Question about HP LaserJet M3035 MFP Printer
I have HP LaserJet M3035 in network environment. It's been workign fine. Today it says it's PAUSED and no mater what's being done (rebooting it, restarting he spooler, deleting all the print jobs from hte queue) it still says it's PAUSED. Help please....
SOURCE: Printer Spooler/Unwanted print job
Canceling print jobs can be frustrating - slow even when it works. Follow these steps exactly, and you're home free.
(I'm assuming you use XP, and if XP Pro that you have administrator permissions.)
- Start Button
- Accessories > Administrative Tolls > Services
- Click one time on Print Spooler in the list of services on the right (they are alphabetical)
- In the column on the left, click "Restart"
- When the progress bar diappears, you should be OK.
Posted on Dec 30, 2008
leroyal
  • 2120 Answers
SOURCE: hp-ux print queue on a m305 mfp printer
Unplug the power cord for 10 seconds, or scroll through the menus for RESETS
Posted on Jan 05, 2009
webmaster21
  • 803 Answers
SOURCE: HP laserjet 2600N print job stuck in the printer
  1. Hit start on your Windows and click 'run'. Type in cmd this will open the old version of what many call MS-DOS or C prompt.
  2. At the C command type: net spooler stop
    You will get a message when the spooler has stopped. Now you need to clean out the queue.
  3. Go back to start menu and click on run again. This time type:
    %SYSTEMROOT%\system32\spool\PRINTERS This will bring up the folder. Delete every file in there. (It's okay this will not harm anything.) Now you need to start the spooler again.
  4. Go back to your c prompt screen and type:
    net start spooler
    This will start the spooler for you again.
  5. Go check your printer queue. Sometimes you may need to f5 to refresh the screen. You did it. Your stuck files in your printer queue are all gone. You can begin printing again.
Posted on Sep 24, 2009
SOURCE: hp laserjet p1006 printing jobs gets struck in printing queue
Solved a similar problem by turning off the UAC (User Account Control) in Windows Vista and Windows 7 machines. Worked great without UAC on.
Posted on Apr 17, 2010
SOURCE: Print jobs get stuck in the queue
OK - all the answer posts on HP sites, Experts Exchange and MS have been a joke to this problem so far. HP 10xx series LaserJet printers do not work (well) in a shared environment. I have found two solutions to this problem. If you really don't understand shares/printing/services/firewall exceptions - don't bother trying this - buy a networked printer when the toner runs out of the HP10xx.
If you want to spend a few hours or about $100 for a print server/NAS device, read on... I HAVE an HP1022 shared on a Windows XP Pro SP3 machine serving as a print server to a Vista laptop, a Windows 7 desktop and a Mac-Mini running OS X 10.6.x. ALL are working.
1. Buy a network print server device (or a NAS device with an included print server - I picked up a Buffalo LS-CHL 1TB and it worked out of the box. I AM NOT ENDORSING BUFFALO NAS servers, they get horrible reviews and you may end up having the same problem down the road due to the NAS device) In this case, your print clients (Win7, Vista, XP, MacOS X) can use a traditional SMB Windows client to print or the BETTER solution is to use the print services for Unix client that comes with Windows but is not installed by default. Both clients work, you may have fewer problems down the road using the Unix (LPR) client. See http://www.alexfalkenberg.com/2009/10/06/linkstation-windows-printing-problem-solved/ This is an excellent article on the Buffalo - BUT THE SOLUTION works in a native windows environment as well.
2. Build on the idea from number 1 above and INSTALL the LPDSVC (friendly name TCP/IP print services) on the machine with the printer LOCALLY attached through USB. You will also have to open up some firewall ports on the machine you are using as a print server if you have one running... I used a program exception (C:\WINDOWS\system32\tcpsvcs.exe) but you could lock this down to 1 TCP port if you wish - I think TCP 515 but you'd better check on this one...) Share the printer as normal. Next install the "Print Services for Unix" CLIENT on the machines you want to connect to the printer remotely from. When you connect to the printer share from the clients, select a LOCAL port, create a NEW PORT, select LPR, use the hostname or the IP of your machine acting as a print server and the NAME OF THE SHARE as the queue. (I don't like to have spaces in my share names, so I used HPLaserJet when I set up the share and description.) You will HAVE TO INSTALL THE RIGHT Printer driver locally on each client. This might be easiest just plugging in the printer with a USB cable since the HP printer driver is an installer as well and wants it to be connected locally unless you can extract the driver...)
Sorry I can't give more details than this. If you don't get the jist of what I am saying above. Don't try it. Give up and call the plumber.
Posted on Jan 08, 2011
From computer How can i scan document from HP LaserJet M3035 MFP
From the search I did that printer is not an all in one and does not hacv a scanner function
Feb 13, 2016 | HP Office Equipment & Supplies
110/1003 (0X3EB)
on HP Laserjet m3035 MFP can not scan in PC we have WIN 7 32BIT edhe show error code 110/1003(0X3EB) Help me
Dec 16, 2013 | HP LaserJet M3035 MFP Printer
My HP M3035 is printing, copying & scanning extremely light but only after I changed th toner It prints fine with the old but with the new the print is light as if it were empty
You have a defective cartridge. It just happens sometimes, you should be able to return it where ever you got it for a replacement cartridge or refund.
Sep 03, 2013 | HP LaserJet M3035 MFP Printer
Bran new HP m3035 MFP.
Try replacing the toner if you have another one, even old one should be ok to test, if not the look at the toner drum and see if there is any marks on it.
Jul 09, 2010 | HP LaserJet M3035 MFP Printer
How do i scan on HP LaserJet M3035 MFP from computer?
Assuming your scanner is installed already, what you need to do is log into Windows Photo Gallery (Vista) and click on FILE at the top left. When the drop down bar engages, you should look for IMPORT FROM CAMERA OR SCANNER and click it. Then a new window will open up and you'll have to pick your device (HP Laserjet M3035). At this point check your settings, and make sure your scan is ready, then click on either PREVIEW or SCAN. Then when it is done scanning, you will have to go to the folder you saved it in to view it. (Xp Similar)
Hope this helps.
Jun 07, 2010 | HP LaserJet M3035 MFP Printer
HP LaserJet M3035 MFP Printer Logo
140 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
