Question about Hunter Fan Company 5/1/1 Programmable Thermostat
I WENT TO INSTALL MY FATHER PROGRAMABLE THERMOSTATE AND IT DID NOT WORK SO I WENT TO BUT ON THE ONE THAT CAME WITH THE HOUSE TOTALINE MODEL P4740100. AN IT DOES NOT WORK IT HAS NO POWER I PUT THE WIRES ON JUST HOW I HAD TAKEN THEM OFF.
    Problem Solver:
  • 5 Answers
Did you turn power off to unit before either attempt? if not you may have burnt something up.
Posted on Jul 11, 2008
How to I control this ridiculous thermostat (Totaline P310-0210) Just moved into this house and no manual, if I press buttons it says stage 1 or stage 2, I/m freezing...someone help!!
Hello Stephanie Sakata,
I found 2 (two) "TOTALINE" manuals...
These little beauties all work pretty much the same...
Put the slide switch in HEAT MODE...
Push the "HOLD".. (which keeps any/all
clocks/gadgets and BACK-SETS off)...
and ADJUST THE TEMPERATURE where you want it...
ELSE...
Read these manuals (
close)...
No exact matches found Try these results
Carnac the Magnificent
Dec 13, 2017 | Heating & Cooling
Thermostat Totaline P7470100
It's probably the liquid crystal has a crack and is flowing inside the glass. It can only be repaired with a new display.
Why not contact Totaline directly and see what they can offer?
Contact Us Totaline
Jul 21, 2016 | Heating & Cooling
How do I get the thermostate out of the Hold mode?
[PDF]Troubleshooting Common Thermostat Problems - Totaline
https://www.totaline.com/dl/troubleshooting_signature_star.pdf
When the temperature limit is exceeded, the furnace shuts off the burners ... buttonthermostats, hold Mode and Fan (or Mode and Override) for SEVEN seconds.
Sep 25, 2015 | Heating & Cooling
Totaline Thermostate P274-1100 works fine when following programming but when I adjust the temperature manually it will start the furnace and after a few minutes the screen displays E2 error, blanks out,...
E2 is the error code for low line voltage. I would think that this is a erroneous code witch would indicate that the thermostat is defective. do you know if this is true line voltage 120v or transformer voltage 24v?
Mar 05, 2014 | Carrier Totaline P291-1003 Capacitor 10mfd...
I have no idea how to use my totaline digital thermostat,
Totaline is a brand name of the Carrier Corporation. Go on www.totaline.com and research the model of your thermostat. User manuals are available.
Nov 11, 2013 | Heating & Cooling
I am a service technician trying to install a Totaline p474-1050 stat to work for one stage heat gas one stage cool.. I do not have the operating manual just installation... In the installation manual I...
Dear friend, don't worry! I encourage you.
You can download freely from:
www.totaline.com/.../P374-0431ThermostatRemoteControlandReceiverOwner'sManual.pdf -
Plz reply, if you satisfied.
Dec 29, 2010 | Heating & Cooling
How to change out thermostat in 1991 buck centry 3300
your thermostate is probably on the block sideways in whitch case you need to remove the air filter outr of your way and loosen the clamp on the thermostate housing. from there take out the 3 bolts holding the thermostat housing in place and remove it. Caution water/antifreeze will come out. take the thermostate out watching where the gasket has been placed and install the new one after cleaning the suface of the old gasket. sometimes it is good to use indian head gasket sealer. there will be 2 bolts on top and 1 bolt on the bottom under the housing. install the new thermostate tightn the hose replace your filter and fill the over flow resivor only to the point on COLD MAX. take the cap off the radiator start the car wait for the thermostate to open and fill the raditor the rest the way up. if it starts to boil over just shut the car off and let it cool than add more water *** needed...
Aug 01, 2008 | 1991 Buick Century
Aprilaire 110
Modle 110 has a relay in it see if it is stuck.Hope this helps
Nov 05, 2007 | Aprilaire 600 Humidifier
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
178 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
