Question about Kenmore 62972 Electric Dryer
Dryer squeals when running. - Kenmore 62972 Electric Dryer
  • Kenmore Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch.
Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt.
Remove the drum and belt and this will expose the drum rollers, idler arm
pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the
idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go
to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots
or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably
only need lubrication. Lubricate the shaft of the rollers with a good grade
of machine oil such as 3 in One oil.
Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Posted on Jan 03, 2011
Squeals while drying clothescould this be a bad belt ?
It can come from two things, belt for sure when you over load the dryer or it is getting worn an second the rubber wheels the drum sets on can squeal.
Mar 29, 2014 | Kenmore Elite HE4 Electric Dryer
Squealing dryer
Sounds like the drum bearings are going bad, or at the very least need lubrication. thats what your problem is.
Jan 25, 2008 | Estate TGDS740JQ Gas Dryer
Really Bad Squeeky Noise
It could be a squeal from the dryer belt. It could be from a belt that has gotten loose, like you hear on a car sometimes when it first starts up, but usually they don't get loose. They just break. Maybe something has gotten jammed between the dryer drum and the interior of the dryer making it hard for the belt to turn the drum and so it is squealing. Does the drum turn by hand without too much force and without squealing?
Feb 10, 2014 | Siemens WTXD5300US Electric Dryer
Dryer was making high pitched squealing noise and now won't run
Please supply the model number so we can help further.
May 20, 2012 | Hotpoint Dryers
Kenmore series 80 Gas Dryer, in back of the dryer there is a fan at the bottom that squeals when I turn the dryer on. Is this easy to replace or oil to resolve the squealing. Suggestions are...
that fan runs off the motor shaft and can be lubed with some spray lube,, be sure that its not the belt thats squealing, check it for cracks, and bare spots
Jul 06, 2011 | Dryers
My dryer is squealing and have to run it twice to get my clothes dry
the squealing/squeaking noise is more then likely your drum rollers:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
the drying twice is a venting issue:
http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
Feb 16, 2011 | Whirlpool LEW0050P Electric Dryer
Dryer makes squealing noise when running. What's wrong?
the idler or tensioner wheel that your belt rides on has a bearing in the center of it. This bearing is going out causing the high pitched squeal your hearing
Jan 23, 2011 | Fisher and Paykel DGGX2 Dryer
Kenmore solid state dryer. was squealing while running. now drum stops and starts. still squeals
belt, idler pulley, drum glide/rollers:
belt/idler pulley:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
rollers/glides:
http://www.partselect.com/dryer+replace-glides+repair.htm
belt configuration
http://www.applianceaid.com/images/belt-config.JPG
Dec 03, 2010 | Kenmore Dryers
Maytag dyer was squealing now smells like burnt rubber
Sounds like you may have a belt slipping.Take the back off &see what the belt looks like.
Aug 28, 2009 | Whirlpool LER4634J Electric Dryer
LOUD SQUEALING NOISE
Most likely the rear drum bearing is worn. There's a "ball and socket" arrangement that supports the drum at the rear and a repair kit for it. Part #5303281153. Should run around $25.fe7bd93.jpg
Dec 27, 2007 | Frigidaire GLER341A Electric Dryer
Kenmore 62972 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
