Question about Cameras
Nikon Coolpix L12 It has a constnat lens error screen Accidentally sat on my camera when it was on, with the lens fully dialated. Now it will open, but will not close all the way and Lens Error appears occassionally... 3 x out of 5. It seems to get stuck when opening and closing, rather off-center
  • 2 more comments
  • dalen1128 Jul 10, 2008
    I've removed the batteries, and replaced the batteries. I have not, however, left the batteries out of the camera overnight. It appears that the lens frame is "off center", which is why it seems to "stick" upon opening and closing. It is the third small lens that gets stuck.
    I did as you suggested, carefully turning the lens. Now,a tiny silver "pin" fell out from the smallest lens, and now the outer two lenses open, but the smaller, third lens does not extend. And now I have two parts, the camera and the tiny pin!
    Do all the cameras come with a one year warranty? I bought it last Christmas from Ritz Camera in California and not sure if I have the paperwork
    You are terrific! I'll be sending it in right away.
    Genius:
  • 1,036 Answers
Yes all cameras come with a maufacturers 1 year guarantee - against workmanship or manufacturing defects.
Basically if it works when you get it, they can walk away saying it must be your fault it's broken because it used to work.
Sad - but that's how it is now.
No, sitting on it is not covered by any guarantee.
One of the alignment pins seems to be broken, so it will not stay rigid. This will require repair or replacement.
Unfortunately this probably is not economic to send for repair, but if you can find a "donor" camera cheaply, you may be able to replace broken parts.
Sorry It's bad news.
Thanks for using Fixya.
Posted on Jul 10, 2008
  • 2,071 Answers
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take
  • Cameras Master
  • 6,487 Answers
Try this. Very gently pull out on your lens while turning on the camera. You can do this by getting your fingernail under the front cover where the little protective doors close. Don't pull too hard or the entire front cover of the lens assembly might pop off. If this doesn't work I would just replace the camera. The cost of repairing it would be about $150.00
Hope that helps.........
    Genius:
  • 1,447 Answers
Hi-
If you accidentally sat on it, pls check for physical damage on the camera itself. Try re-setting it by removing battery and leave it off for a few hours but if problem persist call NIkon support esp if you are within the warranty period, here are their contact info
Digital Imaging Technical Support
24 hours a day 7 days a week
1-800-Nikon-UX or 1-800-645-6689
To send an email click here.
Film & Sport Optics Technical Support
6am-4pm PST Monday-Friday
1-800-645-6687
Service and Repair Support
1-800-645-6678
For Nikon Service and Repair mailing and status information available through our website click here.
Nikon Parts Department
8am-3pm PST Monday-Friday
Phone: 1-310-414-8107
Fax: 1-310-322-6979
Thanks for using Fixya! Have a nice day!
  • 1 more comment
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Jul 10, 2008
    Hi-
    Check for physical damages or dirt that is preventing the lens to retract, ot try plugging the ac adapter for it and turn unit off and on.. thanks!
    Suggesting to have an expert look at it. and prevent voiding the warranty for camera
    Yep, you have a year warranty from the manufacturer not from the store where you got it. all you have to do is provide the serial number for it. Thanks!
  • Cameras Master
  • 19,396 Answers
Try helping the lens back in place with your finger while you turn on the camera
  • Ginko
    Ginko Jul 10, 2008
    Lens error also happens because of small dust on the lens gear try also sprying some canned air on the shutter and lens gear.
  • Ginko
    Ginko Jul 10, 2008
    If you cannot fix it in this simple ways, then the lens barrel should be taken apart, in this case the job is better done by a professional.
How do I correct lens cover error?
nikon coolpix s52 lens cover error Questions & Answers ...
www.fixya.com > Forum > Tags
Nikon COOLPIX S51 Digital Camera When I turn the camera on the lens cover willnot slide open. The screen displays a message that say "Lens Cover Error!
Nikon COOLPIX S52 Digital Camera - Fixya
www.fixya.com/support/p926575-nikon_coolpix_s52_digital_camera
Recent Nikon COOLPIX S52 Digital Camera questions, problems & answers. Free expert DIY tips, support, ... How do I correct lens cover error? Nikon COOLPIX.
Fixing a nikon S52 camera lens cover?? PLEASE HELP!!!? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Apr 4, 2011 - ... broke my lens cover on my nikon coolpix s52. when i try to turn it on it says Lens cover error and has a ... Can i fix it myself? What would be the approximate cost of repairs? ... How to fix Nikon Coolpix L6 digital camera lens?
Lens Error message ' Nikon Knowledgebase
Aug 31, 2015 | Nikon COOLPIX S52 Digital Camera
The lens on my coolpix l12 keeps getting stuck and the shutter cover will not close
the lens on my coolpix l12 keeps getting stuck and the shutter cover will not close
Jul 19, 2011 | Nikon COOLPIX L12 Digital Camera
My Nikon Coolpix L12 will power on but won't take a photo. There are no error messages on the screen. The lens will extend and retract. The zoom works. The shutter release button depresses but will not...
Well, seems like a camera failure to me,actually the processor inside the boards is wrong, maybe your product is a failure ones, I think it's better for you find the dealer or service center to solve this problem.
But, you can try remove the battery off from the camera, and let the camera without it for about 2 hours, then try put it on again, maybe this trick can help you!!!
Dec 09, 2009 | Nikon COOLPIX L12 Digital Camera
My camera nikon coolpix l12 keeps saying lens error,what should i do
This is a serious problem with Coolpix cameras. If it is still under warranty then take it to a warranty repair facility for Nikon.
If it is not under warranty you could try removing the battery for a few minutes, put it back in and try the camera again. As a last resort before tossing the camera out.....CAUTION DOING THE FOLLOWING MAY RESULT IN PERMANENT DAMAGE TO YOUR CAMERA, DO THESE AT YOUR OWN RISK.... Other remedies that may work would be to gently tap on the sides of the camera to see if you lens may be stuck in a certain position. Or, you could gently and slightly twist the lens back and forth.... VERY GENTLY though. This may free up the lens and allow it to work.
I hope some of this works for you and good luck.
Nov 14, 2009 | Nikon COOLPIX L12 Digital Camera
TURN ON CAMERA THE LENS GOES IN AND OUT JUST A LITTLE THEN SAYS LENS ERROR
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 21, 2009 | Nikon COOLPIX L18 Digital Camera
Lens Error, Restart
Nikon System error help????
Sep 05, 2008 | Nikon COOLPIX L12 Digital Camera
Nikon coolpix l2
I had this issue and I read on the net to hold the lens down on a table of some sort and apply slight pressure while pressing the power button, it should go right back in, It did for me!
Jul 29, 2008 | Nikon COOLPIX L12 Digital Camera
Nikon coolpix l12 lens error
Dear All, Looking at other threads this seems a standard fault for many brands. I know the dreaded 'lens error' is a recognised Nikon fault.
I had the same problem with a Nikon Coolpix L1; lens would shuttle in and out rather woriedly and then get stage fright and freeze, hiding behind a lens error tag.
The solution came from a similar site to this and listed at least ten happy punters who tried it and found it worked, so, brace yerselfs....
Put a paperback book on decent sort of a table and slam the flat base of the camera down onto it as hard as you dare. If you slam and hold firm to the book it seems to give better shock without having to belt the poor thing to hell.
Worked first time for me. Not a cure, though. You'll have to repeat it every few months perhaps.
I suppose your camera may explode during the process; I decided mine was unusable as it was and so I'd nothing to lose.
If you break your wrist change to the other hand and don't slam so hard this time!!!
Before that I found some correlation between battery type, charge and lens function but the book bash was an instant cure.
Do let me know of any success
Apr 12, 2008 | Nikon COOLPIX L12 Digital Camera
mine has that too....urgh i need to take pics cuz im going on vacation too....joy
Dec 31, 2007 | Nikon COOLPIX S9 Digital Camera
Cameras Logo
91 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
