, try to decalcify, best and secure way with tartaric acid. If there is no noise, the pump may be damaged, or there is a fuse blown (mechanical or electric) at the pump.
Good luck
Jens
Dec 05, 2008 | Coffee Makers & Espresso Machines
Unable to get water to pump in order to prime
Try to take a bellow pump or similary and force in water in the water inlet, make sure you have the steam knob open when you do this.
Aug 09, 2008 | Saeco Caffe Charisma Espresso Machine
Saeco charisma will not prime. pump runs when turing steam/water knob but no water delivered out of steam tube
Aug 06, 2008 | Saeco Caffe Charisma Espresso Machine
Machine will not prime????
I think you have to replace the flow meter (water turbin), it´s like a water counter.
Jul 19, 2008 | Saeco Caffe Charisma Espresso Machine
No instruction on how to prime a saeco caffe charisma machine. looked in the book that came with it but there is no instructions for this process
Prime = letting some water out from the water/steam nozzle. Priming means that the machine has not water in the lines. By letting water come out, you are making sure that water fills all the components and is ready to use.
Apr 28, 2008 | Saeco Caffe Charisma Espresso Machine
Bugatti Diva Espresso Machine Logo
272 people viewed this question
Top Bugatti Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Bugatti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
