Question about LG DU-50PX10 50 in. Plasma HDTV
I have a DU50PY10 ( 50" LG PLASMA HDTV) and the picture is fuzzy and the cable jacks do not work. I had a TV Technician look at the problem and they stated that the "Y Board" and "inuerter" board are bad. I thought it may be the plasma tube but they said they had to check those 2 boards before they could rule the problem beiong from the plasma tube. My question is: Can you find replacement "y boards" and "inuerter boards" for this TV anymore since production stopped in 2006? thakn you
SOURCE: LG "NO PICTURE" , IF FIX WILL RECUR? ,DID LG FIX DESIGN FLAW 42PC3D
I had same problem - no picture, but sound worked - LG 42PC3d - was two months past warranty, but LG agreed to fix it as a warranty call. Service guy was out within a week to replace the Z SUS(?) board. Works fine now. This must be a typical problem, as LG did fix it, even though the warranty had expired. Good luck.
Posted on Nov 15, 2008
mastertech49
  • 8 Answers
SOURCE: Black screen on HP PL4260N 42? Plasma HDTV
The problem is the "Y-SUS" board. It is inside the set on the left side with several aluminum heat sinks, under the left side brace bar. You can order this board from Union Electronics at www.ued.com .Search for part number: TNPA3243AB-PA
It lists for about 115$
Posted on Mar 20, 2009
  • 92 Answers
SOURCE: LG 50PX1D Plasma TV with dark and fuzzy picture
Z-Sustain PCB will cure it.
It is inside the TV, on the Right Hand Side.
www.chsinteractive.co.uk or Google for a replacement.
Posted on Sep 08, 2009
freetek
  • 5568 Answers
SOURCE: LG 42 Plasma has a black Fuzzy Screen when 1st turned on
Doesn't sound like a fuse-related symptom but rather the sign of a failing capacitor in the high voltage supply; when weakening, their characteristics can improve slightly with warmth but it is likely going to get worse. I don't know your set so can't say if the HV supply is integrated with the main supply or not.
Your model number is incomplete so you will need to add some characters to get the right part.
This company does offer some warranty on their items which are primarily gathered from disassembled sets but check with them:
Jimmy's Parts
If you replace the failing board, don't throw the other away, it is a repairable item if you find the right technician.
Posted on Nov 18, 2009
SOURCE: Vizio P50HDTV10A 50 in. HDTV Plasma HDTV Tuner out
The HDTV tuner is out. Analog tuner, and video inputs work fine.
TV Model P50HDTV10A
Screen Size 50 in.
TV Manufactured Date Jan 1, 2007
Part Type MAIN UNIT
Alternate Part Type SIGNAL BOARD
Part Number 3850-0042-0150(3A)
Alternate Part Number 0171-2272-2163
Posted on Dec 27, 2009
My TV doesn't have picture its fuzzy in different areas not the whole screen and makes with clicking noise when its turning on.
Invariably the HDMI cable that you are using to connect the signal is bent and pressing hard against the wall. Can you verify with other ports and other sources.
Feb 06, 2016 | LG 60PV250 60 in. Plasma HDTV
Picture is fine for about an hour then goes fuzzy
Hello Townsend, It sounds like a problem called blooming, or you are having a problem with focus control which are signs of a problem in the horizontal and high voltage section of the tv in the case of plasma TV this would be the excitation circuit. I would suggest that you take the set to a TV repair shop to effect repairs.
Sep 12, 2007 | Dell W4201C 42 in. Plasma HDTV
Fuzzy picture
There can be many reasons for this fault. A through checkup is necessary. Contact any experienced service technician. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name and model number to your device into its search box at the top right of display window. Faults and its reasons to Plasma TVs are described in detail with screen shots. http://electronicshelponline.blogspot.com/
Apr 25, 2013 | LG 50PS60 50 in. Plasma HDTV
Snowy white picture while on cable.
Maybe a tuner problem--considered hooking up whatever you use for signal to the rear av jacks? bypass the problem?
Apr 06, 2012 | LG 50PC5D Television
Just bought the Samsung 550 Plasma Hd Tv can you tell me if we just use a regular cable from the wall to the Tv will the picture quality be sort of off.. WE have an HM MI cable from the cable box to the TV...
unfortunately cable does not give you the best quality picture and "fuzziness ' is the reduced resolution being displayed on the tv.
the easy way to check the picture quality is to get a decent hd antenna and scan using it for free hdtv signals, if these are also fuzzy, on all channels then the tv has a problem but if it is only on a few lower resolution channels then its just the way it is until everyone is hd 720 or better.
Jan 31, 2010 | Samsung 50 in. Plasma TV
Sep 08, 2009 | LG 50PX1D 50 in. Plasma Television
Picture becomes fuzzy in different areas of the screen
sounds like a splitter problem try replacing splitters
Mar 24, 2009 | LG 50PX5D 50 in. Plasma HDTV
LG Plasma Problem
This could be the main drive board failed, or the plasma display backplane has a defect. These types of repairs are generaly fairly expensive.
I would be considering to get an estimate just in case it is simple fault. But, if the repair will cost more than a few hundred dollars, I would strongly suggest a new set. Also, servicing an older set is a gamble in case something else will soon fail.
Jerry G.
May 09, 2008 | LG 42PX5D 42 in. Plasma HDTV
LG DU-50PX10 50 in. Plasma HDTV Logo
76 people viewed this question
Computer Repairing
Computer Repairing
