Question about Engel Commercial Refrigerator
Thetford n100 refrigerator not getting cold when turned on,as any1 got any answers please
Will not get cold can a person wire the theromister wires together
disconnect thermistor at board let run if gets cold replace if not bad board or cooling unit
Nov 17, 2013 | Thetford Norcold RV Cooler/Freezer
I have a thetford N112 fridge which works on gas but not on mains, the element heats up but fridge does not cool
Hope this answers all your questions
Leave a comment if you need more help.
Thanks for using Fixya.
Oct 16, 2012 | Thetford Refrigerators
I have a Norcold 611 and the freezer works fine, but the refridgerator wont get cold. Any answers?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 25, 2010 | Thetford Norcold RV Cooler/Freezer
BOTTOM NOT GETTING COLD
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 29, 2010 | Thetford Norcold DE0051 Refrigerator
Thetford N90 EL.L built-in has stopped cooling/freezing. It has power (the light is on) Any repair suggestions?
If it won't cool on all 3 power sources the cooling unit is probably faulty. Contact Thetford asap if the unit is uner 3 years old as it should be under warranty. Thetford won't sell a replacement cooling unit, their only answer is that you need to buy a new fridge at over £600. I have this problem too and am looking for another solution but to luck so far
Mar 28, 2010 | Thetford RV Refrigerator - N300 Model -...
Will not turn on as error code no 14
simple answer. Little resetable fuse on power board, F5 as i remember. It causes the display board to go insane as it doesn't provide enough power to the board. Solder a 2amp one across it. I nicked one from an old computer motherboard USB fuse(usually mounted next to each usb socket). SORTED! was an issue with 2007/8 fridges, especially if you had solar panels fitted tgo your caravan!!!! :)
Jan 03, 2010 | Thetford Refrigerators
Fridge wont get cold with gas
This is worth a try. Disconect the gas and power make sure the pilot light is out. Turn the fidge unside down overnight then unright again. Try it on gas agian. This worth a couple of goes before giving up.
Aug 30, 2009 | Thetford Norcold N323 1.7-cu ft 3-way...
Fridge will not work on gas
If you're sure the gas is igniting and making heat, you may have lost your refrigerant. It probably is ammonia, which smells very strong. Check your dealer for someone who can check it out.
Apr 27, 2009 | Refrigerators
Engel Commercial Refrigerator Logo
98 people viewed this question
Top Engel Refrigerators Experts
Jaime Hernandez
christian nielsen
cwradio73
Are you an Engel Refrigerator Expert? Answer questions, earn points and help others
