Question about Electrolux Washing Machines
I have an eletrolux washing machine,model' washy talky' no 660.Due to rat menace its circuit board stopped functioning.The machine is situated in Bihar near Samastipur,the service people could not solve problem locally.I am coming to pune on 6th,would depart by 11th Jan.If the kit would be delivered to me right there, i would be grateful.I may be informed about the status,and cost,as well as how to procure on my mobile no.09835645112,or be mailed at -drprabhats@yahoo.co.in
5 Suggested Answers
SOURCE: service manual
looking for a service manuel for a fisher paykel GWL11US about 4 yrs old
Posted on May 27, 2008
mnwarfield10
  • 452 Answers
SOURCE: how to replace the water inlet
TURN ELECTRIC OFF .....top lid off x2 screws on lid....remove water inlet pipe...TURN WATER OFF FIRST :)....undo or unclip on valve...unclamp water clamp on hose ... take off hose ...reomove valve..refit new part ..refit hoses .... test .
Posted on Jan 04, 2010
TheMobilian
  • 8220 Answers
SOURCE: whirlpool 6th sense washing machine,
Find your machines tech sheet. The error codes and suggested remedy's will be there.
Posted on Feb 01, 2011
bharana_boya
SOURCE: my washing machine model is
pl check the bp sensor or the conector of the wire harness.according to my knowledge there is no door sensor in wf-660.if bp sensor is ok change the P.C.B
Posted on Aug 02, 2012
Electronic board for AGI SS 50 whirlpool washing machine
find the part number for the board and go on ebay to look for a new or used one boards our usually expensive so i would look there first
Nov 20, 2014 | Whirlpool Washing Machines
MY MACHINE STOPPED MID PROGRAM. the red light indicating the door is locked is not on so i suspect this is why it stopped. the door itself is locked and will not open. the machine is full of clothes and...
You haven't given the machine make and model. The door lock is electrically operated and so if the door will not open even after unplugging the machine from the mains power, then the door lock has probably shorted and got stuck (welded contacts due to excessive power). This may also be the reason why the machine stopped and the red light is off. The mains fuse may also have blown. This used to be a common problem on Hotpoint washing machines. A track on the program circuit board would also burn out due to the current. The repair in this case was to replace the door lock and repair the burnt out track.
In terms of emptying the machine, if this is a front loader, then try banging the front of the machine where the door latch is situated. This may be enough to free the lock mechanism. If not, then remove the top cover AFTER FIRST DISCONNECTING THE POWER, and see if you can get access to the door lock form inside. It should be possible to dismantle the control panel and free the front of the machine, which will still be attached to the rubber drum seal.
May 25, 2011 | Washing Machines
Hi i recently moved into an apartment which has a CDA CL993 washing machine.It seemed to work fine at the start but now i realise that i have to switch on the functions manually to get the machine do its...
its probably the control board - timer it comes off from the back u have to pull the cover off pay attention to the way it comes off n put back o nthe same way these knobs are timers too and they go bad !!!
Apr 08, 2011 | CDA Washing Machines
My washing machine model is LG WF-660.. it cannot function due to failure indicator at water level.... it keep on "beeeping" cannot do other operation.... plz help....tq...
Feb 03, 2011 | LG Washing Machines
Machine does not turn on but circuit board has power I think prob is circuit board
I would bet you have a duct fuse blown due to some sort of air flow restriction. Most duct fuses have small wires, do not carry a heat load, and are in the same circuit as the door switch. When drum temp rapidly rises to 350f the duct fuse melts and stops the appliance before dangerous situations occur.
Mar 03, 2010 | Dryers
How to replace the water inlet in electrolux kelvinator 760 FXZ washy talky washing machine
Jan 04, 2010 | Washing Machines
Panel board wires have been cut by the rats...is
solder and heat shrink or solder and liquid electrical tape
Dec 17, 2009 | LG WM-1832C Front Load Washer
Hi! Can you help me decide if the Kenmore oasis 3.8pc is a good washing machine.
The Kenmore Oasis is made by Whirlpool for Sears. It is the same as the Whirlpool Cabrio. The Cabrio and the Oasis had a problem with the computer board. Whirlpool has been replacing the computer boards under a recall(mine was replaced recently). But I believe it is the model with no agitator in it. The one your talking about I believe is the one with the agitator. Whirlpool makes a good product. I would stay away from Maytag. Besides the recall problem I have had mine for over 2 years and it has worked fine. But I did get the extended warranty with it due to all the sensors and computer board can make repairs expensive.I have not had to use the extended warranty yet. My previous Kenmore washer was 12 years old and stopped working due to a rat chewed thru all the wiring and hoses. It would have cost me more to repair than what it was worth so I purchased the Cabrio.
Sep 27, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
32 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
