It is nothing to do with the extension lead you are using, sounds more like a board problem to me, or another fault causing the lights to flash.
Posted on Jan 03, 2011
Mar 16, 2016 | Dishwashers
Nov 22, 2014 | Hotpoint Washing Machines
Jun 04, 2012 | Dishwashers
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU make sure its securely seated and has thermal grease
hope it helps
Apr 17, 2012 | Dell Dimension E520 PC Desktop
Aug 10, 2011 | Washing Machines
Test your PSU or replace it if your power supply units fan
is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or
to shutdown or fail to detect/ boot up a computer hard drive
the leads from your
"((motherboard to your hard drive))" make sure they have a secure connection and
will end up with a computer error hope this helps
Apr 22, 2011 | E-Machines Emachine T2865 Power Supply...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help
don
Feb 20, 2011 | ViewSonic (A-AD-0114-0011) Power Supply
One bad lead can cause a computer to fail to detect a hard drive continue on a cycle or to shutdown
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
Dec 21, 2010 | OCZ ModXStream (OCZ780MXS) 780-Watt Power...
Aug 13, 2010 | Dell (E210882) Motherboard
Mar 09, 2010 | Kenmore Dishwashers
98 people viewed this question
