Need new bulb for old slide projector...bulb type is DAK 500 watts - 120 V...was Sylvania Projector Lamp Blue Top. Is there anything available to replace? Thank you. Linda
  • 613 Answers
The only place to get it is online. I used this link from bulbs.com
http://www.bulbs.com/eSpec.aspx?ID=12053&Ref=Light+Bulbs%2c+Ballasts%2c+Fixtures+and+More&RefId=0
Posted on Jan 03, 2011
Can we still buy a bulb for an Agfacolor 50 projector?
Most bulbs (regardless of vintage) can usually be found at a number of places: you can also try a retail chain called "Batteries PLUS Bulbs". The 3-letter ANSI code that identifies the lamp (can be found on the top of the old lamp, the base of the lamp or in the projector's manual) will make the search simpler. I just did a quick search on "Osram 64610" and found the code to be "HLX", 50 watt, 12 volt. Found a few on Amazon for under $4 each. Happy Hunting !!
Nov 19, 2014 | Office Equipment & Supplies
My slide projector light won't come on. Every thing else works
Check the base where the bulb connects, pins get bent and don't connect to bulb at times
Nov 18, 2014 | Kodak CAROUSEL 650H ELH Light Bulb Lamp...
My argus 300 projector bulb blew new one won't work
yes could have been a power surge at the time, or fan cooler packed it in, the internal housing inside the Projector would have been too hot with the bulb inside it cooling down without the fan, i would double check all parts near the lamp housing and check to see they have not melted or burnt, also worth checking the fuse as well should be a T-250 Fuse bulb
Apr 23, 2017 | Argus Vintage Cameras Inc Projector Model...
Can I still buy a new 150watt bulb for an old Elmo Slide Projector CV and CS
never tried them personally but you could try
http://www.bulb-source.com
Jan 23, 2013 | Elmo Projectors Office Equipment &...
Need relacement buld for Brownie Movie Projector Model 1, bulb 300-watt, 120-volt,T81/2. S.C. bayonet base, C-13D projection lamp
Hello
You haven't specified anything about your projector or other detalis about it. jsut get into this link, and see whether the lamp you want is available there or not. You have to search with its number. It will have a model number on it. OK
http://www.visualapex.com/accessories/lamp-projection-tv.asp?MFR=DNGO
Dec 13, 2011 | Office Equipment & Supplies
I am looking for a replacement bulb for a Kodak carousel projector model # 650H where can I find one
The 650H uses a 300 watt, 120 volt lamp with an ANSI code of "ELH". You can order "ELH" lamps from Bulbman (www.bulbman.com).
Aug 08, 2010 | Kodak Office Equipment & Supplies
Light won't come on, replaced old light bulb.
First, check to see if the lamp lights at all (spill light coming out of the projector near the fan). If it does, then the problem could be just the "dark shutter" not opening. If the lamp does not light, it could be a couple of things: it could be the lamp thermal fuse has opened or it could be a bad lamp socket.
Sounds like you need to seek out a factory-trained repair dealer for this one, to narrow down the possibilities!
Apr 20, 2009 | Kodak Carousel 5600 Slide Projector
KodaK EKTAGRAPHIC MODEL E2 SLIDE PROJECTOR
You can use an ENH lamp which is 250 watts. it costs more (shop around- margins are high on lamps) but lasts an average of 175 hours vs the 300 watt ELH lamp at 35 hours.
You can also get ELH and ENH lamps from Wiko and Fuji in a "-5" version, ie ELH-5. It's built for 125 volts rather than the typical actual house voltage of 110-120 v. This allows them to burn much longer. There is a marginal lowering of light output in these forms.
Nov 25, 2007 | Office Equipment & Supplies
Televison & Video Logo
90 people viewed this question
Top Televison & Video Experts
Electro Med Services...
