Question about Interactive Toy Concepts Polaris Sportsman 800 Remote-Control ATV
Left front hub split and wheel cannotbe made to stay on is there any where i can purchase a new hub?
I have a 83 Bronco 351w I am doing the brakes and the passenger side rotor needs to be replaced can someone walk me through this thanks
Personally I would replace both rotors to prevent a future brake imbalance.
* chock rear wheels, raise front of vehicle and place on stands.
* remove wheels, remove brake calliper and bracket assemblies.
* remove bearing hubs from axles, via removal of bearing adjustment nut
*remove hub seals, clean and inspect bearings, repack with HT bearing grease.
* the brake rotor bolts to the rear of the hub, you will have to remove and replace rotor to hubs, make sure all bolts are thread locked with loctite 263 and tensioned to spec.
* pack hub with grease, install seals, fitt hub assembly and adjust wheel bearing preload, install new split pins.
* fitt brake calliper and brackets, fit new brake pads,
* fitt wheels lower vehicle, test brake for function
Hope this helps..
Aug 02, 2016 | Cars & Trucks
How to fit front wheel bearings Which brand to use for quality
If the car is front wheel drive a puller is required to dismantle the hub a rather involved job better left to a mechanic .If rear wheel drive do the following. ( Applies to front wheel drive also.) Chock rear wheels,loosen front wheel nuts, jack up car, fit safety stands,remove wheel , remove grease cap from axle. remove split pin or locking nut on axle ,Remove hub, with a punch drive out the grease seal ,the tapered cone bearings can now be removed, the 2 bearing cups still in the housing will have to be pressed out ,all old grease has to be cleaned out. the new cones must be repacked with high temp bearing grease . tap in the seal with the lip facing inwards , slide on the hub fit the outer cone to the axle , the spacer and nut goes on next, tighten the nut to seat the bearings , spin the hub make sure its free to spin, back off the nut one eighth of a turn fit a new split pin or lock tab. fit grease cap and road wheel.
Jul 27, 2014 | Cars & Trucks
Como puedo cambiar los sensores de la transmission de un 2002 trailblazer ls4x4
Vehicle Speed Sensor (VSS) Inside automatic transmission assembly.
Wheel Speed Sensor-LF On left front wheel hub assembly.
Wheel Speed Sensor-RF On right front wheel hub assembly.
Wheel Speed Sensor (WSS) - LR Attached to left rear wheel hub.
Wheel Speed Sensor (WSS) - RR Attached right rear wheel hub
Jul 08, 2014 | 2006 Volkswagen Jetta
How to change a front wheel bearing on a 2007 toyota tacoma 2 wheel drive pickup truck
The bearing & hub is a whole assembly for this model, start by removing the brake calipers, the removing the rotors" a couple taps with the hammer should loosen it" , after removing the rotors the hub & bearing assembly is held on by 4 #17 bolts, after you get the hud and bearing assembly off you will need a tool called a bearing split plate ,to split the hub and bearing off each other. Now you should have the new bearing assembly ,inner wheel seal, and hub set together" this is when you need a press". Press the hub onto the new bearing assembly.And thats it! Its ready to go back on the way you took it off.
Mar 02, 2013 | Cars & Trucks
2008 siverado. Front-end humming. Sounds like extremely loud tire pattern noise coming from left-front wheel area, noise stops when i turn the steering wheel to the right. replaced tire with no results.
it is your wheel bearing. the bearing is a sealed unit so you replace the hub assembly. remove wheel,caliper,brake rotor.if it is 4x4 loosen axle nut. there are three 15mm bolts on back side of spindle remove these and slide hub out replace with new one. most hubs come with new wheel speed sensor so remove harness from connectors or if no new one remove the screw holding it in place to hub and slide out.
Dec 31, 2010 | 2008 Chevrolet Silverado 1500
How do you get the wheel bearing off a 1996 saab 900
assuming its a front one disconnect lower arm by undoing ball joint bolt remove brake caliper and disc disconnect hub from strut undo driveshaft nut and remove driveshaft u then split hub by pushing centre iut with a press,once split push bearing out with press then push new bearing in and refit everything the same way u removed it
Apr 14, 2010 | 1996 Saab 900
Replace front left wheel berring on 2002 GMC Yukon
do not replace only the bearing. replace hub assembly. remove rim/tire , remove caliper, mounting plate, rotor. . un bolt hub assembly, unplug abs. remove front axle nut if 4x4. you may need to rent the axle nut remove kit and hub puller. pull out hub. drive axle reward out of hub. install new part. do not torque hub over 90lbs. check with parts sell for spec
Jan 03, 2010 | 2002 GMC Yukon XL
Changing front wheel hubs on a 2002 Toyota Solara - 4 cylinder
the rotors ? remove wheels and brake assembly and install new ones make sure to press the piston on the brake caliper or they wont go back on
Aug 24, 2009 | Toyota Solara Cars & Trucks
How to install wheel bearing in left front of the car
That will be a pressed in type of bearing. It has to be installed from rear of spindle. The bearing is in back & the hub comes through front and into bearing, which also requires press fit. You'll have to remove entire spindle/knuckle assy, and at least get it in a vise or on a bench. It can be done without a press, but has to be done carefully & patiently, because damage to new parts or hub can happen real easy if not done right. Are you equipped for the challenge?
Jan 04, 2009 | Hyundai Elantra Cars & Trucks
Interactive Toy Concepts Polaris Sportsman 800 Remote-Control ATV Logo
Top Interactive Toy Concepts Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Interactive Toy Concepts Toy Expert? Answer questions, earn points and help others
