Question about Garden
I believe my starter motor needs to be replaced.How can I remove it.The flywheel prevents me from pulling it out. If I remove the motor from the chassis can I take the motor to Craftsman repair center for service?
  • 2strokeguy
    2strokeguy Jan 03, 2011
    I need additional information to solve your problem. What is the brand of the engine? What is the model# & serial # of the engine? Is it a single or twin cylinder?
    Most likely the Sears service center will not work on an engine that is out of the equipment. They do offer mobile service.
  • tjackson192 Jan 03, 2011
    GT twin garden tractor model# 917.255915 engine model# 422437 Type # 0758-01.
  • 183 Answers
On your twin cylinder briggs engine, it is necessary to remove the flywheel first before removing the starter assembly. !st, remove the sheet metal covering the top of the engine. Then remove the screen covering the top of the flywheel. The larg nut that is holding on the flywheel is on very tight. You will probably need an impact tool to remove this nut and to reinstall it. Next, pry up on the flywheel on 2 sides to remove it. Be careful, it is very heavy. Now you can remove/replace the starter.
Posted on Jan 03, 2011
  • 1 more comment
    How can I prevent the flywheel from turning when I try to remove the nut? What direction do I turn the nut to remove?
  • 2strokeguy
    2strokeguy Jan 04, 2011
    Turn the nut counter-clockwise.
    Several ways to lock down the engine. 1. Use a flywheel holding tool available through any Briggs
  • 2strokeguy
    It didn't take my complete response. 1. Flywheel holder 2. Impact tool (recommended) 3. Remove the sparkplug and fill the cylinder with clean rope. Leave a tail hanging out so you can remove the rope. Rotate the flywheel (counter-clockwise) to compress the rope. Now use a long breakover handle on your socket. This nut is on very tight and will need to be tightened when complete to 150 ft/lbs.
Replaced starter not engaging to flywheel to start engine what could be problem
I need year--make--model?
Can you remove flywheel cover, where applicable, maybe you can see if starter motor is kicking out drive-gear to engage flywheel? Check the flywheel teeth.
As far as starter testing, you can usually take the starter motor off, lay it on the ground, hook up jumper cables properly from charged battery to starter motor, at the least, it should kick out the drive gear and spin. I have to talk in generalities because I don't know which vehicle you have?
Feb 05, 2018 | Cars & Trucks
One day my 1994 aspire will start fine the next it wont how can i fix this?
If I understand correctly the starter motor turns but does not cause the engine to turn over. If this is the case then the ring gear on the flywheel or flexplate is worn out, or the teeth on the starter motor are worn out. The starter gear does not engage the flywheel. With the starter removed the teeth of the flywheel can be viewed. turn the motor over by hand and look for worn spots; the gear teeth will be noticably shorter. If you find worn spots then the transmission will have to be removed to replace the ring gear. Another possibility is the starter is not pulling in correctly, thus the gears would not engage.
Nov 22, 2011 | 1994 Ford Aspire
Starter makes a screeching noise sometimes just after the motor starts
Replace the starter before it ruins the flywheel. You have a worn out drive that applies to the flywheel. Flywheels are very very hard to change, in fact you can change 10 or 15 starters in the same time changing one flywheel
Jul 24, 2011 | 1997 Buick Century
Starter spins but doesn't turn over motor is there a keyway on one of the gears that could be broke and how do I get at it?
Typically there is a piece called a one way clutch. It is bolted to the back of the flywheel. In this case the one way clutch is not grabbing the large starter gear. You will have to remove the engine side cover, pull off the flywheel, and replace the one way clutch and starter gear. Then, when the starter motor is spinning , the clutch will grab the starter gear, the motor will turn over, and hopefully start.
May 06, 2011 | kawasaki KE 125 Motorcycles
Starter spins but wont engage, could it be a fuse
HUH??? The electrical circuit is working and you think there is a blown fuse?
NO! there is a MECHANICAL problem with your starter like a broken bendix or a chewed-up flywheel. You need to remove your starter motor and inspect the teeth on your flywheel. Look through the starter hole and turn the engine by hand so you can inspect the teeth all the way around. I usually mark the flywheel with a marking pen before I start turning it so I can tell when I have gone all the way around. If the teeth are all in decent condition, replace the starter. If you find any broken/damaged teeth, you need to pull your transmission and replace the flywheel. (AND probably replace the starter anyway.)
Mar 11, 2011 | Suzuki Esteem Cars & Trucks
My b/f has a 1990 Fleetwood Cadillac...He believes the fly wheel may be broken...Where is the fly wheel and are they easy to replace?
Flywheel is between the motor and transmission the starter actually runs the flywheel to start the motor. To change it you will have to pull the transmission away from the motor to get to the bolts that hold it to the motor. Not the easiest thing to replace by any means.
Jan 05, 2011 | 1990 Cadillac Fleetwood
I have a 90 gsxr750 and it won't start. The starter turns all the gears in the case but they seem not to connect to the motor
remove flywheel special tool needed , pull starter gear out of flywheel you will find 3 rollers tensioned by thin long springs stretch springs aprox1cm longer and replace
Jul 21, 2010 | 1990 Suzuki GSX-R 750 L
REMOVING STARTER ON 1994 TOYOTA CAMRY LE (6 CYLINDER), NEED TO KNOW EXACTLY WHERE TO FIND THE STARTER AND HOW TO REMOVE IT AND REPLACE IT
The starter is found under front end.. Near where the moter meets the trani - you will see the flywheel (a big round gear) the starter connects to the flywheel to turn the motor..
Disconnect the battery..
Disconnect wires from starter..
Should be 2 bolts that hold the starter in - remove them..
The starter goes in only one way so you cant mess it up..
Rate well ;o)
Jul 22, 2009 | 1994 Toyota Camry
Starter motor turn but wont engage
It has a starter clutch on the fly wheel. You will need to remove the left side case cove to access it. You will need to pull the flywheel with a puller as the starter clutch is behind the flywheel
May 24, 2009 | 2002 Yamaha XVS 1100 Dragstar Classic
Hello Friend, I have a Dodge Caravan 1997 and in the process of changing out my water pump and timing belt. I am in the stage where I need to open the damper harmonic bolt. Which direction does this bolt...
I have managed to open the harmonic damper bolt. This bolt opens in the counter clockwise rotation. A breaker bar was used with the flywheel locked in place. In order to get to the flywheel, the starter motor was removed to get access. The manual suggest removing the bell housing plate. This takes more effort and one of side engine mount also need removal. I decided to remove the starter motor instead. In order to remove the starter motor, first remove the cables from the starter motor and three mounting bolts. Secure a rod or a screw driver between the flywheel and bell housing through a hole in the flywheel. The size of the size is about 1/2". This hole was visible when the engine is set to TDC (top dead center). There could be more than one hole but I did not try to rotate the engine to find out. Once the rod or the screw driver in place in the flywheel, use the 22mm socket head and breaker bar and undo the harmonic damper bolt counter clockwise (CCW). I believe an impact air gun could do this job as well. The spec on the bolt is 100 ft lbs torque - Hendry
Jan 13, 2009 | 1993 Dodge Caravan
Garden Logo
100 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
