Question about Whirlpool GEW9250 Electric Dryer
My whirlpool duet dryer model # GEW9250PLO control panel comes on, all settings will change, but will not run when you press "start". Are there some easy troubleshooting checks to narrow down the possibilities?
jumptrout51
  • 3361 Answers
SOURCE: My whirlpool dryer won't start.
Check your door switch for continuity. If no continuity,replace it.
Posted on Aug 13, 2009
dmftrucker
  • 1922 Answers
SOURCE: I need to replace a door switch on my Whirlpool Duet dryer. How?!
look toward the bottom the screws are recessed upward to hide them then it should open up like a car hood and there are spring clips at the top
Posted on Nov 01, 2009
  • 396 Answers
SOURCE: dryer runs, no heat Whirlpool duet 9250
Most likely, it is the thermostat which controls the heating element. The Bios Thermostat will have two wires connected to a round disc which has a flange and screw holes to hold it next to the blower vent or the center of the drum. Use an ohm meter to see if it open or take it to an appliance parts store to have them check it for you. You may also see a thermal fuse and a high temperature cut-off thermostat which should not read open with an ohm meter. Any open thermostat will prevent the heater element from turning on. The part should be about $25.00.
Posted on Feb 15, 2010
jumptrout51
  • 3361 Answers
SOURCE: Control Panel in my whirlpool duet dryer model
First check for 220 volts incoming power to the dryer at the terminal block on the rear of the dryer.
If you have 220 volts,check continuity on part number 59(thermal fuse) in the attached diagram. No continuity is a bad part.
cut and paste this link to your dryer diagram.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5139909&diagram_id=951915#d951915
Posted on Jul 24, 2010
blueextc3221
  • 15935 Answers
SOURCE: I have a whirlpool duet gas dryer. how do I open
1. Unplug the unit while servicing inside.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
We have a whirlpool duet gas front loader dryer and one morning the front panel says control lock?? What's solution for that??
The Control Lock is a child lock option. This prevents the dryer being started or the cycle being changed when it shouldn't. To toggle this off, you need to press and hold the Control Lock button on the WGD9550WL for 3 or more seconds. Other dryers use pressing and holding Cancel or two separate buttons for the feature. The appropriate button or set of buttons will usually have a Hold for 3 seconds label below or on the key in a small font.
The manual will also have the information on toggling the control lock on and off. Most Whirlpool manuals are available here: https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10561&langId=-1&storeId=10211&krypto=5QgxQhneFliXuEuX564wSQ%3D%3D&ddkey=http:OCManualsLiteratureSearchView . Put your model number in the search box and press the right arrow. For dryers the model number is inside the door on the rim of the dryer. If you add a comment with your Whirlpool model number, I will be glad to check if there a different Control Lock option for that Duet model.
I hope this helps.
Sep 07, 2011 | Whirlpool Dryers
Cannot be started and the status light "control
Take a good look on the control panel on the right ..It has a button that says press for 3 seconds for to lock ..Im not sure on your model ...but all models have a control locking button ..It may be the start cycle one ..If it is ..you have to press he button for 3 seconds and will unlock the controls ..
This happens when you try to make it start the cycle and hold the button on ..too long ..
Aug 15, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My Whirlpool Duet dryer has the "Control Locked"
Hi
To unlock it press the END OF CYCLE SIGNAL button for 15 seconds and the unit will reset.
Dec 31, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet dryer does not run. The control lock light stays on even after I hold down the end of cycle button for over 5 seconds and/or unplug dryer for over 15 min. The light comes on when door is...
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Jul 19, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Whirlpool duet dryer is stuck on control lock mode. Have tried pressing the end of cycle button for several seconds and control lock button stays on....dryer won't run.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#!#!
Jun 27, 2010 | Whirlpool GEW9250 Electric Dryer
Unresponsive control panel- Whirlpool duet dryer 4 years old
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&&^^^
Nov 03, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
My front loading dryer Whirlpool Duet GEW9250PLO will not come on even after resetting.
check for electrical power if you have 220+ then check the door switch, jump the wirers if necessary. If switch ok, then move timer to 20 minutes and press start--if timer ok then you must have a broken wire in the wiring harness. Good luck.
Sep 04, 2008 | Whirlpool GEQ9800L Electric Dryer
Whirlpool Duet Ghw9150pw1 would not start
Aug 21, 2008 | Whirlpool GHW9150 Front Load Washer
Whirlpool GEW9250 Electric Dryer Logo
563 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
