Question about Dryers
Maytag Dryer Loud Shrieking Noise Maytag Intellidry Dryer D-4, 10 y/o, Model MDG9806aww (QuietPlus II). Replaced belt. Replaced two dryer drum rollers (just the wheels, the posts looked and felt OK, but what do I know?). When the belt is not connected and I turn the drum, I do not hear the noise. The situation has deteriorated -- it sounds as if metal is rubbing on metal. The clothes dry just fine and require the same amount of time as before. I did not use any grease or lubricants at any point, if that makes any difference. I would appreaciate any other things to look at. Thanks
  • 1 more comment
  • 458399976 Oct 10, 2008
    My maytag dryer is having the exact same problem. Were you able to fix it? How much did it cost?
  • svcctr87 Jan 17, 2009
    I have a Maytag LDE8824ACE dryer that is about 10 years old. It dries clothes fine, but the screeching noise is very loud. I will try the solution below, once the clothes that are in the dryer now are done!
  • dcsmith37464 Mar 15, 2009
    loud screeching noise when dryer is on, same maytag LDE8824ACE. I don't see the "4" phillips screws just inside the front door as referenced. I do need to vacuum the inside of the unit and my guess is replace the belt... Any thoughts on opening up the unit?
    Dave
  • 246 Answers
Here we go. First unplug the unit. Remove the front panel by removing the 4 phillips screws just inside the door (on the hinges and just opposite). Next remove the greenish/ brown 5/16 screws that hold the front panel in. There are wires still connected (door switch and moisture sensor) but if you swing it to the side, you can leave them connected and still procede. Next, you have to reach underneath (very difficult to see this so you will have to do it by feel) There is a belt that wraps around the drum. On the underneath side of the drum as you follow the belt it wraps
around the motor pulley (small wheel) and the tensioner pulley (bigger wheel just to the right). Now with one hand, move the larger pulley towards the msaller one. This will give you slack and you can take the belt off both pulleys. Now pull the drum
forward. There you have the inner workings left. Now, there are 3 wheels. 2 black and 1 white. I would check the white one since you've already replaced the black ones. This is the pulley that provides tension when the motor is running (hence no noise when you take the belt off) I'm betting you'l find it does not turn freely (you should be able to spin it with your finger and have it coast to a stop insdead of stopping as soon as you take your finger off). You can get the replacement wheel from your local appliance parts store or on line from the manufatrues web site. However, if you do have to wait for the part, take the wheel off the shaft and wipe off the inside race of the wheel and the shaft for temporarily relife and useage.
Posted on Jul 09, 2008
Maytag intellidry dryer
This could be a lot of things. It could be the belt on the drum, the tension pulley on the belt or something stuck between the drum and the frame. To check it you need to unplug it and see if there is a panel under the door that comes off. There may be screws on the bottom of it. If it does not come off, the whole top lifts off.
Sep 03, 2014 | Maytag Bravos X Series MGDX500XW
My Maytag MDE9606AYW drum randomly decides to not start. I hit the push button and there is loud noise but the drum doesn't move. When it does start the loud noise happens but it is quickly replaced by...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 02, 2011 | Maytag MDE5806AY Electric Dryer
Maytag quietplus heats well but makes grinding sound
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Nov 22, 2010 | Maytag Dryers
Dryer makes loud noise when operated.
Get your model number and get a set of glides or drum bearings, whichever your unit uses. Don't let this go too long or your drum could be ruined.
Dec 01, 2009 | Washing Machines
Maytag performa intellidry dryer model#PYE4500AYW
Check drive belts. If too loose or too worn it will not spin at proper speed.
Mar 27, 2009 | Dryers
Dryer only ''humms'' when you press start
It sounds like you have a broken belt.
Does the dryer blow are from the exaust if it does then your belt probly broke.
Dec 08, 2008 | Dryers
Maytag Dryer squeeling
Drum support rollers. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Maytag Neptune MDE5500AY Electric Dryer
1999 maytag intellidry gas dryer
The groaning sound seems as if the belt is broaken and the motor is trying to spin a little too fast because it doesn't have a load on it. Take a look to see if the belt is broken and if so, you can purchase a replacement belt at Lowes for approximately $7.00.
Mar 15, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
819 people viewed this question
Top Dryers Experts
