Question about Samsung LN46C530 TV
Half my screen is dark the other half good on a 46 inch samsung 530
  • 197 Answers
SOURCE: Samsung 46" LCD picture dark at one side of the screen
bad panel
Posted on Jun 07, 2009
  • 304 Answers
SOURCE: Cracked 46 inch screen on my Samsung tv. Where can
You can go to Encompass or J&J electronics for the Panel. But If you have never replaced a Panel before, it is best left up to a trained Samsung tech.
Posted on Jul 16, 2009
  • 7 Answers
SOURCE: 46 inch Samsung TV that just clicks but wont turn on
I just fixed this very same problem. It is the capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Posted on Sep 25, 2009
  • 12 Answers
SOURCE: what to do if my sony bravia 46 inch gets dark on the right
Your inverter or cfl bulb is out on the right side.
Posted on Feb 24, 2010
SOURCE: When I trun on TV (Samsung LN-T4661F 46 In), it
Samsung made a bad TV, the new part is $1200 I have the same issue. it is a blurred picture from left to right after about 10 min it goes away. (18 month old tv) it is only going to get worse.
Posted on Jun 29, 2010
Bottom half of screen is black
The display strip is not properly seated in the connector base. That is a hardware problem so dont think of a software error.
Oct 07, 2014 | Samsung Un46eh6000 46-inch 1080p 120hz Led...
Dark Center of Screen and Ghosting on Right quarter of screen
Your LCD panel has failed, common problem with older Samsung's and Sony's. It will cost more to replace the panel vs. buying a new TV set. If I have helped you please sign my guestbook!
http://www.back2lifeelectronics.com/Guestbook.php
Mar 07, 2014 | Samsung LN46A650 46 in. LCD HDTV
LN46A530 Samsung LCD -half a screen black-stays for 30 minutes, than turn to some what normal, but not quite all.What is the problem , what is the part to replace?
is it completely dark or just very dim or dark on one side? if it's just dark on one side, you have a failing LCD panel, very common for older Samsung panels. If it is completely black on one side split down the middle, you could be dealing with a bad panel, bad t-con board, or a faulty LCD panel ribbon connection.
Sep 07, 2013 | Samsung LN46A530 46 in. LCD HDTV
Samsung LCD 46 inch half of the screen is darker than the other half.
Hi, while fixing another persons lcd tv i used lower rated power supply to try to fire up the tv ( picture-no sound) the bulbs ( actually cold cathode fluorescent ) lit up but only halfway. So sounds like the power supply for your backlight has gotten weak. You may try a workaround I've used on personal equipment, try turning down brightness on tv-this may,if your lucky, even out the brightness. hope this helped. Prodzilla
Mar 30, 2011 | Samsung LN46A650 46 in. LCD HDTV
Half of my lcd tv gets dark no picture
Find your warranty papers....may be a defective screen.
Apr 21, 2010 | Samsung LA46A550 46 in. HD-Ready LCD TV
No picture on my new 46 inch samsung LCD
Hi...there,
It's seems your backlight lamp is burnt out... if you are still under warranty... call the mfg. up and get a replacement lamp.
Nov 29, 2008 | Samsung SyncMaster 460P (Silber) (Silver)...
Samsung series 5 530 46" LCD
RE: Product Defect
If Its new enough to return without store rejection or if you still have a valid warranty --take it back! --
Aug 17, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung LN46C530 TV Logo
66 people viewed this question
Jerry Greenberg
Jerry Greenberg
