Question about Amana Microwave Ovens
I pulled the front panel off my Amana Radarange and accidentally pulled the primary switch (bottom switch) out of its housing; can't figure out how to get it back in place. (The switch still works.) It's a little black plastic piece about 1/2" by 1", with a small red switch protruding. Nothing is actually broken.
MicrowaveSvc
  • 9098 Answers
SOURCE: Door latches to microwave broken
I assume you're talking about the spring that keeps tension on the door hooks (latch heads, as they're called by Sharp). When you shut the door, the "hooks" are held down by this spring to actuate the door switches. To fix this, you'll have to separate the door panels. You can download the service manual from my Web site. There's a loop built into the latch head assembly and sometimes the loop breaks. If so, you can drill a tiny hold in it and reattach the spring there. There may also be a loop on the innner door panel to hold the spring. That one can break, too. If it's broken, you'll have to find a way to secure the spring to the panel. If the panel material is thick enough, a tiny screw eye could be inserted, then epoxied overnight to secure it. I've attached a diagram to this message that should help you. If that doesn't help you, I have the service manual for the R1600-series microwaves on my Web site at: http://www.microwavedisplay.com/R1610.pdf Repost if you need more help.
Posted on Nov 15, 2006
trintek
  • 111 Answers
SOURCE: Amana Radarange Microwave/Convection over the stove
what is the model number of your radarange? it should be found inside the microwave on the rim.
Posted on Nov 21, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Instruction manual for 1986 Amana Radarange microwave
I think it will use a standard generic probe for the Accu-Temp. Sorry I couldn't help. Take care.
Posted on Jan 28, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: I have an Amana Radarange
Is that model number RR-9?
You can find and order that part (# AP118264) here.
I just hope your magnetron is not blown, too. (Does it still heat?)
You can use a microwave-safe plate in the meantime.
Posted on Sep 01, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Profile Spacemaker XL1800 Microwave Model # JVM1870SF001
(I also replied via e-mail)
Sorry, but the subject lines get cut off after so many characters.
Thanks for replying.
Part # DE63-00204A looks like a valid Samsung part number but it doesn't show up anywhere, so it's likely a proprietary part made only for GE and not available separately.
You can see a helpful exploded view of this model here.
Then you can go here and enter your model number and come up with the parts list. This site has much better prices than GE.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Chances are you will end up having to but more than you want to, but not the whole door.
Posted on Sep 10, 2008
Interlock door switch
Bad secondary interlock door switch or switch mounting problem.
Nov 12, 2013 | Amana Radarange Microwave Oven
Door handle on Amana Radarange Model MVH100E1 came dissconnected at the bottom of handle. How do I reconnect it since it appears to have been riveted to the door?
I would use epoxy glue allow it to dry 24 hours for maxium bonding, clamp it in place for best results, otherwise the door would probably need to be replaced.
May 02, 2012 | Amana Radarange Microwave Oven
Me and my wife purchased an old house for rental property, while cleaning it out, i found an amana radarange from 1974. i took it home and plugged it in and it works. on the inside of the door near the...
It sounds like this is an old RR7 or RR10?
I don't know of any 'old' parts suppliers. Parts are generally available for up to ten years after manufacture. You might try ebay.... that would be my best guess..
Sep 13, 2009 | Amana Radarange Microwave Oven
I hit the lock button and it quit wrking
Hold down the "START" button for 5 seconds.
Jul 13, 2009 | Amana Radarange Microwave Oven
Help setting clock on amana radarange microwave made in 1987
press Reset, then enter in the time of day (e.g. 0807 for 8:07 am or pm doesn't matter), then press Clock button twice. hope this helps.
Mar 17, 2009 | Amana Radarange Microwave Oven
Need to change bulb inside Amana radarange RR1220
There is an access / cover panel on the back of the oven.
It's shown in the exploded view here.
Please unplug the oven from the wall first.
Then use a 1/4" nut driver or socket to remove the screw in the end of the lamp cover.
The bulb is behind the cover, and should be readily available at grocery stores, home improvement centers, hardware stores and big box stores like Wal-Mart.
Dec 01, 2008 | Amana Radarange Microwave Oven
Amana radarange microwave oven 1000 watts not heating.
The two possible causes are a faulty door switch and a bad magnatron. You can pull the top cover off of the unit and check all of the door switches (there are 2-6 of them all on a common rail, me normally closed)). If the door switches all check out, replace the magnatron, diodes, and capacitor.
Oct 27, 2008 | Amana AMV5164 Microwave Oven
Microwave Ovens Logo
160 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Steven Clarke
Steven Clarke
foster_mommy
Level 1 Expert
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
