Protemp 70T will not restart. green light will blink and unit will not restart. Turn off power switch and back on, green light will burn steady and unit will restart a few times then green light starts blinking.
  • 1694 Answers
SOURCE: Power Failure, now the power/timer blinking light won't stop blinking
Four bad caps in DM module = common repair for qualified
Mits tech.................................T.
Posted on Nov 22, 2007
SOURCE: Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Posted on Feb 20, 2008
ctf1800
  • 4402 Answers
SOURCE: Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Posted on Feb 26, 2008
SOURCE: Ruud Achiever 90 Plus wont start
4 blinks is "pressure switch closed" there are 2 in the system according to the wiring diagram one for the vent system  and one for the drain system ... I just wiggled them and heard one "click" the fault light quit blinking and when I pushed the safety switch back in the furnace fired right up.  That being said is there a good website for learning how to maintain your own furnace?  I'll call a pro if I have to, but shoot I can fix a jet engine... this shouldn't be much worse.
Thanks  dan
Posted on Mar 10, 2008
SOURCE: ALL LIGHTS BLINK BUT UNIT IS DRAINED
Hi all,
I think the problem is that the A/C has tripped the electrical switch located in the plug. To correct press the black button followed by the clear button. Then try turning the unit on -it has worked for me so no reason it should not work for you.
Regards,
Tommie C.
Posted on Sep 02, 2008
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
Power Problem with 2Wire 2701HG-B
Sounds like a startup self test. All wireless devices go through a power on self test. Does it connect? You can connect to it and go online? I rarely turn mine off, only in a electrical storm.
Nov 22, 2012 | 2wire (2701HG-B) Wireless Router
My unit to my house wont turn on outside. This happened last night at about 8:30. I have checked the circuit breaker/fuses and the little red switch on the unit itself-- I pushed that. I turned the...
Turn power off to indoor unit. Remove red, yellow and green wires from tstat and wire nut the three together. Turn power to indoor unit back on. This should bring on indoor fan and outdoor conpressor and fan. Let me know
Jun 22, 2017 | Fedders Q Chassis A6Q10F2A Air Conditioner
I mistakely deleted pictures from my camera (Kodax Esay Share M340) Move picture to internal memory.How can i get the pictures back
If Try one or more of the following
Ready light does not turn on and the camera does not work.
Ready light blinks green.
  • Camera is operating normally.
Ready light blinks amber.
  • Wait. Resume picture taking when the light stops blinking and turns green.
Ready light blinks red and camera turns off.
Ready light glows steady red.
Ready light is off or glows steady green.
Mar 10, 2011 | Kodak Cameras
The top light of the two is flashing green/red back and forth very fast and the light on the bottom is a solid red. how do I fix this so that way it will work normally
The steady lower light indicates the unit needs a new toner cartridge, MLT-D108S. Did you previously see this light blinking or blinking rapidly? (Those indicate the toner being low.) Replace the cartridge and check for any other error lights. Turn off the machine and let it cool. Then open the front cover and pull the old toner cartridge. Open the package with the new cartridge, remove the packing tape and paper that protects the cartridge and gently shake it (avoid touching the blue or green parts of the OPC drum). Press the cartridge into the slot until it is fully seated. Close the front cover.
The green/red blinking power light is not one I'm seen before. The printer indicates a non-toner failure (open cover, no paper, LSU failure, etc.) with a steady red light.
Aug 02, 2010 | Samsung ML-2240 Laser Printer
Internet connection stopped suddenly
Switch off power to the modem, router and computer. Now switch on the modem first and let all lights on it to be stable.. Then switch on the router and let all lights on the router become stable. Once the lights on router are all stable, switch on the computer and then try to accerss sites.
May 07, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
I have a mitsubishi 1080 projection tv. I wont turn on, the green light just keeps blinking.
Check the manual...blinking green light is normal. The unit is powering down cooling the lamp. It could have been a shut down command through pressing the off button by accident. If problem continues I would unplug tv and power on/off. Steady green. Next to the lights is a small indentation where you can reset the TV to the defaults. Take a paper clip ...power on..and put in the center. The green light will blink for a minute or two then go dark. THen power up.
Dec 10, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Feb 10, 2008 | NEC VT460 Multimedia Projector
Bose lifestyle no sound
Hi, best practice when troubleshooting a no-sound Bose Lifesytle system is to first begin with the internal sources (i.e. the AM/FM). Bose Lifestyle system when connected properly (media center and bass box via the data cable) should show a steady green light underneath the bass module. Begin by simply playing AM/FM tuner and try to increase the volume till 45 (normally the sound becomes audible at this level). If the system still has no sound, then try to check if the bass module is steady green. When you see a blinking green LED (slow green) then do kindly check the DIP siwtch (red latch switch with white mini switches) just beside the Light and data connection. All of the switches should be in "ON" position (basically toggled upwards with the arrow marking indication). Before changing DIP switch settings do ensure that the bass module is not connected to the electrical power. after ensuring that all DIP switch are in the "ON" position, connect the data cable firs and then power up the bass module. Then you should see the bass module blink green twice and once you turn on the nedia center, the green blinking should turn steady green. That should sort out your problem.
Also do note tha this procedure applies only to Series II Lifesytle System and does not include the Series IV (with the smaller bass module).
If all still fails, there is an internal problem with the bass module which would require servicing.
Hope this helps!
Jan 27, 2008 | Bose Lifestyle 18 System
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
