Question about Bosch Refrigerators
I get my Bosch Refrigerator B22CS80SNS/01 failing since 2 days: No LED lighting inside, no display, no more electronic control but still cooling full speed! I found 2 boards on top. The right one is a Siemens ref# 900 308 803 and the left one is a Shaanxl Linghua Electronic ref# 9000281644. It has no 12V DC voltage but the AC 110V goes to it. I couldn’t find any other electronics and all connectors and AC connections from bottom (mains) seem OK. Any idea which board fails or if there is another 12V DC power supply unit somewhere else? I'm an engineer in microelectronics so I basically understand what we are talking about. Thank you
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 86 Answers
Always good practice to replace both boards.
Posted on Jan 17, 2016
3 Suggested Answers
  • 9 Answers
SOURCE: iv got a fisher/p refig@freezer! freezer at bottom
ok u must check the prion u will see at the back of the refrigerator,then check if the prion have a hole..
Posted on Jan 20, 2011
  • 2699 Answers
SOURCE: I have a GE refrigerator model # GSL25JFPABS. I
WR55X10942 is the board that goes into that machine,it's the most up to date board out there,why would you put a first generation board in there that you know is gonna fail when they upgraded it to the WR55X10942 and that's the board it calls for now so don't put the other board in there
Posted on Apr 19, 2011
Tip
Bosch B22CS80SNS Manual Download
Download Bosch B22CS80SNS Refrigerator Manual
Have you misplaced your Bosch B22CS80SNS Refrigerator Owners Manual?
Would you like a digial, searchable, pdf version of the Bosch B22CS80SNS Refrigerator Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
on Apr 20, 2010 | Refrigerators
Freezer compartment works okay but refrigerator compartment gets warm. Pulled bottom shelves and noticed ice build-up. Not sure of the problem. Any ideas and solutions?
Hi, it sounds like the thermostat for the refrigerator is not shutting off and just continuing to cool to the point of freezing . You need to get it checked out and renewed .
Jan 07, 2016 | Bosch B22CS80SNS (220 cu ft) Side by Side...
How to fill water in bosch KAN58A70NE Refrigerator
You can go to the Bosch website for some help. When new it comes with a hose to plumb in for water and ice.
Mar 21, 2014 | Bosch B22CS80SNS (220 cu ft) Side by Side...
Bosch service manuals
Here's a link to the manual on searspartsdirect.com B22CS80SNS 01 BOSCH REFRIGERATOR Manual
Jan 05, 2014 | Refrigerators
Despenser light no longer works.
if you mean light for water and ice dispenser they upgraded to a new led ring mine went out to you can get part from bosch parts website
Dec 08, 2013 | Bosch B22CS80SNS (220 cu ft) Side by Side...
I just bought a Bosch Linea B22CS80SNS. Where is the serial number located? Thanks much
The serial number is located on the inside of the refrigerator section, on the right side of the first vegetable bin on the panel.
Aug 29, 2011 | Bosch B22CS80SNS (220 cu ft) Side by Side...
Control panel light does not come on, light in freezer and refrigerator does not come on. Tried to run self test unable to get buttons on control panel to turn on. Tried alarm button. Also, no ice,...
Does ANYTHING work? Sure it's plugged in, breaker not tripped and GFI plug not tripped?
Plug something else into the outlet to confirm that it works.
Unplug from wall for 30 minutes to reset Bosch to defaults.
Still malfunctioning? Main control board is faulty.
Jan 05, 2018 | Bosch B22CS80SNS (220 cu ft) Side by Side...
Bosch B22CS80SNS sxs with no lights
You can get the manual here. on page 16 it tells you how to take off savagemode.
Sabbatical mode settings:
– Accoustic signal is switched off.
– Super cool or Super freezing
functions are ended (if activated).
– The interior illumination is
switched off.
– The light on the display panel is
reduced to basic lighting.
– Buttons are locked (except
“options” and “+” buttons).
Switching on and off:
̨ Simultaneously press “options”
and “+” buttons for 5 seconds
When switched on, [Sabbath] is
indicated on the display panel.
Good Luck
Nov 02, 2009 | Bosch Refrigerators
My bosch dish washer won't work. A number 1 is displayed on the electronic panel. what does this mean Paul
Helloduranjp,
Welcome to fixya.
You said, Your Bosch dish washer won't work. A number 1 is displayed on the electronic panel.
If it is displaying"01" then that means the extra dry setting is being applied!
Did you try to use the extra Dry setting?
Did the dishwasher work before this or is it brand new?
What is the model number and year?
Let me know ! I'm waiting for your response
Below is and example of the usage of 01 or 00 in a Bosch Dishwasher!
Extra Dry Heat
With this option you can raise the temperature of the rinse water and increase the drying
time which will result in improved drying.
To activate :
Press and hold the left cancel drain button ,
Then press and hold the on/off button when the LED display shows a, "00" or a "01"
To enable the additional drying heat,press the left cancel drain button until the LED display shows a "01"
To disable the additional drying heat,press the left cancel drain button until the LED display shows a "00"
press the on/off button to save the settings.
Huuum
Oct 02, 2008 | Bosch Dishwashers
Refrigerators Logo
720 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
