Question about Samsung SF555P All-In-One Laser Printer
How to scan document and save as pdf on a samsung sf-555p?
SOURCE: Save scanned document in PDF
Well I have this problem too.
The HP's link guest posted above is in simplified chinese, for those who doesn't understand chinese, and is too lazy in translating them, here is a brief translation done by myself.
HP is acknowledged of this problem, this is basically caused by the incompatibility between HP's OCR engine and form tables in the scanned documents.
"As HP's OCR engine is kinda elementary, and is not supposed for professional uses", said HP, they suggest users to reduce the complexity of scanned documents by limiting the scanned regions. The best way would be by eliminating image objects, or just scanning text within a form table. (Well that would be kinda lame and stupid.)
Well if you DO need to process documents with forms, "Get A Professional OCR software" and forget about HP's imaging software, it's what HP says.
Wish this would help.
Posted on Jun 05, 2008
checkitright
  • 1362 Answers
SOURCE: Black line on document when I scan from platen or ADF or scan to save as PDF.
As a tech I've never seen that happen. from the doc feeder only Yes, not both the feeder and the glass but not show up when you print from the computer ?????????
For sure there is a dot or something on the small strip of glass, only when you do it from the feeder.
the reason is that the document is moving and the dot on the "small" strip of glass now looks like a line to the copier.
You said it also does it when you lay it down on the glass !!??(platen) that should of indicated the drum has a ring around it, but since it doesn't come out on the PC copy then the glass must have a line on it.
Posted on Oct 07, 2008
SOURCE: Scan format - Samsung SCX-4521F to PDF
samsung scx 4521f in black background in more verticle white line in
Posted on Feb 28, 2009
  • 164 Answers
SOURCE: scan document as pdf on a Photo 926
open adobe acrobat..not reader, has no ability to create pdf's, and go to file, create pdf, from scanner
Don't forget to rank the advice!
http://www.aa1consulting.com
Posted on Jul 27, 2009
SOURCE: Can't save my scans in pdf form
This can possibly solve your problem:
0. you should have the CD that came along with the printer. the solution that is listed below is working for windows xp operating system.
1. Browse the CD -> Go to the Setup folder. -> Go to the DocProc folder. -> Double-click Docproc.msi to install. you will not see any progress etc.,
2. Browse the CD -> Go to the Setup folder. -> Go to Qfolder . -> Double-click Qfolder.msi to install. same as above.
3. Go back to your HP solution centre and under scan settings option you shhould get to see the PDF options (and a few others as well).
cheers
Posted on Aug 11, 2009
Why does samsung sf 2800 page come out black when copying a document?
if it receives faxes fine then its
likely the ccd reader input is disconnected . broken lead.
the sensor is above the slot where you insert the to be scanned sheet.
you'll have to open the case cover to find out.
Aug 03, 2014 | Samsung Office Equipment & Supplies
Save scanned document in pdf
Scan and create PDF documentYou need to install a PDF printer driver on your computerfirst. There are quite a few freeware PDF writer programs on the Internet youcan download one such as CutePDF.
From your computer SCAN your document then click on File - Print and select thePDF writer as the printer device. Then name and save the PDF file. To download Cutepdf PDF printer driver (freeware) click onthis link :-http://www.cutepdf.com/
Dec 09, 2011 | Office Equipment & Supplies
New all in one printer/scanner. when I scan I get:- Adobe reader could not open 'scan_Doc0001.pdf'
Might need a bit more information about this: But I'm presuming you scan your document and save it as a pdf document using the built in HP software?
Couple of things to try:
1 - have you got the latest version of Adobe Reader? It may be that you are using an older version - the pdf document specification has been updated over the years and it may be that you're saving the pdf using a newer version of the pdf format than adobe reader is able to read.
2 - Adobe reader isn't the only pdf viewer, there are numerous other pdf document viewers (some free some not) You could try another pdf viewer, like Foxit Reader (free to use) and see if that can open it?
3 - When you save the scan, make sure that in the Save Dialog box it is really saving it as pdf. Common mistake is that people often just save a file with .pdf and expect the program to know that you want to save as pdf. When you scan there are several other file formats that you can use (Tiff, Jpeg etc) Is is possible you're saving the file as Tiff or Jpeg but with a .pdf file extension? If you're not sure, re-scan the document and resave it, but don't use a file extension, let the scanning program do that, see what it saves it as?
4 - check where you're saving the pdf on your computer? Is the place you're trying to open it from, the same as the place you've saved it?
Feb 28, 2011 | HP Office Equipment & Supplies
How do i scan to a pdf and save on my pc
  • Scan it as a jpeg or whatever it is scanning as. then you can open the scanned image and
    save as a pdf
  • 2
    Turn on your samsung all-in-one device. Put your document that you want to scan face
    down on the tray of the samsung all-in-one.
    Open your samsung device manager on your personal computer or your Mac. Choose
    the "Scan" function. This will be slightly different depending on whether you are on a PC
    or a Mac andwhat samsung all-in-one model you have.
    Hit the "Scan" button on your samsung all-in-one or the "New Scan" button in the top left
    corner of the software on your computer.
    Click the drop-down menu at the bottom right of the scan window, below the image. Choose
    the "PDF File" option. Hit the "Accept" button. A dialog box that allows you to save your PDF
    in a location of your choice will appear.
    5
    Type a name for the PDF in the "Save As" field. Choose a place for it on your computer with
    the drop-dowm menu. Click the "Save" button. Your scanner will then scan the PDF and save
    it.
Jan 14, 2011 | Samsung SCX 4521F All-In-One Laser Printer
How to scan a document in a samsung sf-565p
you just have to put the page in the top compartment and press start. Just like how you use it to copy.
Dec 25, 2010 | Samsung SF-565P All-In-One Laser Printer
Can I scan a document to PDF?
any scanner, indeed any document, picture format can be saved as pdf. i would suggest first scanning the document as text (for example to words, or openoffice or indeed whatever you use as your document management program) and then port it (sort of print operation) to any free available "translator" program which allow you to save file as pdf. alternatively you can scan your document as jpeg and then save it as pdf, but this tend to produce very messy outlook and results are usually horrible.
Jul 27, 2010 | Brother MFC 8440 All-In-One Laser Printer
Why toner empty error in samsung sf 565p
I have an SF-555P and have installed numerous cartridges. The last one was a Samsung brand and it didn't have the little fuse taped on the top. I never knew what this was fur until I had problems. When I first installed the new cartridge the "Toner Low" display remained lit. I shook the cartridge and it persisted but it printed well. Then about 100 pages later I got the "TONER EMPTY" and the printer stopped. After researching the issue I found that the fuse is actually a reset for the printer counter and when the new cartridge was installed without the fuse, it never reset.
You will need a 5X20 Fast acting fuse, no greater than 315 ma. You can buy a 4 pack from Radio Shack for about $3 (P N 2701046). Install it with a piece of electrical tape in the slot on the toner cartridge and make sure the contacts are exposed. The printer will blow the fuse and reset the counter. Don't use a bigger fuse, a slow-blow or anything that won't burn open quickly or you will be buying a new printer.
Mar 18, 2010 | Samsung SF-565P All-In-One Laser Printer
Samsung fax machine SF 560R states 'comms error' messages in memory 65% how do we print these messages out?
When it has no paper then your all incoming fax documents save memory,Insert paper in cassette box and press start key or memory check button.
Dec 08, 2009 | Samsung SF-560 Plain Paper Laser Fax
Samsung SF555P All-In-One Laser Printer Logo
162 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
