Question about Acer Travelmate 5742 Notebook
I have added a 2 gigabyte ram to my newly bought laptop and when i want to install windows xp it gives the blue screen
    Scholar:
  • 112 Answers
Does it give the blue screen with the old ram memory?. You can go to http://www.memtest86.com/. Memtest 86 is free software to test the memory RAM of your computer. You will have to download the .iso file, burn it in a cd, and reboot. This is the only way to test the memory ram to stay 100% sure that it's not corrupted. If it's not corrupted, then check the ram memory specs speed, and latency. They must have the same speed and equal latency-or better- than the older ones.
Posted on Jan 03, 2011
My computer reaches the win xp starup screen then a blue screen flashes theen it restarts
There are a lot of reason why this is happening. It may be a newly installed hardware, one of the hardware is damaged or it may also be the RAM. You can try reseating the ram first. If that does not help, if you have hardware connected through USB, disconnect it first.
Install the operating system (win XP) with the mouse, keyboard and the monitor connected. Other peripherals (hardware) should be disconnected to the tower.
Apr 20, 2011 | Microsoft Windows XP Professional SP2
I can't install Windows Xp Sp2 For Compaq Presario Cq60 Model. a blue screen error occured after completing the files from cd to ram before entering lience agreement
You need to check your system ram or memory. If you have 2 system ram or memory unplug the other memory and install the windows xp sp2 again. If still having a blue screen try the other memory then run the setup again. Also if you have an extra hard disk drive you can test it that or plug your hard disk drive to the other laptop and run the windows xp sp2 using your hard drive. If you can install the windows xp sp2 on the other laptop that means your hard disk drive are good. If your memory and to the other laptop are compatible plug it and run the windows xp sp2 installer to see and to diagnose what are really causing problem. Have a nice day.
Apr 02, 2011 | Computers & Internet
Bought a 'refurbished' x31 a while back, loaded up with BIOS thingy but nothing else. Got someone to install wondows on it, yesterday I got it back, started it up, worked ok for a few hours until I...
Did you install Windows 7 or is it XP, which is a discontinued operating system?
Blue screens are less prevalent and even nonexistent on Windows 7 vs. Windows XP.
Aug 22, 2010 | IBM ThinkPad X31 2672 Notebook
Windows xp instalation stpos givibg a blue screen in aspire m5640 desktop
Windows Xp installtion give Blue Screen of Death when XP tries to installed devices driver during installation or when the cd is corruptted and cannot be read in graphical mode installation or when the hard drive is corrupted with Bad sector.
Get a new windows XP CD and configure your system BIOS to default setting ( load optimal settings) and configured for IDE drive configuration to compatible mode or disable mode if you are using SATA hard drive.
If problem still occured, get "Bad sector recovery pro" and try to repair the hard disk.If the bad sector are unrecoverable then change the hard drive.
Sometimes, faulty RAM also give blue screen too. Check your RAM too.
Dec 19, 2009 | Acer Aspire m5640 PC Desktop
Blue screen error while installing XP in acer 5630 with 4 gb ram
Boot your computer with winxp disk then follow the procedure.
Press enter for install new xp then you see partition delete all partition then create again then install xp in first partition try this 3 to 4 times so that error not comes .you can do it.
Let me know if you need more assistanse.
Thanks.
Sep 21, 2009 | Acer Extensa 5630-6806 Notebook
Adding 2 gigs memory
try to install windows xP!! when the screen turns blue!! just press f7 until the setup is finnish!!
Jul 12, 2009 | Jetway 939GT4-SLI-G Motherboard
Installing RAM
you might want to try and remove the ram that you just installed and check if the problem is still the same. If it is then it's not the ram that's causing the problem. But if the problem goes away when you remove the newly added ram then you probably have a busted RAM
Sep 11, 2008 | Toshiba Satellite 2415-S205 Notebook
Blue Screen
OK, so I took out the added RAM, changed the internal RAM to a new 1GB stick. The machine booted, windows started, I logged on, then blue screen. I put the old internal RAM back in, changed the hard drive, same result. This test suggests that the RAM is fine as is the hard drive as the blue screen appeared with different hardware. My next step is to replace the motherboard as the appears to be the issue. I'll let you know how I get on.
Jul 17, 2008 | Toshiba Computers & Internet
Blue Sreen Error
I strongly suspect bad ram when any computer displays that message.
Apr 25, 2008 | Compaq Evo N610C Notebook
Acer Travelmate 5742 Notebook Logo
53 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
