Question about Cobra 19 Ultra II CB Radio
Audio transmission trouble - Cobra 19 Ultra II CB Radio
  • 391 Answers
Hello please check mic wireing as it enters the radio could have a short there also open mic and get some switch oil spray lightly into the switch
Posted on Mar 29, 2011
Gears slip
Automatic Transmission Slipping
www.aa1car.com/library/transmission_slipping.htm
Transmission slipping may be caused by several things: ... there must be enough fluid to generate the internal pressure required to engage the various gears.
Top 10 Signs of Transmission Trouble - HowStuffWorks
auto.howstuffworks.com/under-the.../5-signs-transmission-trouble.htm
It may happen when trying to get into first gear from a stop, or at any point up and down the assorted gears. Common causes include low transmission fluid, ...
10 Most Common Transmission Problems
www.transmissionrepaircostguide.com/10-common-transmission-proble...
A clunking sounds when you shift gears almost always lies within a .... If the transmission is spontaneously slipping in an out of gear (or simply popping into ...
Transmission Slipping - Transmission Repair Guy
Jan 01, 2016 | Cars & Trucks
Where is the transmission warning light in the display
In most vehicle, Transmission warning light incorporated in Check Engine light (ie, when you pull check engine light codes, transmission trouble code will be among it, if there were any), other case, its in your PRNDL indicator light (ie. PRNDL light will blink when transmission has problem), and in another case, you need to have a special scaner that capable of pulling transmission trouble code. I hope it helps :)
Dec 25, 2014 | Cars & Trucks
2003 sable how to adjust transmission kick down cable
What do you mean by the kick down cable? Are you having trouble with the transmission during shifting? If that is the case, you may be having trouble with the clutch. The gears might be having trouble transitioning.
Elisa Jed ' http://www.nytransmission.com/transmission-service.html
May 17, 2014 | 1997 Mercury Sable
Transmission
check the fluid level in the gear box. Too much and not enough will cause overheating. have a pressure test done on the gear box to check for internal problems . Change the transmission fluid. . Have the bands and clutches adjusted to ensure that they are not slipping. If you are pulling trailers /caravans then the weight and speed will be factors that overheat the transmission oil. Run fault codes to check for sensors solenoids and servo faults.
Dec 10, 2013 | Cars & Trucks
Cadillac escalade transmission problem TFP switch trouble code and how to fix the delay shifting my car is cadillac escalde 2008
Transmission fluid pressure switches, i would say you have internal transmission problems, weak pump or internal leakage but to have four bad pressure switches is very very unheard off, i would have a transmission shop check it and maybe do a pressure test and leak test. it sounds like it may be time for a rebuild on that transmission.
Dec 25, 2012 | Cadillac Escalade Cars & Trucks
HAVING TRANSMISSION TROUBLE. IT WON'T GO INTO REVERSE
Hi John:
I would first look at the automatic transmission fluid level and make sure it is to the full line.
Dec 17, 2011 | 1995 Plymouth Voyager
P01529 trouble code
Per Chilton's Manual:
P1529 refers to the TCM (Transmission Control Module)
Trouble Code Conditions:
Engine started, engine running, and the PCM did not receive the Customer Request Snapshot Data (MIL and Freeze Frame Data) as requested from the Transmission Control Module (TCM).
Possible Causes:
  • Transmission control module error
  • Check for trouble codes in the transmission control module
It may merely be an isolated incident whereby having the code cleared (some auto parts stores will do a free obdII test and clear most codes) will solve the problem. Otherwise, you may have a bad speed sensor that is throwing the code.
Sep 08, 2011 | 2001 Hyundai Santa Fe
Got 2005 dodge neon 2.0 engine code 700 and 732 what does this mean
700=TRANSMISSION CONTROL SYSTEM, NEED TO READ TRANSMISSION DTC's ON THE DRBIII(R)
732= TRANSMISSION.....POSSIBLE CAUSES----RELATED DTC'S PRESENT, TRANSMISSION SOLENOID/PRESSURE SWITCH ASSEMBLY, INTERNAL TRANSMISSION, INTERMITTENT GEAR RATIO ERRORS..
Hope this helps ??
Jul 02, 2011 | 2005 Dodge Neon
Ford trauras trouble code 732 - was told transmission code 732 was being produced, what does a code 732 say?
P0732 FORD - Incorrect Second Gear Ratio
Transmission in second gear and the ECM detected an incorrect gear ration. This diagnosis monitors actual gear position by checking the torque converter slip ratio calculated by Transmission Control Module (TCM) as follows:
Torque converter slip ratio = A x C/B
A: Output shaft revolution signal from revolution sensor
B: Engine speed signal from Engine Control Module (ECM)
C: Gear ratio determined as gear position which TCM supposes
If the actual gear position is higher than the position (2nd) supposed by TCM, the slip ratio will be more than normal. In case the ratio exceeds the specified value, TCM judges this diagnosis malfunction.
Symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Incorrect transmission shifting
Possible causes
- Low transmission fluid level
- Dirty transmission fluid
- Shift solenoids
- Transmission mechanical problems
- Transmission hydraulic control circuit
Tech notes
Start by inspecting the transmission fluid level and condition, and change fluid if necessary.
Hope helps.
Apr 26, 2011 | Ford Taurus X Cars & Trucks
Radio Communications Logo
46 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
