Question about HP Designjet T1100ps Printer
Tengo un problema de erorr con la maquina t1100 hp cuyo error es 02.1:10 ya lo reseteie
2 Suggested Answers
  • 304 Answers
SOURCE: tengo un problema con la
49.XXXXX ERROR To continue turn off then on
A critical firmware error has occurred.
This type of error can be caused by invalid
print commands, corrupt data, or invalid
operations.
In some instances, electrical noise in the
cable can corrupt data during transmission
to the MFP. Other causes include poorquality
parallel cables, poor connections, or
specific software programs.
Sometimes, the formatter itself is at fault,
which is usually indicated by a 79 ERROR
message.
Follow this:
1 Turn the MFP off, and then turn the MFP on.
2 Upgrade the firmware.
3 Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
4 If the message persists when using different software programs and attempting specific print jobs,disconnect all of the cables that connect the MFP to the network or a computer.
5 Turn the MFP off.
6 Remove all DIMMs and flash-memory cards. Do not remove the firmware memory card that is in slot 1.
7 Remove all of the EIO devices.
8 Turn the MFP on.
9 If the error message disappears, reinstall each DIMM, flash-memory card, and EIO device individually, making sure to turn the MFP power off and then on again as you install each device.
10 Replace the component that caused the error message.
11 If the error persists, replace the formatter.
Posted on Jul 14, 2011
Mi MP828-8G DEJO DE FUNCIONAR A UNOS DIAS DE COMPRARLO
YO TAMBIEN TENGO UN PROBLEMA CON EL MISMO REPRODUCTOR NADA MAS QUE ES CON LA REPRODUCCION ALETORIA E IGUAL LO COMPRE EN COOPEL, ME LO CAMBIARON PERO SALIO IGUAL Y NO ME PUEDO COMUNICAR CON EL PROVEDOR, YA LO SOLUSIONASTE TU PROBLEMA?
May 31, 2012 | Coby MP828 MP3 Player
Tengo problemas con un Multifuncional HP Laserjet M1522, por alguna razon empezo marcar ERROR 5 Y NO PUDO INICIALIZARSE el SCANNER , Funciona como impresora pero no como copiadora o Scaner, , parpadea la...
59c05df4-3e41-4402-8674-16fa865682b6.jpg1e27574a-853d-43f0-83e9-639f0eb8015f.jpg6f9cb0d0-efc0-4725-b485-113c15667e78.jpg639e37f6-dbca-4b87-baf4-9919d68a26d4.jpgf319f64c-35bb-4a4d-b11b-3637a94260fd.jpgdf4c7415-80c2-478b-9083-7ef214ae9172.jpg027f0e9b-f662-4bc9-916c-d62c423d9e73.jpga1eea8bc-2311-4ede-b6b1-2b036b38dc64.jpg7ada6481-ced7-4dab-b710-09760d6b9498.jpg04f42b95-4eec-4796-8556-1ef7ab6cddbe.jpgHola amigos, tambien tengo este problema con una impresora, reinstale el firmware y no funciono, lo que note es que el motor estaba quemado, lo desarme y lo rebobine, compre el alambre me parece que fue calibre 33, aprox 25 mts, 260 vueltas con una resistencia de 10ohms por bobina. bueno despues de esto lo monte y funciono un poco mejor. pero al parecer es la tajeta logica pregunte a un proveedor de hp y su valor es de aprox 3000 pesos mx, lo que hice es hacerle un agujero al escaner.
Detalles.
viendo de frente el escaner del lado izquierdo le hice un agujero de 3mm. y le puse un cincho largo(pueden usar algun desarmador, el cincho se lo puse doble para que no se doblara, el cincho debe entrar con facilidad pero no muy olgado para que no se doble, al introducirlo no es necesario sacarlo ya que el carro lo sacar, es por eso que no debe quedar apretado). esto me permite mover el carro del escaner a lo posicion "0". posicion de partida y hubicacion de la banda indicadora(Empujarlo unos 3 cm aprox, despues solo se calibra).
La finalidad de esto es de manera manual regresar el carro, se apaga y se vuelve a encender y listo. funciona nuevamente.
Este error me aparece despues de haber utilizado el ADF, el cual el carro se mueve al lado izquierdo para poder escanear automaticamente los documentos. posteriormente no puede regresar.
Aqui pues es donde le podemos ayudar a regresar a su posicion original.
Espero que les ayude en algo.
Aug 29, 2010 | HP LaserJet M1522nf Multifunction Printer...
Tengo una gran cherokee 200 limited 4.7 de 8 cilindros; el preblema es de que se para, se apaga continuaonsejo con mayor frecuencia en la ciudad y un poco menos en carretera pero sigue sin poder usarse...
Hola, al parecer tienes problemas con el idle. Revisa si el vehiculo tiene la lampara de "Check Engine" encendida, en cuyo caso puedes llevarlo a "Advanced Auto Parts", donde pueden leer gratis el codigo de la falla, y podras saber con mas precision cual es le problema del Jeep. Tambien seria buena idea que lo llevaras a hacerle una sincronizacion completa, y haz que le revisen la manguera de vacio.
Aug 26, 2010 | 2000 Jeep Grand Cherokee
Tengo problema con impresora mfc210c en la pantalla dice eror36
El error 36 es cuando el Purge unit de la maquina esta lleno, hablando claro es una esponga que recoje el residuo de tinta y es contabilizado por la maquina, ella asume que ya esta lleno y nesecitas remplazarlo.... en este caso nesecitas visitar un dealer brother o taller.... www.brother.com para mas inf. sobre un dealer autorizado...
Oct 03, 2009 | Brother MFC 210C All-In-One InkJet Printer
Problemas de transmision automatica
hola que tal, tengo un saab 9000 1988 y tengo problemas con la transmicion aveses me hace los cambios y abeses no, si abansa para atras y para adelante pero me abienta los cambios cada que quiere,,, alguin tiene idea de que pueda ser?? nesesito ayuda ya estoy desesperado...
Aug 02, 2009 | 2001 Hyundai Accent
Hola , necesito saber si puedo cambiar toda la maquina, excepto el DD y dejar este mismo como master, tengo programas que me costaria mucho conseguir e instalar de nuevo gracias
Muchas Gracias COnstantin, quizas me expresé mal, mira mi problema es que el pc, excepto el disco nos quedó chico, es decir, quiero cambiarlo por una maquina mas nueva core duo por ej, por ende con distinta placa, y el DD tiene toda la informacion y programass con licencia que necesito, entonces necesariamente tiene que quedar como master, me indicaba un tecnico que los driver de la placa podriasn darme problemas, si es así y tengo los drives de la maquina nueva ( placa) no debiera tener problemas?
agradeceré tu respuesta
gracias
Jun 23, 2009 | MSI PM8PM-V Motherboard
Parpadean los dos botones el de el bote y la de la tinta
alex, te tengo malas noticias yo tambien trabajo con estas impresoras llevo 4 dañadas de igual manera, la epson en estados unidos te la cambia antes del año de garantia, es de pensar que seben que tiene su defecto que parece ser no tiene remedio, si llegas a encontara el reseteador me lo pasas yo hare igual contigo.
Mar 23, 2009 | Epson Stylus 1400 InkJet Photo Printer
Problema en el ps2
Amigo, creo que solamente se dasabilita eso por el jumper, pero la pregunta es, el board sin teclado conectado funciona, o sea despierta, si es asi, conecta el teclado USB cuando la maquina este funcionando, con el sistema operativo (windows, linux, o el que sea) , si no arranca, puede ser problemas de memoria, prueba cambiarlas y me dices, un saludo Marlon de la Rosa
Feb 01, 2009 | AOpen MX4LS (91.88Q10.001) Motherboard
Call for service CD4 en estudio 650
CD4 indicates full toner bag, need to be disposed...
Mar 25, 2008 | Toshiba E-STUDIO 650 Copier
HP Designjet T1100ps Printer Logo
175 people viewed this question
Seeker5211
Seeker5211
