Question about Denon AVR-2106 Receiver
I had the the volume up medium listening to music. I then smelled somthing burning. it was coming from the inside of the receiver, from the top vents. at this point the power light started to blink and i then lost power. when i press the power button, it blinks red and then shuts off. i have a denon 2105 avr
  • elco-fixer May 11, 2010
    Just managed to repair AVR2105 which had same symptoms as descibed above. Replaced a pair of output transistors and some o/c resistors etc. The only problem is the amp is generating too much heat. I guess quiescent current for output transistors needs adjusting, there is a trim pot near them and a socket to plug test wires I guess. Anyone knows how to adjust quiescent current and to what value?
    thanx
    President:
  • 624 Answers
It is most likely that you have a shorted output channel or a supply resistor that sometimes opens. The smell you had was probably a resistor opening up. This could be a couple of resistors in a output channel or the supply resistor mentioned above. In either caase, it is something that would require an experienced technician to repair. If you have a multimeter and soldering iron, I could help you to determain the exact cause. But it would require very good soldering skills and if the problem is more than just the supply resistor opening it would require the replacement of 2 output transistors, 6 to 8 resisitors, 3 driver transistors, 1 capacitor, all for repairing a shorted output channel. I have repaired many of these Denon receivers and it takes an experienced technician about 2 hours to complete the repair. It is very common for these Denon's to have this problem.
If you are up to the task, let me know and I will direct you to the proper components and give you the part numbers you will need to complete the task.
But beware, it must be done perfectly the first time, and if you miss just one bad component and then turn the unit on again, it can burn up all the components you have just replaced.
Do not continue to try and turn the unit on any more since it is going into the protect mode, doing so can cause more components to fail from excess current being drawn thru the bad channel every time you turn the unit on again.
Let me know if you need more help.
Dave
Posted on Jul 09, 2008
Burning rubber smell coming from top tweeter and smoke coming out as well
If it is an active speaker unplug it now!!!!!!!! If it is a pasive speaker open it up and see what is burning. disconnect it. you will cause further damage. If you need it fixed you can order the parts. or send it in to our shop or find a local service center.
Vito Vacirca Jr.
Pro Line Music
490 Lincoln Highway
Fairless Hills Pa. 19030
215-736-8055
servicedepartmentprolinemusic@comcast.net
www.prolinemusic.com
Jul 15, 2011 | Audio Players & Recorders
I was playing my ipod thru my Pioneer VSX-518 tuner and noticed that sound was coming trhough only 2 speakers. While playing the music I toggled through the advance surround options. When it came to...
I believe that smell is the death of a semiconductor in the surround power amp. How loud did you have it? As for an inexpensive fix, there will be hours of diagnostic work, and the parts can be VERY hard to find and expensive.
There is also the issue of safety. You should likely take it in for repair. Receivers aren't as dangerous as televisions or microwaves but they often have the two live 110V wires exposed near the primary of their power transformer. If you don't know what that means I strongly recommend you don't fix it yourself. These can also be dangerous even when they're unplugged, due to high value, medium voltage capacitors
Aug 12, 2010 | Pioneer VSX-518-K Receiver
Panasonic pt-l780u projector lamp warning light comes on and lamp goes out. smell somthing burning. this is with three lamps. i am sure it's not the lamp.
the burning could be the dust on the inside burning off. blow the dust out with canned air. then check to see if the fans are spinning. after that, it's the ballast/power supply.
Nov 11, 2009 | Optoma H30 Multimedia Projector
BURNING SMELL COMING FROM MY WASHING MACHINE
if it smells like rubber burning then i would suspect a belt is worn or slipping or somthing has jambed the basket from turning .. the belt is not expensive ..labor of course would be extra .. if the burning smells like insulation or a strong electrical burning smell then you may have a bad motor .. those used to be about $70 + labor .. no telling what they get for them now ...
you mention that the smell came from inside ... do you mean inside where the cloths are (the tub) or inside the cabinet (outside of where the cloths are) ...if the smell was coming from inside the washing tub .. then i would suspect something cought between the inner and outer tubs .. if the smell is not from there then the first suggestions above are good ... bras and slippers and such are good for getting cought .. check where the movable tub (with holes) meets the outer tube (no holes) .thats at the very top of the tub .. ..make sure nothing it cought there ...
Aug 05, 2009 | Washing Machines
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
try this mate:
http://www.electronicspoint.com/googlesearch.php?cx=002919058480771089906%3A03mranmmdze&cof=FORID%3A10&ie=UTF-8&q=Technics+SA-GX550&sa=Search#862
May 23, 2009 | Technics SA-EX400 Receiver
"protect" display when volume is high and volume cuts in and out.
you should have it repaired.the audio circuit is malfunctioning because of the sudden burst/surge of current.
May 15, 2009 | Onkyo TX-SR502 Receiver
My AVR 2803 shuts down when volume is at medium or above.
too big a speaker load,unit sensors shut unit down when speaker impedance gets too low . and draws too much current at hi volume.A bad woofer or tweeter voice coil burned by sudden excess volume can cause this,also partially shorted speaker wires.
Jan 03, 2009 | Denon AVR-2803 Receiver
Speakers humming. No reception.
The audio amplifier in the unit has failed, and that's what you smell. Turn it off and quit using it immediately - it presents a fire hazard. It might be possible to replace the bad parts. Depending on what it cost, you might want to take it somewhere for a repair estimate, but be prepared to learn it might not be fixable. Often the burned parts damage the circuit board as well.
Usually this happens in small stereo systems because of running them at high volumes for a long time. If you want to listen to loud music, you would be better off putting the money into a higher-power system.
Dec 08, 2008 | Audio Players & Recorders
Duet Dryer
burning smell would be coming on the coil of an electric dryer. the coils could have catch some lint that produces that distict burning smell..
i hope i was able to solve you problem..
pls rate me.
tnx
drcool
Jul 15, 2008 | Whirlpool GEW9250 Electric Dryer
Denon AVR-2106 Receiver Logo
253 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
