Question about Apple iTunes
I keep trying to connect to the itunes store but it says that the network connection is timed out and I need to check it to make sure it is active. I already went to the LAN settings and checked the box I needed to check, but I still can't connect to the store. What am I supposed to do?
    President:
  • 2,291 Answers
Reset ur internet connection, run reginout cleaner to fix it
Posted on Jan 10, 2011
Cannot unblock iphone 5
Fix the issue on your iPhone, iPad, or iPod touch If you can't connect to the iTunes Store on your iPhone, iPad, or iPod touch, make sure:
  1. That your date, time, and time zone are correct. Tap Settings > General > Date & Time. Time Zone might list another city in your time zone.
  2. That your iOS software is up to date. To check for updates, tap Settings > General > Software Update. You can also connect your iPhone, iPad, or iPod touch to iTunes and click Check for Updateon your device's Summary page.
  3. To check that you're in range of a Wi-Fi router or base station. If you're using cellular service, make sure that cellular data is turned on from Settings > Cellular. If you're connected to cellular data, larger items might not download. You might need to connect to Wi-Fi to download apps, videos, and podcasts.
  4. That you have an active Internet connection. For help with your connection, check your device's user guide.
  5. To see if other devices, like portable computers, can connect to the Wi-Fi network and access the Internet.
  6. To reset your Wi-Fi router by turning it off and then on again.
If there's still an issue, learn what to do if your device won't connect to a Wi-Fi network.
Jul 07, 2016 | Apple iPhone 5
When I tried to connect to iTunes, I got this message: Cannot connect to iTunes Store. Unknown error 0x80090318. Make sure your network connection is active and try again. What does this mean? I am trying...
Start Menu>Click All programs>Accessories>Right click command prompt> run as administrator>Click on continue> When the scream comes up Type...
netsh winsock reset
Please Note: Space between the 3 words
Message will appear:
You must restart your computer in order to complete the reset
After that you will be able to connect to your itunes
This should fix the issue
Dec 18, 2013 | Computers & Internet
When i go to update my ipod, it says, network connection timed out, please make sure network connection is correct and active. how do i do that so i can update my ipod?
Go to System Preferences from the Apple icon menu (top left) under the Internet & Wireless section there is a Network icon (glass ball looking thing) click on that. green dot next to ethernet (or wireless whatever one you use) means you are connected. yellow dot means ready but not connected. red dot means not connected.
If you have a red dot next to the connection that you use, check your router or modem. You might have to call you ISP if the problems keep happening.
Feb 20, 2011 | Apple iTunes
Always pop up NO SIM INSTALLED or NO SIM , how can i fix it? my phone is iphone4, thz
Check sim in another iphone first see if it works, if so have you activated your phone and sim correctly? If so then try restoring you iphone as NEW iphone (following instructions below to do) ..... if that doesnt work then you may need to try getting a new sim from your network or maybe popping into an apple store to see if its the phone
  1. Make sure you have the latest version of iTunes installed and running before attempting to update.
  2. Connect your device to your computer.
  3. Select your iPhone, iPad, or iPod touch when it appears in iTunes under Devices.
  4. Select the Summary tab.
  5. Select the Restore option.
  6. When prompted to back up your settings before restoring, select the Back Up option (as seen in the image below). If you have just backed up the device, it is not necessary to create another.
  7. Select the Restore option when iTunes prompts you (as long as you've backed up your device, you should not have to worry about restoring your phone).
  8. Once the restore process has completed, the device restarts and displays the Apple logo while starting up:
    iPhone only: For the iPhone only, after a restore, the iPhone displays the "Connect to iTunes" screen. Keep your device connected until the "Connect to iTunes" screen goes away or you see "iPhone is activated." If iTunes does not have an Internet connection, you cannot complete this step.
  9. The final step is to restore your device from a previous backup. Once your device is restored and-in the case of the iPhone-in the process of activating, you should be able to see the following in iTunes:
    Select the backup you want for your device and select the Continue button to complete your device's restoration.
If you do not want to restore from backup, select "Set up as new..." If you want to preserve previous backups that iTunes has made, be sure to back up the appropriate directory before choosing to set up as new. To learn more about setting up your device as new, see How to set up your iPhone, iPad, or iPod touch as a new device.
Jan 01, 2011 | Apple iPhone Smartphone
Itunes could not connect to the itunes store. make sure your network connection is active and try again and error 11222
This is going to be your anti - virus software blocking itunes
disable it or remove it
refer to link for more info
http://support.apple.com/kb/TS3125
Mar 11, 2010 | Apple iTunes
ITunes cannot connect to iTunes store, the network connection was refused. What should I do ?
I had added a proxy to my internet explorer while trying to access another intranet. I always use Firefox so I didn't think it would matter if it was set to the intranet IP as the proxy, but apparently itunes and some other programs blindly copy the proxy settings from explorer and will stop working. everything was fixed when I disable the proxy in the connection tab.
Apr 28, 2009 | Apple iTunes
ITunes store connection probomething
Check your firewall, enable it if it's stuck off. And also check your virus and malware programs, it sounds fishy if you can connect to every other site sounds like someone set it so you can't get in, check your security settings also
Feb 03, 2009 | Apple iTunes
I can connect to the internet but not to Itunes store, AIM...
Can you check your wireless router ? Does it have RJ45 ,you can hook up your computer ,make sure ,network is ok. Then check your apple.
Jan 31, 2009 | Apple iPod nano 4th Generation
Getting into itunes store
Make sure you are connected to the internet - the error msg means it doesn't detect that you are connected to the internet
Jun 22, 2008 | Apple iPod nano
Apple iTunes Logo
88 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
