Question about Kitchen Ranges
THE BOTTOM ELEMENT OF THE OVEN WILL NOT WORK. THE BROILER ELEMENT WORKS, EVERY THING ELSE WORKS HOWEVER , I HAD A CERTIFIED JOURNEYMEN ELECTRICIAN CHECK IT OUR AND HE CAN NOT TELL IF THE ELEMENT IS GONE OR THE CONTROL TIMER UNIT IS GONE. HIS REALING FROM HIS METER SHOWS THE ELEMENT IS STILL SHOWING GOOD RESISTANCE AND IS SHOWING OPEN OR CURRENT IS STILL PASSING THROUGH THE ELEMENT. HOW DO YOU TELL OTHER THAN TRIAL AND ERROR AND SPENDING 50 DOLLARS TO CHANGE THE BOTTOM ELEMENT OR HOW DO YOU TELL IF THE TIMER CONTROL UNIT IS NO GOOD, BECAUSE EVERY THING ELSE WORKS ON THE STOVE.???
    Problem Solver:
  • 16 Answers
You can check the element by supplying the necessary voltage at its terminal direct. Remove the connection and supply it with your own extension wire going to the live outlet. This is easy but dangerous to the untrained personnel. If it works then the most probable culprit is a broken wiring or the timer itself.
Posted on Jan 03, 2011
Oven taking to long to preheat the doesnt cook the food...speed bake button not working...but broiler and burners do..this just started. IT WAS WORKING
call in a technician or electrician
could be thermostat or a blown element ( probably an element)
Feb 25, 2016 | Ovens
My top broiler won't turn on. Everything else works fine. I have exchanged the top broiler element with the bottom. So I know it isn't the element.
Could be wiring. Did it work before? Maybe, never connected? Could be demand of two oven's and or broilers at the same time exceeded the wire and circuit breaker capacity when installed and therefore were never connected.
Otherwise thermostat. Probably need appliance Tec or Electrician.
Mar 04, 2015 | GE JTP27 Electric Double Oven
Kenmore 790 oven won't heat after self clean
Did you fully disconnect the wires when you checked continuity? If not you are checking continuity in the whole circuit. For what its worth, the self clean feature superheats the oven and often burns out elements. We see it all the time. It is one feature to never use!
The broiler element is not part of the oven temperature, it is a broiler. The oven works on the bottom element alone. If it only gets to 300'F, wither the bottom element is faulty or the thermostat is failing. As I mentioned self clean is a great way to cause problems.
Nov 16, 2017 | Kitchen Ranges
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
The oven does not heat up on my GE Spectra XL44 but the broiler and stove work fine.
Might be the bottom element is bad. Not too hard to install a new one.
I am no electrician but if you unplug the stove, remove the bottom element and use an ohm meter attatched to each end, it should show if the element is broken through lack of continuity.
Just an idea from a landlord.
Oct 30, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Oven and broiler: no heat
Flipped the breaker switch! Although we had looked at the breaker first thing, and it was not flipped off, plus everything else on the range was working: we found out it is actually a double breaker, with one half controlling just the oven, and it can be just partially flipped and you don't notice it. So as soon as you toggle it off and on again, you are back in full power.
Apr 08, 2009 | Kenmore Kitchen Ranges
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven not working
There is a separate element for the oven (bottom one) and the broiler (top one) It sounds like the bottom heating element is burnt out assuming this is an electric oven.
Nov 23, 2008 | Ovens
Gas oven's broiler works. Regular oven does not.
There could be several reasons.
  1. You could have 1 bad element.
  2. You could have a loose connection in the stove. Try removing the element and reinstalling to reset the element.
  3. Your selector switch could be bad. Contact an electrician for electrical checks
Please rate this solution
Jul 31, 2008 | GE Kitchen Ranges
Kitchen Ranges Logo
77 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
