Question about KitchenAid KSM150PS Artisan Series Stand Mixer
My KitchenAid stand mixer is making a grinding noise, it still turns but starting making a noise.
ricardok45
  • 135 Answers
SOURCE: Kitchenaid mixer makes a clanging noise
Hi. If your mixer is under warranty, call Kitchenaid. They are very good at replacing mixers under warranty.
If you are out of warranty, this is where the fun begins, NOT!
Remove the silver band from around the top of mixer. Remove 4 screws that secure the top cover, remove cover and at the front top of the machine locate the transmission cover. Inspect this cover carefully for cracks. If you find cracks in it...You have just discovered Kitchenaid's dirty little secret. A cheap plastic transmission housing! The failure of this cheap part is the cause of all of the rest of the damage inside the mixer, which may include a destroyed worm gear and shaft, destroyed bearings and their seats. You're not alone. I estimate that thousands of these plastic parts have failed causing great damage to the rest of the mixer
Kitchenaid's replacement housing is made out of metal. If you feel up to the task of repairing the mixer yourself goto the Kitchenaid website and do a search for the parts catalog for your mixer model, these will assist you with disassembly, reassembly and parts ordering.
If you're not up to the task, take it to an authorized repair place once you have put the cover back on.
Even if you're out of warranty, you may be able to have Kitchenaid pay for the replacement parts, they did for my mixer. Be persistent with them and try to get to a manager with your complaint. This cheap piece of plastic has no business being installed on a high-priced machine.
If this solution has assisted you, please rate it. ricardok45
Posted on Mar 20, 2009
  • 274 Answers
SOURCE: Grinding Noise
If it's metallic sound you are loosing teeth on a gear or two.  This is caused by lack of lubricant or simply fatigue of the material of the gears.  Don't use it, you can get metal flakes in your food.
Take it in to a repair shop and have it fixed.  The money spent is well worth it because if done correctly will last another 12 years.
Posted on Oct 23, 2007
  • 45 Answers
SOURCE: Kitcchen Aid mixer making a grinding noise
common problem. Worm gear & bracket #PS734273 about $36.
Posted on Nov 05, 2007
  • 145 Answers
SOURCE: KitchenAid 600, Stand Mixer -
If the beater is grinding when it meets resistance, it generally indicates that an internal gear has broken or been stripped.
With the Professional 600 stand mixer, up to 14 cups of white flour or only 8 cups of any flour are recommended at one time. Speed 2 is the only speed that should be used for bread dough and it should never be kneaded for longer than 7 minutes. Failure to do any of these things make cause problems for the mixer motor.
If you are interested in self-repair, I recommend mendingshed.com. They have internal parts available to order and also have a .pdf file for the Kitchenaid Mixer Service Manual.
If you are interested in a repair facility, please visit the following link:
http://caservice.kitchenaid.com/
This is a listing of certified repair locations.
Also, if the mixer is less than a year old, Kitchenaid may replace it under their 1 Year Manufacturer's Warranty. I would recommend calling their customer service. Their toll-free telephone number is:
1.800.541.6390
Posted on Jul 16, 2009
  • 61 Answers
SOURCE: My KitchenAid mixer will not turn it makes a loud noise.
buy a new mixer unless you are able to replace the motor because it is most likely burnt up because we have gone through 6 mixers and the motor slows down and eventually stops and just buzzes
Posted on Oct 14, 2009
Makes a grinding noise at higher speeds
If it is leaking you are going to have to go inside the gearbox to change the grease so whatever is wrong inside may become obvious when you take it apart. Remove accessory cap from the front and look for any dryish grindings inside there.
Oct 17, 2014 | KitchenAid Kitchen Aid KSM150 Artisan 5...
On low it makes a really loud grinding noise the higher you turn up the speed the slower it becomes.
It sounds like the Worm Gear is going out. The faster the motor runs,
the more damages the Center Gear is grinding away the teeth of the
Worm Gear. Things start to slow down, and eventually they will come
to a halt. It's time to replace the Worm Gear. Also make sure to use
new fresh Kitchenaid Food Grade Grease with the new replacement.
Jun 19, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Grinding noise
I needed to replace the nylon worm drive in my mixer. When I put it back together, I found that my mixer made a kind of grinding noise. The noise was due to a vibration associated with the cover for the electrical wiring in the back of the mixer. I solved my noise simply by loosening the screw to this cover. The cover is located on the back of the mixer, and the screw is on the top.
Separately, to find instructions for opening your mixer, you can go to http://neilcrockett.com/mixer.htm.
Jan 13, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
My 6qt Kitchenaid stand mixer started making a grinding noise and beater bar keeps stopping. When I put it gently with my finger, it begins turning, only to stop again and make that grinding noise. It is...
They seem to have a plastic gear built in as protection for overloading (prob). When the machine counters to much resistance that gear will strip its teeth causing the machine to not be able to turn, that it what seems to be the grinding problem. If it is not the plastic gear then it another gear that is "stripped(of its "teeth") I hope your problem is not a severe, but if your mixer is "locked up" then at least you found the problem.
Jan 12, 2010 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid KP2671 - Spaghetti cutters stopped turning. Makes loud noise.
this is common for any device that has a motor,either the gears are grinding or the motors contact brushes need replacing, it will have to be looked at to determine the exact cause
Oct 13, 2008 | KitchenAid KP2671 Professional 6 Series...
Kitchenaid 250 watts k4ss mixer
The repair manual says that the mixer can make this grinding sound at slow speed, like stir or 2. This is normal, especially until it warms up. This is the sound of the gears turning at slow speed.
Dec 13, 2007 | KitchenAid K45SS Classic Stand Mixer
The kitchenaid is making noise and moving
Sounds like the hinge pin may have slid out of half of the base..
Nov 25, 2007 | KitchenAid KSM90 Ultra Power Series Stand...
Grinding Noise
Oct 21, 2007 | KitchenAid KSM90 Ultra Power Series Stand...
Oct 21, 2007 | KitchenAid K45SS Classic Stand Mixer
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
357 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
