The shredder has just developed a problem where, when inserting paper to shred, it will not automatically shut off. It has to be manually shut off. When you immediately turn it back to "auto" position, it is off until paper is inserted. Then it has to be manually turned off again. The shredder was purchased on 10/02/2010. THANKS!
    Genius:
  • 1,218 Answers
There are 2 "eyes" in the middle where you insert the paper ...give these4 eyes a clean, they may just be dusty/dirty.
Posted on Jan 16, 2011
Shredder will not work in automatic mode
There might be a tiny scrap of paper blocking the sensor, which will keep the motor running.
Dec 06, 2016 | Shredder Office Equipment & Supplies
Just purchased shredder and it seems to work in reverse but not on auto.There was a small basket looks like it hooks on to something I don't see where.This basket is not shown in the manual.
Question: have you inserted paper to shred while set on AUTOMATIC?
In most units, there is a sensing switch (electronic or mechanical) that allows it to run.
Jun 06, 2015 | Honeywell 9112 Twelve Sheet Cross-Cut...
Runs reverse auto
From your manual!
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the waste basket; insert waste basket and repeat jam clearing procedure.
Feb 01, 2014 | Fellowes DM12C Shredder
Won t shut off
Blow out the sensors with some compressed air, Using a can of compressed air, look for the sensors that detect the paper and give them a blast or two, then try it, it may take a couple of tries.
This may also be a good time to lubricate the cutting heads, if it is a good machine with metal heads a light oil applied to paper then run through the shredder will pass the oil onto the heads.
A shredder oil or light oil like 3 in 1, these usually have a narrow nozzle to limit the oil flow, draw lines, do a picture or spell your name on the paper with oil and shred it. You have just serviced your shredder.
If it is a less expensive shredder with plastic heads, shredding a couple if sheets of waxed paper will pass the wax onto the cutting heads reducing friction.
Hope this helps.
Ed
Oct 01, 2013 | Office Equipment & Supplies
Only runs in reverse
I just had this problem with my shredder. I think the problem started with a bin that was full. Running the shredder in reverse resulted in shredded paper being pulled up into the slot used to feed paper into the shredder. Some of this shredded paper was blocking the little plastic tab that activates the switch when paper is inserted, so the shredder would no longer start when paper was inserted. I emptied the bin and removed the shredded paper from the feed slot, being careful not to break the plastic "sensor" while removing the paper from under it. The shredder works fine now.
Dec 13, 2010 | Fellowes W11C Confetti-Cut Shredder
Runs only in reverse
Nov 06, 2010 | Fellowes W11C Confetti-Cut Shredder
The shredder developed a jam. I removed the bin and the top of the shredder. I removed the shredding mech. and removed the paper material. Reassembled the shredder. Shredder starts up when paper is...
Does the motor run??? even in reverse???
If the motor doeas not run at all it probably PCB. If the motor does run but the cutting mechanism does not turn then you probably have stripped/broken plastic gears... open and check,...contact Royal at 1-800-524-0799 for parts assistance.
Oct 27, 2010 | Royal VF880 Shredder
Shedder OM99732 in automatic mode will start and shred when paper put in, but will not shut off. It also appears there is some type of plastic covering the screws so I am unable to remove the cover. It...
It sounds like a piece of paper is blocking one of the two photo cells that detected when a piece of paper (or a CD / DVD) has been inserted for shredding. The (six) screws that secure the top are accessible from the bottom of the shredder unit after it is removed from the paper bin. Be careful: There are three different sets of wires connecting the top control plate to the bottom motor and cutter assemblies. It is not too difficult to get inside the shredder "head" if neccessary.
Aug 23, 2010 | OfficeMax Office Equipment & Supplies
Paper shredder does not turn off. I have to open
I'm assuming that it automatically detects the presence of paper... .
By opening the drawer you're disabling it from the safety switch. (they dont want you to shred your fingers from the bottom) There is probably a small piece of paper holding the feed sensor down.
If you're confidant, unplug the unit and take apart the plastic cover. Do not remove anything inside. Look for the small switch between the blades which 'feels' the presence of paper. There is probably a small piece of paper wedged between the housing and the switch which would fool the unit into thinking it has paper that still needs to be shredded.
Carefully put your unit back together and happy shredding.
This may happen often, remember what you did!!!
Jul 30, 2009 | World Office Products Papermate PM-1550CD...
Royal VF12mx shredder
Pour some shredder oil in the throat where you normally insert the paper...put some shredder oil directly onto 1 sheet of paper and try shredding 1 sheet. If it wont even shred 1 sheet I would ask is the shredder running???
Mar 05, 2009 | Royal VF1012mx Shredder
112 people viewed this question
jasbo
jasbo
