Question about SYMA Toys industrial Syma S032 Ready to Fly Gyro
How to replace rear rotar - SYMA Toys industrial Syma S032 Ready to Fly Gyro
  • Jessica Mar 08, 2012
    I just posted a question like this. lol Is this the only way to fix the tail rotar? To glue it back on? I have heard that the tail rotar is sapose to actually pop on or screw on or something?
    Scholar:
  • 56 Answers
Just the rear rotor itself? Or the motor as well?
Tail rotor pops right off, and replacement will pop onto the shaft easily. A small, very carefully applied, drop of super glue will keep tail rotor on firm. If doing that, I recommend you turn the helicopter upside down and then pay close attention that you don't get any glue near where the shaft meets the motor, and don't turn it over again until glue is totally dry.
If the motor needs to be replaced, you'll need soldering equipment, it's a really simple wiring job, but the wires are barely thicker than a hair and not very easy to access. Not recommended unless you're very confident with a soldering gun.
Hope this helps,
r
Posted on Sep 12, 2011
    I just posted a question like this. Is this the only way to fix the tail rotar blade? (only can glue it back on?) I heard that its sapose to pop back on or screw on.. yes or no?
Stop a rear caliper from popping open and leaking
have you replaced the disk? if they have run out,"warpped" tehy will cause problems. spin rotar an see it there is alot of run out.
Feb 01, 2015 | Dodge 1997 Ram 1500
2002 pontiab bonneville i replaced rear rotar and when i drive it smells like something is buring and the wheel gets hot
Sounds like your pads are stuck, this could be a seized piston in the caliper. Check to see if the pads are touching the rotor without touching the brakes.
Dec 18, 2012 | Pontiac Bonneville Cars & Trucks
I replaced the rear breaks rotars and shocks on my 2007 chev tahoe and now the abs light and service traction control and servive stabilitrak light came on. Jow can I reset?
Sounds like you may have disconnected or damaged one or both of the rear wheel speed sensors. Inspect the wiring going to the rear hub assembly, just a two wire harness.
Jun 12, 2011 | 2007 Chevrolet Tahoe
Trying to change the rotars on my 1991 mitsubishi mirage and there is a plate in between the wheel and the rotar that i cant figure out how to get off
you will need a puller to remove the hub from the spidle, and the rotor bolts on from the rear. or remove the spindle assembly and have a machine shop do it for your, a better idea since the wheel bearing will have to be inspected as well
Nov 06, 2010 | 1991 Mitsubishi Mirage
Removing front rotar
rotar doesn't contain the studs, the plate/hub behind the rotar does - you need a 32mm socket to undo the axle nut to then get at the hub (need a flat screw driver to lever the nut tang up first). If it's seized on put the rotar and wheel back on (leave the axle nut off) and gently rock it in a top-bottom motion (not radially or axially) to free it up. you can then gain access to the hub and studs. put the wheel nuts back on the studs 2 -3 turns so that you have a 'seat' and using a bolt with a smaller dia to punch them out
May 08, 2010 | 1991 Subaru Legacy
Removeing the rear rotars
well if you have ever thing out of the way do not no where you live but if they are very rusted spray wd40 or something like that if this dose not work propane torch heat the rotor at the hub get red and hot as it cools try to get it off if you are replacing them hit it with slog hammer but if the e brake shoe are in side rotor you need to claps them first should be hole for adjuster in front of rotor or be hind baking plate hope this helps
Aug 27, 2009 | 2003 Toyota Camry Solara
Right rear brake seizing up and pads are wearing out prematurely
welcome to fixya
you might want to change out the caliber ....
sounds like you have a bad caliber and it is sticking open so the brakes are locking up
hope this helps you out have a good day :
Jul 27, 2008 | Chevrolet C1500 Cars & Trucks
Open Questions:
See all SYMA Toys industrial Syma S032 Ready to Fly Gyro Questions
SYMA Toys industrial Syma S032 Ready to Fly Gyro Logo
193 people viewed this question
Top SYMA Toys industrial Toys Experts
MeAndMyBrain
Level 1 Expert
Terry Hair
GI Consulting
Are you a SYMA Toys industrial Toy Expert? Answer questions, earn points and help others
