Question about Fujitronic Automatic Dispensing Hot Water Pot FP-30A Electric Kettle
I have a Fujitronic automatic dispensing water thermo pot. it only dispenses limited amount of hot water.
2 Suggested Answers
  • 587 Answers
SOURCE: No Cooling
The water pump or the float valve is not working.
Posted on Aug 10, 2009
Fugitronic automatic dispensoing hot water pot won't heat
The partial answer to your stated problem is that after 3-4 years of use it is possible that the heating element has worn out
Mar 08, 2013 | Fujitronic Automatic Dispensing Hot Water...
Bunn hot water heater has a slow flow of water
Try brewing a few pots of white vinegar solution, no coffee in the system.
Jan 22, 2013 | Bunn 125000024 Hot Water Dispenser 5...
Water does not pump
plug it in? or the motor has fried itself could be a defect item
May 03, 2011 | Fujitronic Automatic Dispensing Hot Water...
Sunpentown SP-3000 Hot Water Pot Dispensing Button No Longer Work
http://www.eserviceinfo.com/download.php?fileid=30158
Basically all eletric hot water pots are the same just like frig/stove.
pdf with wiring and parts.
Enjoy.
Dec 22, 2009 | Sunpentown SP-3000 Electric Kettle
Faber-ware automatic percolator model L1360 US no longer heats water well. It is in good condition. Suggests for repair?
The problem is the keep warm element. The reason, your pot perc's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix, it is the small looking white rope that runs around the bottom of the pot. You have 1-nut and 1- screw to remove. When removing the screw from the main element you must hold the (leg) that the K M element is screwed to so it does not bend and brake off. Take your time and be firm with the pressure you apply to the screw, while holding it with a pliers Good luck. bobbyone
Oct 25, 2009 | Faberware Coffee Makers & Espresso...
No Cooling
Aug 02, 2009 | Fujitronic FH-797 Portable Air Conditioner
Inconsistent water amount being dispensed
It sounds like there is some build up in the brew line, find the nearest bunn dealer and get a delimming spring, then remove the shower and run spring through brew line.
Apr 26, 2009 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
How do I clean the Hot Water Dispenser?
I have zojirushi 4L (model: CD-LCC). I noticed that the bottom of the pot have some stain which are looked like "corrosion". What should I do? How to remove it? Please help.
Thank you
Nov 01, 2008 | Zojirushi 5L Water Dispensing Pot Cd LCC50...
Zojirushi electric dispensing pot
Got greasy white stuff floating inside the kettle, any idea where this comes from? And how to eliminate it besides getting a new one. This unit is over 5 years old. Thanks.
Oct 18, 2008 | Zojirushi 5L Water Dispensing Pot Cd LCC50...
Fujitronic Automatic Dispensing Hot Water Pot FP-30A Electric Kettle Logo
67 people viewed this question
Top Fujitronic Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Fujitronic Kitchen Appliances - Other Expert? Answer questions, earn points and help others
