Question about Roper Dryers
NOT BLOWING HOT AIR IN THE CLEDRYING CY - Roper Dryers
  • Roper Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape and running the dryer to check to see if the element is red or not,
or with an ohm meter check the two terminals of the thermostat/thermister
after you have removed the wires, the thermostat/thermistor should have/show continuity across the terminals.
If the coil heats up, or the thermostat/thermistor shows an open circut
then replace the thermostat/thermistor as it is defective.
If it overheats the dryer will not operate properly.
It's located on the blower housing.
It cannot be reset. A vent clogged with lint can cause it to overheat.
You can test it with an Ohm meter/continuity checker, if no continuity,
replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the an element go to the following website, it will give you an idea what you are in for:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Jan 03, 2011
Hot air blows into car from underneath of car what is causing this
does the air blow in when the car is not moving. if it does, your heater switch is on and blowing hot air in through the bottom vent.
Apr 01, 2014 | 1997 Ford Taurus
Heater not working
HEATER NOT BLOWING COLD,NO HOT AIR FROM HEATER,A/C BLOWS HOT AIR,A/C NOT BLOWING COLD, COLD AIR FROM HEATER,BLEND DOOR ACUTATOR CLOSED,HVAC UNIT NOT OPERATING,
http://alltypesofpartsreplacing.blogspot.com/2012/12/heater-not-blowing-coldno-hot-air-from.html
Dec 26, 2012 | 2001 Ford Taurus
The air conditioner is blowing hot air, there is no water to drain
if it is also blowing cold air out of the other vents you need to vent the hot air its blowing outside
Sep 30, 2010 | NewAir ACP-1000E Portable Air Conditioner
Blowing out hot air
check for the clogged evaporating coil
Jul 20, 2010 | Sharp CV-P10LC Portable Air Conditioner
Brick Air blowing hot air
if you hear the compressor turning on,no heat, the coolant has leaked out. if the compressor doesnt turn on, its a control issue.
Jul 25, 2009 | Heating & Cooling
Blows hot air
My 2003 chevy suburban just started blowing hot air...it was working find , then i stopped to eat lunch, when I came out it started blowing hot air
Jun 25, 2009 | Heating & Cooling
After boost air conditioner started blowing hot air
BLOWING HOT AIR YOU MAY HAVE A RESTRICTION ON THE SYSTEM, OR MAYBE A REAL BAD LEAK THAT UR FREEON IS ALL GONE,
May 28, 2009 | 2006 Chevrolet Trailblazer
Not blowing hot air when idling
check the coolant level on the radiator..it sounds like its low
Jan 24, 2009 | 2004 Chevrolet Suburban
Dryers Logo
32 people viewed this question
Top Roper Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Roper Dryer Expert? Answer questions, earn points and help others
