Question about Sirius Stiletto 2 Satellite Radio Receiver
My Sirius Stiletto 2 won't power up - Sirius Stiletto 2 Satellite Radio Receiver
5 Suggested Answers
SOURCE: white square on sirius stiletto 2
I ran the stiletto device recovery program and it works again. You can find it on the Sirius website by searching for "stiletto device recovery". However, it does delete all of the content that you have saved on the stiletto.
Posted on Jul 31, 2009
SOURCE: usb connection on sirius stiletto 2 to pc
You must be sure to have satellite radio turned off in order to connect to the pc. If you are using a home dock, first make sure satellite is off and then push the "Sync" button on the front of the home dock.
Posted on Jun 03, 2008
SOURCE: Sirius Stiletto 2 Problem
That's one of several problems my Stiletto 2 has. The only solution I've found is to "reboot" the unit. You'll have to remove the unit from the cradle, pop the back off, and remove the battery for a few seconds. Then put everything back together and power it up. It will take a minute or two, but once it reboots it should be fine.
Posted on Aug 19, 2008
SOURCE: Sirius Satellite Stiletto 2
My Stiletto got the same problem at around the same time. I have been reading many stiletto owners problems and see many of the same problems erupting at around the same time-mid to late February. I just spoke with a Sirius Representative who said the Stiletto 2 has been discontinued. Seems like a conspiracy to me.
Posted on Mar 27, 2010
I'm considering purchasing a Sirius Stiletto 2 Satellite Radio Receiver - just wondering if it can it be connected to my new Harmon Kardon 3600 avr or do I need to buy the Sirius connect SCH1 Home...
You will need to use the aux input from the top of the unit, or from the back of your home dock. If your receiver has a built in or add-on dock for the XM2GO line of radios, you will need to read here: http://www.digitalradiocentral.com/sirius-backstage/stiletto/108379-i-converted-xm2go-dock-stiletto.html
Jan 08, 2011 | Sirius Stiletto 2 Satellite Radio Receiver
Feb 25, 2010 | Sirius Stiletto 2 Portable Satellite Radio...
Sirius Stiletto 100 - can't record as of Jan 1 2010
Hard boot fixed it... (removed battery, put it back in... shoulda tried that a long time ago...)
Jan 05, 2010 | Sirius Stiletto 2 Portable Satellite Radio...
Can I use a stiletto 2 home kit for my Stiletto 1 receiver?
no sorry it wont the stiletto 1 it deeper than the stiletto 2.
Dec 04, 2008 | Sirius Home Kit for SIRIUS Stiletto 2...
Stiletto2 sometimes has static while playing mp3's from exp. card
I also own a Stiletto 2 and I have noticed this same problem, but only when playing MP3's in my car. What I have found is that if the volume on the Stilletto is too high it creates distortion. The solution is to turn down the volume on the actual Stilletto and just use the volume on the car stereo. Problem solved everytime.
Nov 21, 2008 | Sirius STILETTO 100 MP3 Player
Aug 15, 2008 | Sirius Audio Players & Recorders
I'm recieving a strong signal on my stiletto 2 but no sound on the radio. The MP3 player works with headphones and so does internet radio.
You need the firmware upgrade from the Sirius website:
Bug Fixes
· Reduced incidence of “acquiring signal” and “antenna not detected” messages
while the radio is installed in the Stiletto Vehicle dock (SLV2)
· Improved audio quality and distortion reduction
· Reduced incidence of long block recording and Radio Replay corruption
How to Get this Release
Updating over WiFi:
Subscribers may update Stiletto 2 over WiFi by following these steps:
1. Power cycle the Stiletto 2 by holding the power/lock switch down for 5 seconds
and releasing.
2. Turn on the Stiletto 2 and press the HOME button
3. Use the MEDIA DIAL to scroll to Internet Radio
4. Press the SELECT button to connect to Internet Radio
5. Tune to your favorite station and let it play for several hours.
6. Follow prompts on screen to complete the update, then power cycle your radio to
apply the updates.
7. Next go to HomeSettingsDeviceDevice info, if the baseband version is
already 00.14.94 you are done. If not, continue to the next step.
8. Reconnect to Internet Radio and listen for at least 15 minutes.
9. Disconnect, and tune to Satellite Radio. Updating Sirius will be displayed for
approximately 5 minutes.
10. Once the message clears, your update should be complete. Go to the Device
Info screen to verify the update has been successful.
Updating using My Sirius Studio™:
Customers without WiFi access may update using My Sirius Studio™ running on a PC
with an active internet connection:
1. Launch My Sirius Studio™ on your computer. Be sure you are running the latest
version of My Sirius Studio, currently version 1.5.1.
2. Power cycle the Stiletto 2 by holding the power/lock switch down for 5 seconds
and releasing.
3. Turn on the Stiletto 2 and connect it to your computer using the USB cable
supplied with your device
4. In My Sirius Studio, click on the gear icon next to the device or go to File
Device Settings Check for Software Update.
5. Follow the instructions that appear in My Sirius Studio™ to complete the update.
Please Note: During the update, your media library must be re-built. If you have a
large amount of content stored or a microSD™ card installed, the process can last
for as long as 10 minutes. During this time the message “updating media library” or
may be displayed.
6. After disconnecting from your PC it will be necessary to power cycle your Stiletto
and connect to Satellite Radio to refresh your channel list.
For additional questions regarding your Stiletto 2 or the SIRIUS service, please refer to
the product manuals. You can also reach the dedicated Stiletto Technical Support Team
at 1-800-869-5364 from 10 AM to 10 PM Eastern Time Monday through Saturday, or by
email at customercare@sirius-radio.com.
Jul 06, 2008 | Audio Players & Recorders
White square on sirius stiletto 2
Feb 02, 2008 | Sirius Stiletto 2 Satellite Radio Receiver
Stiletto constantly powering off
Solution is downloading the sirius recovery software from sirius.com My radio would not connect to my computer because it would not fully turn on. disconnect the battery. Hold the DISPLAY and OPTIONS button on the radio face when reconnecting battery. Connect to PC and Sirius Recovery Program will pop up. Run program, takes approx 10 to 15 min and radio works good as new.
RUNNING PROGRAM WILL ERASE YOUR LIBRARY ON YOUR RADIO....
Dec 26, 2007 | Sirius STILETTO 100 MP3 Player
Sirius Stiletto 2 Satellite Radio Receiver Logo
395 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Steve
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
