Question about Canon Cameras
Canon PowerShot A430 lens shutter won't close
I HAVE CANON power short A-430 digicam i want to know that can i use a external flash to it?if yes how?& where to get it?
Posted on Oct 31, 2008
I have a canon powershot a430. When I am taking pictures in daylight all pictures are heavly over exposed, Si I cant take pictures but the lest is ok because I can take his res video of 640x480 without...
I do not know the solution Yet, I have the same problem on a canon A430 and a canon A460 ,after 1.5 Years of use,very strange they are like time-bombs
I ordered the flex cable of the shutter unit,but it is not arrived,
I will let you know the results
Dec 30, 2010 | Canon PowerShot A430 Digital Camera
Horizontal white lines on blurry still pictures - after 2 years. But the video is working properly.
Dear Friend,
I had also the same problem with my Canon A430. Mainly this problem is due to stuck of the camera shutter, always in open mode, images are overexposed due to this.
I had the problem with lens flex cable, which was partially damaged due to movement of lens and one coil was not working, due to this one shutter was not working and remains always in open mode. There are two coils, which operates the 2 shutters. I purchased the lens flex cable from ebay and replaced it, now it is working fine. Your problem may be the same.
Nov 03, 2010 | Canon PowerShot A430 Digital Camera
My canon powershot a430 has always given me beautiful pics! I love it. but now I can only take pics inside. when I take pictures outdoors they come out white. what can I do to fix this problem?
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. By the way, recommend trying the pencil tapping method described in this article for a stuck "open" shutter.
Jul 30, 2010 | Canon PowerShot A430 Digital Camera
Indoor pictures are fine; however, when I take a picture outside, it is "white." Have I accidently changed a setting? Thanks for your help.
First make sure your mode selector dial is set to the red camera WITHOUT an M next to it (ie it's in Auto and not Manual mode). If so...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Now the A430 is not capable of taking 15 second exposures as recommended for the fix. Instead try setting the camera to manual mode, turn off the flash, got to a darkened room, and take a picture. Open the battery door while the red and yellow light are flashing. If after many tries this does not work, then consider trying Fix #5a on the site. But do so with the camera turned off and the lens retracted to lessen the chance of damaging the lens mechanism.
Jul 05, 2009 | Canon PowerShot A430 Digital Camera
I am using canon A430 for 1 yrs bur from bfore 2 mnths when i image on day time the image becomes too bright and when i take at in light i comes parallel lines.i am beliving that u will suerly solve my...
First make sure you are taking pictures in auto, and not in manual (make sure the mode selector dial is not on the little red camera with an M). If it's not...
Now the A430 is not capable of taking 15 second exposures as recommended for the fix. Instead try setting the camera to manual mode, turn off the flash, got to a darkened room, and take a picture. Open the battery door while the red and yellow light are flashing. Repeat as the fix recommends, but please note that there may be only a small hope that this will work as the shutter may be stuck in the open position. This is harder to get unstuck than a closed shutter.
If the above doesn't work, consider attempting Fix 5a listed on the web page. There is some risk of damaging your camera with this fix, that's why I hesitate to recommend it until last.
Jul 04, 2009 | Canon PowerShot A430 Digital Camera
Canon PowerShot A430 won´t start
get a bucket full of water, with a little bit of dreft. gently wash your camera; if this does not work, call thomas the camera-repair guy: he has 5 years of online-camera-repair-experience.
Aug 28, 2008 | Canon PowerShot A430 Digital Camera
Image too bright plus the white lines
Hi!
I had a similar problem with my powershot A430 recently. I took it to a canon service center and they identified the problem as "shutter unit problem". My cam was under warranty so they fixed it for free and also replaced my lens (even though i didnt ask for it!). :-)
Take your cam to canon; they will fix it. All the best!
-Aashish.
Aug 04, 2008 | Canon PowerShot A430 Digital Camera
Lens error
The lens on my canon camera power shot A430 wont open and when I try to start it is says lens error restart the camera
Cameras Logo
141 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
