I am renewing the fire bricks to a Baxi Brunell open fire. What compound is used to fill between the new fire brichs and the chimney construction.
    Problem Solver:
  • 10 Answers
In the UK they sell small tubs of "fire cement" which is a white pre-mixed cement in a tub. I'm sure that will do the trick!
Posted on Jan 03, 2011
Smoke comes out of draft vent and everywhere when starting a fire
Ugh, my husband does this... You have to start the fire so that it does burn hot enough to force the smoke up the chimney (and, yes, make sure the chimney valve is open!). To do this, keep building the fire in baby steps: light with balled up paper beneath a "teepee" of kindling and keep the door open. Once enough kindling is burning, add a couple pieces of larger wood (make sure all is very dry, especially to start) and start closing the door, but make sure the vent is open all the way. Once the wood is burning, add a couple more larger pieces and begin closing the vent - a little at a time, checking every few minutes. No, you don't have to stare at it the whole time, but keep checking. After awhile, you can fill the stove with very large pieces of wood and have the vent closed far enough to lower the flames to very small - but not to smothering totally. This is where the heat really starts and your room gets warm!
Mar 06, 2015 | Home
Even if it was a wood burning fireplace from the beginning & was converted to gas ?
Now that's a LOT of additional information. I hesitated to answer your question the way it was worded originally.... IF in fact it is a masonry chimney and originally built to burn wood, you should have a chimney sweep do a thorough inspection of the flue to ensure it is safe to use again. Flue temperatures, while burning wood, EASILY exceed 1200 degrees whereas natural gas flue temps are in the 450 degree range.
It also should have a clay tile liner and not be fabricated of brick only. The unsafe thing of an unlined brick chimney or a chimney with a severely cracked liner has to do with unburned gases condensing within the inner surfaces of the chimney. Some of those gases are moist and will condense on the inner surface and eventually have an unsafe build up that can be ignited by an oversized flame or excessive sparks causing a flue fire. During a flu fire, temperatures exced 2000 degrees and an unlined BRICK flue of that age could have lost some mortar allowing superheated gasses to seep into the crevices. Those superheated gasses then explode when igniged by the flue fire and either do extreme damage to the flue, blow the entire chimney apart or in the worst case scenario burn your house down.
I'm sure you've seen houses burnt and the chimney was left standing....but you have also seen damaged houses with the chimneys blown off the end of the house and laying in rubble toppled out into the yard. The latter visual picture was an example of the end result of the gasses exploding. If the chimney was inside the house instead of on the end of the house, the house would have been burnt also.
There is a lot to be careful about when heating with wood and to start off safely you need to have your chimney inspected and the gas components removed with the gas line capped EXTERNAL of the fireplace.
Dec 08, 2014 | Home
Wood stove problems
Appliances that can draw air out of your house, like the clothes dryer, air exchangers, bath and kitchen fans can cause a negative air pressure issue. The combination of a cold chimney flu and barometric pressure can also cause a down draft.
Install a Carbon Monoxide Detector in your house when using any fuel burning appliance. Be informed about the dangers of Carbon Monoxide Poisoning.
Amazon com carbon monoxide detector Electronics
http://carbonmonoxidedetectoralarms.com/
Mar 02, 2014 | Monessen Dutchwest Series Wood Burning...
Woodchief stove
It could be a draft issue . In order to work properly the stove needs to be able to draw air in to replace the airgoing up the chimney along with the smoke from the fire. In old houses this was not a problem be cause they were loosely constructed and replacement air could be drawn in around windows and doors and gaps in the walls. Newer homes are a lot tighter therefore no replacement air can get in. In some cases the house is so tight that running an exhaust fan or dryer actually creates what is known as a negative pressure situation if this is the case air can be drawn backwards down the chimney and into the house bringing the smoke from the fire with it. To check for this try starting a fire with a window or door partly open. If the fire drafts correctly you may have to install a make up air for the stove. Hope this helps.
Dec 08, 2013 | Heating & Cooling
Build a pizza oven in the back yard
Hi.
All you need is bricks and cement.
Use perforated bricks or regular 65mm bricks for the support. A light oven may be built on an U shaped support (you will need to make some structural considerations about the weight). Moreover the U shaped support on top requires an armed concrete slab adequate to support the chamber. If you are not sure about structural performance, build a solid support block of bricks.
Make sure that the support is adequate for the weight of the heavy chamber. If the oven is big, then lay basic foundations or build the oven straight on the ground.
For the chamber you must use refractory bricks (fire bricks). You have different choices of design. A common shaped that do not require armed concrete parts is the igloo style chamber. Leave space for the chimney on top of the chamber.
Mar 24, 2013 | Ovens
I want to know what a lever in a fire place is
The lever at the top of the fireplace operates the "damper". The damper is a door that opens the fireplace to the outside via the chimney.
The damper must remain open whenever a fire is burning in the fireplace to allow smoke to escape out the chimney instead of filling the fireplace and eventually, the room. The damper should be opened prior to starting a fire, otherwise the handle will be too hot to handle. Once the fire has gone completely out, the damper should be closed to prevent heat from being drawn out of the room / home. You can easily check is your damper is open or closed by simply looking up the chimney. If dark, it is closed. If light(er) it is open. Do not operate the damper while looking up - as dirt, soot, rust, etc. can fall when doing so.
The damper also prevents pests from enter the room / home. It is not uncommon for birds, bats squirrels, etc. from creating a home / getting caught in side the chimney.
I hope this helps - good luck!
Nov 12, 2010 | Coleman Heating & Cooling
We have just moved into an old house with a Baxi open fire and have no idea how to use it. Do all Baxis have boilers? How do we find the model name/number? Is there any risk in using it if the backplate is...
baxi do boilers they are on the baxi potterton wed site, but they are gas would not use with the back platecracked this old fire place you may have trouble finding parts if any , try someone one that deals with woodburners of fire places , they could well be you bestline to go down or a chimney sweep
Oct 15, 2010 | Heating & Cooling
Having trouble mounting a LC420SS8 VESA mount
There are 6 mounting screws located on the back panel that can be used as mounts points if you wish to construct a DIY mount (or if you don't want to purchase the official mounting bracket). See the manual for their exact locations.
I used 2 of these screws (the top two) to anchor a twisted steel cable that I designed to work in the same manner as a picture frame cable mount. I then drove a masonry nail into the brick chimney above my fireplace, and connected this steel cable to that mount point. The TV is mounted there, much like the way you would hang a painting (a very large & heavy painting). The bulk of the weight is supported by the front edge of the TV, which rests on a brick mantel that is part of my chimney. The steel cable, while strong enough to fully support the TV, only acts as a balancing wire, or to catch the TV should it topple forward off of the mantel.
Be sure you know how to work with steel cable and have a strong anchor point if you try to use this method. DO NOT USE THIS METHOD FOR DRYWALL ONLY APPLICATIONS. USE FOR EITHER WOOD STUDS or MASONRY APPLICATIONS ONLY.
Apr 05, 2009 | Sylvania LC420SS8 LCD TV
Flame burns to high
I had this problem. From using the center brick most of the time, lots of dust bunnies build up in the gas chimney behind the brick.
Tie 2 pipe cleaners together with a small perpendicular circle at the top and carefully remove the dust bit by bit by twirling the cleaner.
The brick should fire like new if it is carefully cleaned out.
Jan 25, 2009 | Vanguard International Infra Red - Large...
Infrared Heater - flaming thru plaque
Jan 15, 2009 | Procom ML060HPA Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
