Question about Canon SELPHY CP740 InkJet Photo Printer
Printer says "error on paper tray". The paper is
  • 84 Answers
Are you getting a specific error message or error code?
Posted on Jan 03, 2011
Cannon mp530 says load paper when paper is loaded
Paper not loaded error is displayed by the printer when the printer doesn't detect any paper. Here try this one.
  • Make sure that your paper is properly inserted.
  • If properly inserted and still the printer doesn't detect it. Try putting more amount of paper in the tray.
  • Be sure that there are no damaged paper in the tray.
  • Clean the rollers using a cotton buds and a clean water.
  • Now try printing again.
Hope my solution will help. Thanks for using fixya.
Jul 08, 2011 | Canon Office Equipment & Supplies
"Paper Size Error: The paper size selected in the
Problem may be the paper tray. You don't say what kind of printer you have and my psychic abilities are nil.
The paper tray has sensors that tell the printer what size paper is in the tray. Make sure that the tray guides are set correctly.
By the way all paper trays are "in" trays.
Print out a config sheet to see what size paper the printer is set up for for each tray.
Jan 11, 2011 | HP Office Equipment & Supplies
Paper is inserted properly but error message keeps saying "Load paper face down in Main tray"
i think the printer has 2 trays, one down and the other one on top from where you insert the paper. load the paper there as well. if there is only one tray then check the paper sensor in the bottom, if the paper end sensor comes out of position then it will not detect the paper.
Jan 06, 2011 | HP Photosmart C6280 Printer
Will not feed from lower tray. upper feeder works fine
If you have a error code on display please respond. I can give you more detailed information.
If not, make sure that the print job that you are sending to the printer is for the same size paper that is present in the paper tray. Also, check that the tray is adjusted properly to the size for the paper that is present.
You could try running an internal print job to bypass the settings.
Dec 28, 2010 | HP LaserJet P4014n Printer
I am getting a "fax output error - cassette." It
Pretty sure your paper tray button is set to get paper from the bottom paper cassette which is the tray that slides into the bottom of the printer.
If you switch the paper tray selection button* to use the rear feed tray you'll probably find it will print faxes successfully or you can put paper in the cassette tray...
*The paper tray selection button is just under (and slightly right of) the "Memory Card" button and has an icon image of the printer with two LED's (top and bottom). These lights indicate which of the trays is currently selected...
Hope that helps.
Dec 10, 2010 | Canon PIXMA MP830 All-In-One InkJet...
My printer keep saying "
The unexpected paper size may cause the above error. Whenever your printer detects an abnormal size, this error appears on the device. It mainly happens when more than one sheet are attached with each other or when the paper trays are not set properly. To handle this issue, reload the trays with appropriate paper size followed by front and back tabs. For all the trays verify that correct paper size adjustments have been done. Now enable the jam recovery button and press the button 'GO' to print your document.
Nov 09, 2010 | Office Equipment & Supplies
Fix for 13.12 error
Hi
You are getting Error 13.12 due to paper jam at Paper feed 1. It can also happen when the Paper doesn't reach PS2(paper sensor 2).
Please check the picture for more details---
Try printing from Tray 2 or Tray 3, if it fails printing from tray 2 or 3 then Paper sensor 2 (PS2) is bad. To check the movement of flag insert the paper manually in the sensor path.
Remove any paper present in printer and then perform a paper path test using a duplexer. If issue is still not resolved then please remove the duplexer unit and re seat it. After re seating the duplexer your issue will be resolved.
Daniel Scott
Jun 28, 2010 | HP LaserJet 8100dn Printer
Hp laserjet 8150. i have a problem, tray 3 empty, always but have paper in tray 3
CAUSE: This error message indicates the paper present sensor flag in one of the trays does not detect paper in the tray. This could be caused by one of the following:
  • A broken sensor flag
  • The tray paper guides being set too close and restricting the paper from being pulled
  • The tray is not lifting
SOLUTION: Follow the steps below to determine the cause of a false TRAY X EMPTY message. Tray 2 empty
  1. Verify there is paper in the tray.
  2. Open the duplex unit access door just above Tray 2 on the front of the printer.
  3. Check the black-paper present flag by looking in through the duplex access door.
  4. Open and close Tray 2 and observe the tray lifting looking through the duplex unit access door.
The tray lifts but the error is still present
  1. Inspect the paper present flag on the PIU located just behind the pickup rollers. Ensure the flags are present and not damaged.
  2. Remove the tray guides from the tray and reseat them. Ensure the guides are seated correctly and are in the correct slot for the size paper in the tray. Add paper to the tray and try printing again.
  3. Try another known good tray, if available.
The tray does not lift and the error is still present
  1. Remove the tray, remove the paper in the tray, and inspect the lifting plate in the tray for damage. Ensure it will lift freely by hand.
  2. Try another known good tray if available.
Tray 3 empty
  2. Remove Tray 2.
  3. Open and close Tray 3 and verify it lifts by observing through the Tray 2 cavity.
  3. Try another known good tray if available.
Tray 4 empty
  2. Open Tray 4 and check for an extra **** of paper stored on the left side of the tray. This can cause the tray to stall while lifting and result in a tray empty message.
  3. Defeat the interlock in the vertical transfer unit (VTU). Open and close Tray 4 and watch the tray lift through the VTU door on the lower-right side of the printer.
    NOTE: Follow troubleshooting steps for Trays 2 and 3 when working with the 2 X 500 sheet-input tray.
  1. Check the tray guides to ensure the guides are seated corrected and are in the correct slots for the paper size in the tray.
  2. Inspect the paper present sensor for damage.
  3. Check for any broken plastic pieces in the tray that may be a broken sensor flag.
The tray does not lift and the error is still present Defeat the VTU interlock on the right side of Tray 4. Open and close Tray 4 and observe the tray lifting.
Nov 25, 2009 | HP LaserJet 8150n Printer
MY LASER PRINTER RED LIGHT CAME ON AND IT SAIDS SMPS FAN ERROR
If the light is solid red:
1. Printer paper is jammed inside your printer.
2. A cover is not being closed properly.
3. Toner cartridge is not inserted properly & need to be reinstalled
4. Toner cartridge is running low
5. No paper in tray
6. Paper inside paper tray is not installed correctly
May 05, 2009 | Samsung CLP-600N Laser Printer
Canon SELPHY CP740 InkJet Photo Printer Logo
258 people viewed this question
old marine
old marine
