Question about Briggs Stratton 020273 Elite Series Portable Gas Pressure Washer
The 6.5 hp Briggs & Stratton engine that powers my 2550 elite pressure washer is blowing oil out the exhaust and air filter while it is running. Do you think this is a gasket problem or a piston ring problem?
    Genius:
  • 1,267 Answers
It most likely is a ring problem as the gasket only keeps the combustion gases in and would leak around the head as a loud noise. Of course it could be the valves, but I doubt it as most of these engines are splash fed instead of pressure, so the only explanation is the compression ring is letting oil blow past.
Posted on Jan 03, 2011
How start small engine that has not been started in long time?
Hello, First check oil level and make sure it is full. Then take out air filter and clean, then take out spark plug and make sure the gap is correct according to your users manual. Add fresh gas, choke and start.
May 17, 2014 | Briggs & Stratton 020272 Elite Series...
Water in oil
sounds like the head gasket is gone once water mixes with the oil
Aug 30, 2012 | Briggs & Stratton Garden
I have a Troy Bilt 2550 psi Power Washer with a Briggs and Stratton 675 Series, 190cc engine. Could you tell me what kind of oil I should use.
Best oil for small engine for most moderate climates is 30wt non-detergent. The pump can use mineral oil (air compressor oil ) sold at most auto stores and lumber outlets.
Jul 02, 2011 | Garden
Started by Craftsman 2700 PSI , 2.3 GPM Briggs & Stratton Powered Pressure Washer for first time in 9 months. Added new oil, and gas. started but is smoking from muffler and is dripping what appears to...
The first thing I would check would be the oil level, to make sure you didn't put in too much oil. If the oil level is correct, it could be a stuck piston ring, letting oil blow by the piston, and out the exhaust. If this is the case, you are going to have to tear down the engine.
Hope this helps!
May 09, 2011 | Craftsman 2700 PSI,2.3 GPM Briggs &...
My pressure washer i have oil coming out my engine exhaut pipe and it wont start.
Need a head and piston service.When oil comes out from exhaust it mean the the piston rings are burn.
Nov 03, 2010 | Briggs Stratton 020273 Elite Series...
Need to know where oil drain plug is on 6.75 hp Briggs & Stratton engine on 2550 psi troy bilt pressure washer!!
I have the same model...... it should be just underneath the unit.... it will look like a square head recessed. I used the ratchet set extension and it fit just right. I literally had to tilt the darn thing upside down to find it. Then once it was loosen a bit, I put the machine upright on the wheels again, and slip a plastic pan underneath as I finished unscrewing the oil plug, Out came the black goo.
Aug 07, 2010 | Briggs Stratton 020273 Elite Series...
Craftsman riding mower 2003 DLT 3000 ,Blowing oil out of the fuel
Head gasket is blowed .Its building pressure in the crankcase seen it twice. Remove the head and check for a blowed out spot between piston and the valve side
Jul 29, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
May 17, 2009 | Briggs & Stratton Garden
Briggs Stratton 020273 Elite Series Portable Gas Pressure Washer Logo
898 people viewed this question
Top Briggs Garden Experts
Mike
Matt Olenzek
Matt Olenzek
Are you a Briggs Garden Expert? Answer questions, earn points and help others
