Question about LG LRFD22850 Bottom Freezer Refrigerator French Door
Not working no cooling or freezing. digital numbers flash and cycle. any help tp properly reset?
    Problem Solver:
  • 17 Answers
Pleas replace freezer thermistor
Posted on Jan 03, 2011
  • ravespanier Jan 04, 2011
    unplugged for 30 minutes, then plugged back in. all good now.
Fridge won't cool but freezer working fine
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 31, 2011 | Refrigerators
Frezzer works but not refrigerator refer section does not get cold but frezer section works
FREEZER WORKS FINE FRIDGE NOT WORKING WHATS WRONG HOW DO I FIX IT
Oct 28, 2011 | Refrigerators
Refrigerator is not cooling
Oct 23, 2011 | Refrigerators
My amana refrigerator is not cooling, freezer is working
Oct 22, 2011 | Amana ARB2217CSR Bottom Freezer...
My freezer is working but the refrigeration part is not cooling enough
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start.In your case freezer is cooling, then freezing, but its not defrosting.Thats why fridge section is not cooling.------- Click this link below and follow the troubleshooting:---- http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html ----------- This will help.Thanks.Helpmech/.
Aug 19, 2011 | Amana ARB1917C Bottom Freezer Refrigerator
Fridge is not cooling. lights are working. freeer is working
Jul 24, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
FREEZER WORKING FRIDGE NOT COOLING
Jul 20, 2011 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
I cannot locate my owners manual for my Imperial upright commercial freezer. I need to know how to defrost it
Hi the following should tell you all the info about the controller
Directions for Accessing and Setting G3 Series Digital Controllers
Changing the Temperature
Instructions for changing the desired temperature
1) First, press set for 1 second
The current set value will begin flashing after a few moments
2) Second, increase or decrease the temperature value by using the up or down icons
3) Lastly, press set to confirm the new value
Manually Setting Defrost
Instructions for manually setting automatic defrost
1) Press down the snowflake icon for more than three seconds
note that defrost will only begin if the temperature inside is equal to or less than 45
degree F.
2) Defrost will last about 25 minutes and then return to normal cooling or freezing
cycles.
Using Flash Cooling or Freezing
Instructions for Using the Flash Cooling or Freezing command
1) First, press the up and down icons together for more than 3 seconds
2) The refrigeration unit will immediately begin cycling to quickly reach the desired
temperature set point.
3) ** Flash Cooling/Freezing Option must be first set on the Configuration Parameters
Menu: Go to CC (continuous cycle duration) and enter a value. The value entered will
be the amount of time (in hours) the Compressor will run continuously to pull the
temperature down. Note: Flash Cooling may go below the temperature set point.
Eg. CC = 2 = 2 hours of Flash Cooling/Freezing.
Accessing & Setting Configuration Parameters
Instructions for Accessing & Setting Configuration Parameters
1) First, press set for 3 seconds, the display will show PS, then press set again.
2) Next, enter the password #22 to go the menu, press set.
3) You can scroll within the menu by pressing the up or down icon.
4) Go to the Carel controller detailed menu chart for specific controller settings. Click
Here.
5) To change the values, go to the menu listings ( C0, C1, D0, D1, F0, F1 etc), press
Set, the up or down icon, then Set again to complete the changes.
6) Finally, to Save all the changes made in the Menu, press and hold Set for 3 seconds.
Note: One of the parameter menu listings must be accessed to Save properly by
pressing set for 3 seconds. Saving by pressing Set for 3 seconds outside of the
parameter menu listings (ie, CO, C1, DO, D1, etc) will not save the changes.
7) If you do not want to Save the changes made, do not press the buttons for 60 secs
Regards
Gordon
Apr 22, 2011 | Migali Imperial Series Aluminum Reach In...
Samsung side by side
you can reset the fridge by pushing "Power Freeze" and "Power cool" at the same time
it worked with my fridge Samsung RS21DAMS which stopped after a power cut and was also flashing at the digit of the fridge temp display
Mar 28, 2008 | Refrigerators
LG LRFD22850 Bottom Freezer Refrigerator French Door Logo
87 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
