Question about Philips 43PP9202 43" Rear Projection Television
I Specifically have a 2005 Phillips 50" Projection
On your remote go to menu,then push picture then scroll down to converge then depending on what color is out of line you will push that,then what ever is out of line you line it up by the up arrow.if that don;t work then there are parts on your board gone bad.
Posted on Feb 19, 2013
yambo
  • 230 Answers
SOURCE: have phillips 55 hdtv that needs convergence badly
OK, friends.. Replace two Ic's Stk 392-110, and get in service menu settings , and adjust point by point. After replaced stk IC's, check if any resistor look brown or born, if yes, replaced it with 6.8 Ohms.SOme time SSB is defective ( small signal board, replaced it ) If you have questions? noetvs@embarqmail.com . Good Luck !!
Posted on Jul 24, 2008
SOURCE: I need the service mode sequence for my philips 51pp9100d/37 so I can manually change the resolution on my tv. The resolution somehow was changed and when I HDMI my laptop to the tv it wont display t
I suspect that you may be using a cable or sat box rather than that set's internal atsc tuner.
Sometimes these boxes are not set up properly or reset themselves to a lower resolution.
Go into your box's settings menu nd look for the resolution settings. Verify that all of the modes or at least the maximum resolution for your set is enabled.
Posted on May 03, 2009
TOM2-TOM2
  • 110 Answers
SOURCE: Phillips HDTV will not turn on I have a 3 year old Phillips 51PP9100D/37 TV that worked gret up until a week ago.After being turned on for a short peroid of time it just shut off.I have no pic. or sou
Check fuse #1003 on SSB and Audio Ouput IC #7700.
Posted on May 27, 2009
  • 380 Answers
SOURCE: I have a Phillips HDTV model #42PF7421D/37. When
Try another hdmi wire. Physically look at the hdmi port and see if there is damage done to the port. Change the source. IE another cable box, xbox 360 dvd play etc. If all else fails, change SSB or Scaler. Depending on the set. It'll be one or the other. I don't have my information with me at the moment to distinguish which one you'll have.
Posted on Dec 08, 2009
Ecollier2012
  • 3459 Answers
SOURCE: White glow around dark objects
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Feb 03, 2010
I have a PHILLIPS scrren HDTV MODEL #51PP9100D/37 and it hs green and red outline on picture. Can you tell me what could be wrong? Can this be fixed? Didn't know if it is something I can do myself or...
Its a convergence problem. The three color guns have drifted and it shows on the edges. Typical of an old projector tv
These will help
www.youtube.com/watch?v=esk4nYZKFcg how-to instructions: www.ehow.com/how_2034880_perform-convergence--tv.html
Mar 08, 2014 | Philips 60PP9202 60" Rear Projection...
Symptoms:
  • Screen Looks 3D
  • Colors wont align
Jan 28, 2010 | Philips 55PW9383 55" Rear Projection...
May 02, 2009 | Televison & Video
Phillips hdtv model 30pw9110d/37 won't turn on
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
Apr 28, 2009 | Mitsubishi WT-46805 46" Rear Projection...
50 inch phillips hdtv model:50pl9126d/37, no picture...
Unplug for one hour then plug back in---worked for me--computer resets
Mar 18, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
PIP does not work
The PIP can only use one tuner at a time, if one is on CATV, the other has to be on an AV input. you would need a catv box for the AV input for this to properly function.
Feb 27, 2009 | Philips 51PP9910 51" Rear Projection HDTV
Phillips 55pl9524/37
Hi
this amber color means defective power oscillations Circuit! need to diagnose at the regulated power supply. and or at the HOT area.,
Thanks!
Dec 27, 2008 | Philips 55PL9524 55" Rear Projection...
Tv turning on and off itself
Try "hiding" the remote from the set so that the TV cannot "see" it. Hope this little trick helps...accordianman
Jan 22, 2008 | Philips 43PP9202 43" Rear Projection...
Philips 43PP9202 43" Rear Projection Television Logo
73 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
