Question about Lexmark X1240 All-In-One InkJet Printer
Color my lexmark x1240 will not print any color in the red family,i only get yellow, green, and black
  • 48 Answers
Hmm...does the test page do same thing?
Also, more printer resources are here
Posted on Aug 21, 2008
I want ti print in color only,how do i do that,?Lexmark X1240 All-In-One InkJet Printer
On your computer, with your file open (your document/picture, etc. that you wish to print), click File > Print. From Print dialog box, click Properties, Preferences, Options, or Setup (depending on the program). The Print Properties dialog box appears. From the Quality/Copies tab, make sure there is no check mark in the "Print Color images in Black and White ". Then hit OK button to save the setting. Once you print your colored document/pictures, etc, it should come out in color.
I hope this helps.
Dec 02, 2011 | Lexmark X1240 All-In-One InkJet Printer
My pictures turn red
generally this is due to your ink cartrige not having enough of the cyan or yellow to produce accurate colors. that or the print heads need to be cleaned on the cartrige. you can clean them with a cotton swab and some rubbing alcohol.
if all else fails replace yoru color cartrige with a new one.
Feb 12, 2010 | Lexmark X1240 All-In-One InkJet Printer
Wont print out document in blue print
Sorry your having this issue. Because Blue is a lite shade of Black, or a combination of red yellow and green ???? Point is even if you have only a black ink cartridge, or only color cartridge. Blue should be visiable and able to print.
Good luck, jasahasch
Aug 13, 2009 | Lexmark X1270 All-In-One InkJet Printer
Color cartridge do not want to print
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
May 28, 2009 | Lexmark X1240 All-In-One InkJet Printer
Printer not printing all colors
You must buy a new cartridge, because refilledcartridges sometimes have problems like the one you report.
Nov 28, 2008 | Lexmark X1240 All-In-One InkJet Printer
Lexmaekx1240
Even with out the Black cartridge installed the X1240 should use the color cart to make a "composite" black. I would suggest calling Technical support to troubleshoot that issue ad get you to test the cart itself
Aug 22, 2008 | Lexmark X1240 All-In-One InkJet Printer
Lexmark x1240 will not print
did you tried to set the properties to mono ?
Apr 12, 2008 | Lexmark X1240 All-In-One InkJet Printer
Lexmark 1270 only prints green!
Sounds like you're missing blue. Using the Lexmark software (maintanance section) that's on the PC, Clean the print heads. You should see all 3 colors (blue, red, yellow) and black. If not, buy a new cartridge as the head on the blue ink are clogged.
Hope that helps...
Geno
Apr 04, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X1240 All-In-One InkJet Printer Logo
113 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
