Question about Vacuums
Machine screams /not enough sucktion - Vacuums
  • 30 Answers
This is probably a plug in the suction side. if it is an upright with no hose, try removing the bottom where the brush is and look for an obstruction where the air goes up into the vacuum. On a canister vacuum check the wand then the hose for something inside blocking the air flow. On bag types, make sure the bag is not full or the inlet to the bag is not plugged. Hope this helps
Posted on Jan 03, 2011
When I am vacuuming, the DCO7 will scream every once in a while. Why does it do this? When I first got it, it would do this when it caught a fiber and ripped the rug. However, that it is not happening...
Hi. If the screaming sounds like it's coming from the roller brush it could be a bad bearing. Take the brush off then turn machine on. If it stops screaming the problem is narrowed down, if not get back to me and we can go from there. Hope this helps, Chris
Feb 21, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Why does my miele 700 revelution hoover keep cutting out? The bag is not full just loses power?
  1. i have a miele revolation hoover, it doesnt pick up. it has hardly no sucktion. where and how do i get the filter out to clean it??? it was given to me working. ive changed the bag so thats not the problem. and checked the hose. still no joy. need sucktion.. Thankyou jacqui
Jan 01, 2010 | Miele Revolution 600 Bagged Canister...
Hoover vacuum carpet cleaner will not sucktion (sic)
No, this cleaner uses no belts.
If you are having a suction problem, first check that the lid on the recovery tank is lined up to the tank when installed to get a good seal.
Second, remove the tank and make sure the round black rubber seal is present on the pipe from the base that aligns with the bottom of the recovery tank. That seal connects the vacuum from the motor to the recovery tank.
Oct 13, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
My dyson works only without the prefilter
Dyson's are terrible vacuums. Sure they look cool and may work for a couple months but they start to "fall apart" no more than a year. If you have pets, then i suggest you spend the money on a machine that won't break down or give you silly issues like a Dyson would. This vacuum is called a Miele Cat & Dog.
http://www.thinkvacuums.com/miele/catdog.htm
Jul 27, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
I have good suction at brush, but no suction in hose connection
i would change the bag and under the bag there is a filter, if dirty wash and make sure its completly dry before putting back into machine. once all done, have machine in upright position, turn on and see if there's sucktion at hose. hope this helps
Jul 25, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
The brush spins but the the dirt is not getting into the bag. i cleaned the hoses now it's not sucking anything up.
If the motor is running you should get some kind of sucktion, if no sucktion or wont blow any air out, check the house making sure is clear of any obtruction, the best way is looking in the house by have one person hold one end and other pull the house straight and look to see any obstruction. if it seem clear, check the motor attach to the fan, yep you have to take the cover to the motor off with phillips screw driver in order to see what causing motor not to **** although the motor may not be attached to the fan; could be loose and not spining the fan to create any sucktion. hope that help some..good luck
Jul 12, 2009 | Vacuums
My kenmore hida filter vacuum cleaner no longer has the sucking ability it used to have. It is only 4 years old and has worked extremely well up until this week. The motor is functioning well, as is the...
well i've hade one come in a while ago and it didn't have good suction so I looked at the bag it was buljing w/ dirt so I put a new bag in it and it had better sucktion but still not good enough so I cheched the fabrick filter and it was dirty too so I washed it and it had even better sucktion so try the paper filter on the end too and if your vacuum still haves bad sucktion try looking if the hose is clogged buy putting your mouth on the end and blowing through it i recomend whiping the end off befor blowing if hard to blow it is clogged, if clogged i would put something thin like a metal rod or or a stirty stick to push the dirt out i'm sorry if my info didnt work out :D
Jun 12, 2009 | Kenmore Whispertone 23312 Bagged Canister...
No suction on wind tunnel vaccum cleaner
Your brush might be clogged with hair. while uplugged, flip over the vacum and check to see if there is any hair or string wrapped around the brush...
Jun 03, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Not getting sucktion to the hose. not picking up dirty water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
7t897
Dec 22, 2008 | Bissell 9400 ProHeat Upright Wet/Dry...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
