Question about Krups XP5220 Espresso Machine & Coffee Maker
I need to replace the espresso filter holder for krups XP5220 P
SOURCE: instructions for Krups Gusto espresso maker
http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Manuals/ResultManuals.htm?SelectedService=Manuals&SelectedGuIDService={F506FE01-D7EC-414A-BEC1-AE53E62990C6}&SelectedProdRef=F880
This is the manual :)
Posted on Jan 25, 2008
Drummernick
  • 440 Answers
SOURCE: how to use krups espresso machine
http://www.electrobest.com/krupinman.html
hers ther manauals on these thx nick rate me as fix ya thx
Posted on Feb 07, 2008
  • 4 Answers
SOURCE: breville ESP8XL Espresso Machine Cafe Roma leaking.. help please..
We had that happen and it was a crack in the black ring that holds the filter. Breville could not supply us with one but we found an OEM part in aluminum from http://www.vancouverwireedm.com/caferomadiyt.htm. We received it 1 week after ordering. It was pretty easy to replace. Our machine works fine now.
Posted on Sep 26, 2008
SOURCE: i have a krups fnb4
RTM !!!
Posted on Oct 24, 2008
SpotBert
  • 231 Answers
SOURCE: Need the instruction manual
The 866 was superceded by 874 and 888.
Here's the manual for 874 =>
http://www.krupsusa.com/NR/rdonlyres/C1F9A0BF-7C73-4009-B552-9B75D43B6DDC/2419/CAFEPRESSOF874_endefrnl.pdf
Here are the manuals for 888 models =>
http://www.krupsusa.com/NR/rdonlyres/FEFA75D6-E1B1-4AEF-86BE-86239F8F5C11/19888/88843CafeCentro.pdf
http://www.krupsusa.com/NR/rdonlyres/55222C7A-5B29-4DD2-9828-679A73F140F0/7908/F888_NAm.pdf
http://www.krupsusa.com/NR/rdonlyres/A025B3F7-4253-45C9-95CA-AF3036FD2914/2430/CAFEPRESSOTIMEF888_multi.pdf
You can call KRUPs to see if there are any major differences.
Posted on Dec 28, 2008
Need to open front panel to check defective switch on front panel
there is 4 skruws from the front you will seen them remove the filter holder and you will see on the age if it and you have some at the back then you lift up slowly from the front upwords
Oct 10, 2015 | Krups XP5220 Espresso Machine, Precise...
How do i prime an xp5220
You should be really need to prime it all. Check where the water reservoir is installed for blockages or dirt. There should be O-rings present, these may have become dislodged.
Feb 08, 2014 | Krups XP5220 Espresso Machine & Coffee...
Pump may be broke
Remove the frother nozzle: if its the early type with three hooks, slide the frother body down before trying to remove it. Disassemble the frother and clean the three holes in the end. If the holes are blocked, the steam can't escape. If it's not pushing hot water through the coffee holder, pull out the water reservoir, and remove and clean the grid plate assembly where the coffee holder clips in.
The coffee oozes out the top of the ground coffee holder as pressure builds up and does not run out through the coffee. Please advise Lara
Lara,
You need to check the brew head, its above the filter holder. I would imagine that it is blocked with scale, when did you last descale it?
Nov 03, 2010 | Krups XP4030 Espresso Machine
I have krups xp 5220 and it doesn't make foam. There is just black caffe. please help me. thank you :)
Three things to try:
1. Try a finer ground coffee
2. Use fresh coffee not old coffee
3. Make sure the coffee is pressed down well in the filter holder
For the machine, make sure it has been descaled correctly.
Hope that helps.
Nov 03, 2010 | Krups XP5220 Espresso Coffee Maker
Krups XP5220 Espresso Machine & Coffee Maker Logo
407 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
