Question about Dryers
HOTPOINT AQUARIUS CONDENSER TUMBLE DRYER CTD40
I have a hotpoint aqaurius condenser model CTD40. the light telling me to empty the water keeps flashing even though it is empty. I can get the dryer to work and its hot air coming through but its stops the cycle after 3-4 mins with the light still flashing...I have emptied the filter at the bottom and the filter in the dryer and am still getting no joy - Any ideas????
There are three water reservoirs - one at the bottom behind the condenser, a second at the back bottom of the machine and then a third at the top which is the one you would normally pull out to empty.
There is a hole at the bottom of the filter in the first reservoir (at the back of the condenser) which leads to the second reservoir at the back. If the hole gets clogged up with lint/muck then the reservoir at the back does not fill up.
So to solve this, unplug the machine, take out the condenser (front left bottom of the machine) reach through to the back and mop up the spare water with a towel and check that the hole to the back reservoir - you can feel this it is towards the right side at the back of the machine is clear from muck.
Once you have cleared it, water will flow to the second reservoir and then (once you switch on the machine) up to the main removeable reservoir at the top.
Hopefully this helps. GB
Posted on Sep 10, 2009
Not sure but try this..it workd with my Whirlpool dryer. Remove the condenser (clean it with water and a toothbrush too coz it will probably be clogged up) and pop a tea towel in the hole where the condenser was. Tip the dryer on its side and any trapped water will run out onto the tea towel or the floor OR the water reservoir where it should have gone in the first place......
Posted on Mar 13, 2009
    President:
  • 1,462 Answers
There is a pump which pumps water up to the top collector - located behind a small back panel. either the pump has failed or is blocked with lint
Posted on Jul 09, 2008
Empty water light, empty condenser
I experienced the problem with a hotpoint TCYM 750, with the red empty water light failing to switch off. After removing the filter and cleaning it, cleaning the condenser and drying anywhere I had access to the machine still didn't heat and the light remained on. Reading the post about the machine having 3 reservoirs it struck me that one of the reservoirs may be hard to access. So I unplugged the machine and tipped it onto its front. The reservoir drained, I pushed the machine back upright and cleared up some water around the condenser. The drier now works properly and the empty water light is off - job done!
Feb 04, 2014 | Hotpoint Dryers
LIGHT FLASHING EMPTY WATER,CUTTING OFF WHEN WATER EMPTIED
Try cleaning the water sensor, it may need to be replaced though.
Dec 22, 2013 | Dryers
My Hotpoint condenser tumble dryer TCD980 won't dry.
hi ime not sure but some dryers have a small tank inside at bottom with a float maybe float is stuck or if it has a pump maybe not working will have one if water tank is at top of dryer
Feb 05, 2013 | Hotpoint Dryers
Hi I've Got A Hotpoint Aquarius CTD40 Tumble Dryer
that isn't a model number,open the door to the dryer,look around the opening where you put the clothes in and send the full model number,
Dec 21, 2017 | Hotpoint Dryers
Empty water light flashing on hotpoint ctd40 dryer even with no water in it can you help
this could be just a sticky switch staying stuck on, telling the dryer it has a full tank try soaking the switch in switch cleaner or wd40 may work
Jul 23, 2010 | Hotpoint Dryers
HOTPOINT CTD40 CONDENSING DRYER not drying clothes any more.fault codes is on/off light and time delay lights are flashing after 30 seconds of switching the appliance on.the condenser unit is free of fluff...
Without actually taking meter readings I would suggest that its probably the thermostats that are fitted to the heater unit on the back of the appliance.
Hotpoint Part Number: 1703607
Hope this helps
Aardvark repairs
Nov 16, 2009 | Hotpoint Dryers
Hotpoint aquarius tumble dryer, drum not going round but still
If you can hear the motor going, then the belt probably needs replacing, if no motor action, then prob is more serious.
Please rate my solution.
Thanks.
Jul 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Dryers Logo
1,843 people viewed this question
Top Dryers Experts
