Question about GTO Aq251 Circuit Control Board / Gate Opener Operators
The aq251 board keeps going bad--no power to the motor. This is the third bord in as many months
Ge regigtor. not working
You got the wrong or a bad board. Willing to bet it's the wrong board.
Mar 13, 2013 | Refrigerators
Power Window issues on 2002 GMC Sierra
try putting some white lithium grease on the tracks
Jul 03, 2012 | GMC Vehicle Parts & Accessories
Need trojan express treadmill expert
1= adjust the reed switch, clean, and tigh the wires connector, see the diagram attached.
2=Tight the ribbon cables from keypads,+ tight the connector from display board vs lower board
3= Lube the deck belt very well, the lack of maintenance produce this effect
4= Test the input motor voltage, if there are, the motor need repair.
see the diagram , and proceed according.
May 16, 2012 | Exercise & Fitness
Clicking - Freezer section problem...
could be the bord but my bet is its the fan motor,,,it has a short in it,,,try unhooking the fan motor from the bord and switching it on, if the bord stayes switched on,,, its the fan motor faulty
Jul 10, 2010 | Hotpoint HSS25GFP Side by Side...
My ~ 3 year old GE 23' side by side keeps shutting
no ck's for the main board but is sounds like it need one / replace it as they have many updates / the newer bords are much better . mm.
Dec 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Air difusser between freezer and fridge will not stop running
When things like this happen I usually replace the main electronic circuit board which would control the motor operation timing, etc.
Nov 29, 2008 | Whirlpool Refrigerators
Roper REX4634KQ
That should be just a push to start switch. The start switch is inside the motor. When the motor turns fast enough it trips an internal switch to keep the motor running. It sounds like you have a motor on the way out.
Apr 24, 2008 | Roper REX4634KQ Electric Dryer
Door front water and ice inop
the bord is usually where the switch's are in front. There behind the push buttons. I would make sure your getting power to the bord and go from there. If you do have power there replace the bord. If not you will need to locate the tech sheet for the wireing diagram and trace the circut for the dispensor. Good luck
Jul 18, 2007 | KitchenAid Superba Architect KSCS25INSS...
GTO Aq251 Circuit Control Board / Gate Opener Operators Logo
54 people viewed this question
Top GTO Home Security Experts
Tom Chichester
Mai Lor
Clinton Daley
Clinton Daley
Are you a GTO Home Security Expert? Answer questions, earn points and help others
