Question about Sub-Zero Refrigerators
I cleaned the tray of the ice maker of my Sub Zero fridge and returned it to the fridge. Now the icemaking does not work. What did I do wrong?
I'm having the same problem. There must be some way to restart everything. Did you get it working?
Posted on Feb 04, 2011
Do you have to remove the screws on the ice-maker to remove the plastic icemaker service tray.
I believe you are talking about the shut off arm. You need to remove the lower freezer drawer. Pull it all the way forward and then lift up. The screws are under the icemaker.
Nov 01, 2014 | Sub-Zero 736TCI Refrigerator With Ice Box
Sub zero icemaker freezes,no ice
You need a new Ice Maker. Very often body of ice maker starts to leak.
May 12, 2014 | Sub-Zero Refrigerators
Water Leaks from Ice Maker of Sub-Zero 642
Sounds like the water inlet valve to icemaker is leaking - not closing completely after filling the tray. Rare, but possible. Prove it by shutting off icemaker arm or switch. If that is the cause, the drip will continue.
If dripping stops when I/M is off, then it is ice blockage in I/M fill tube and or diverter funnel at end of ice tray. Remove I/M, clean ice from both, and re-assemble.
Replacing that valve (water supply to refrig connects to it in the back) should solve it.
Jun 13, 2009 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Ice Maker won't work
If your trying to save a service call you have your work cut out for you. The ice maker is a unit that sits by itself attached to the wall or part of the freezer wall.
There are many reasons why you do not get ice and I will list them.
1- Temp of freezer got too cold and has frozen the pipe that feeds the water to fill the icemaker.
check to see if the icemaker has any ice in the area that fills and makes the cubes.
If the pipe is clogged, very gently put a small tipped screw driver in the fill hose that sites over the ice making row in the ice maker. Be careful you do not push your screwdriver out the back of the refer.
Check to see the freezer temp is not too cold and is freezing that pipe. 0-3 degrees F is good.
2.- check to make sure your water feeding the fridge is on. There is an on off valve to allow the water to feed the icemaker when it needs to fill. This could be bad. there are reset proceedures for the fridge, but unplugging the entire frige for 1 minute and plugging it back in you can listen for the the valve to come on and see if it fills the ice maker resevoir.
3. If it fills and freezes the ice resevoir, then the sensor in the ice tray does not sense the frozen ice and will not cycle and kick cubes. At this point, unless you are super tech, you will need to replace the entire icemaker unit.
Hope this helps.
Mar 21, 2009 | Sub-Zero Bottom Freezer Refrigerator
Icemaker for sub zero 632 is not working, tray will not fill with water,there is no water in tray, It worked fine before hurrican, we emptied the frig and freezer and shut off the breaker for the hurr
check the water pressure ... if you have a filter in the line it may be restricting the pressure ... I had the same problem and a new filter fixed it
Nov 06, 2008 | Sub-Zero 632 / S
Sub-Zero 632 Ice Maker Leaking into Ice Bucket
Ice Maker is overflowing and leaking into the ice bucket: There are several things to check for.
Go for the easy stuff first, make sure the icemaker is level, some of the plastic liner fridge's will move and allow the icemaker to tilt over and leak. Other troublemakers..... the fill valve
staying on and over filling the icemaker..... the finish sometimes comes off the icemaker body and all the ice cubes don't come out. This will allow the new water to fill on top of an icemaker
that still has a ice cube or two left inside the body, if you have had trouble with black specs in your ice cubes, this may have been the beginning of your finish problem on the icemaker body.
On the module style ice makers (Whirlpool, Maytag Family, Sub Zero) the printed circuit in the
module head often wears and the contacts become too long and allow the icemaker to over fill = new ice maker or new module head.
Older style icemakers: This gear is bad for breaking and the icemaker quits turning to eject the ice.
You can remove the front cover to see the gear.
This is a common parts breakdown of the older style icemakers
Water fill volume: The water fill adjustment screw will change the fill volumes by changing the fill time.
One half to one full turn usually ( approx ) is equal to 20cc ( 0.68oz ) to 40 cc.
The correct fill is usually 130 to 150 cc ( 4.5 to 5.0 oz ).
When a water valve is replaced the fill volumes must be re-checked!
http://www.SubZeroLosAngeles.com
________________________________________
Sub-Zero Service Experts in LA Metro
Aug 15, 2008 | Sub-Zero 632 / S
Sub-Zero 550 - freezer unit is chilling, but not freezing
Ice maker was intermittent at best - ice was often just a shell. After two failures to correct we had the ice maker (a Whirlpool - on a Sub Zero - Go figure) replaced. Then the paddle that detects the ice level broke. Next step a new GE.
Jun 13, 2008 | Sub-Zero Bottom Freezer Refrigerator
Ice maker leaking
what is the model number of this fridge?
HTML clipboard_______________________________
http://www.subzerolosangeles.com
Los Angeles Sub-Zero refrigeration experts
May 19, 2008 | Sub-Zero 632 / S
Ice maker
verify the water supply to the valve first, second verify valve to icemaker works(unit has dual valve at rear bottom of fridge, switch plugs, then press water dispenser and see if icemaker fill with water ) if fills icemaker is bad , if not valve is bad. replace one or the other.
Mar 28, 2008 | Refrigerators
Icemaker does not work on subzero 650
My ice maker on the Subzero 650 is up and running again. After checkig the tray and shutoff mechanism thoroughly I checked the display in the fridge aea and noticed a "service icemaker" indicator. I turned the icemaker off and then on again with no change. I then turned the power to the entire refridgerator/freezer unit off, waited ten seconds, and thurned it back on. This apparently must have reset some type of logic because the icemaker immediately began to cycle (ice ejector began to turn slowly) and then I heard the water soelenoid turn on to inject water into the ice trough. It's been 24 hours now and the icemaker tray is filling up nicely. I guess my icemaker just need to be rebooted. The miracles of modern technology. I appreciate the suggestions posted in response to my posting as well as the postings of others with similar issues as well as te corresponding suggestions. All of these together lead me to investigating areas that ultimately lead to resolution. I probably would have called for an expensive repairman if not for this forum. THANKYOU!
Dec 05, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
144 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
