Front speakers making screaching noise. just the left and right front speakers making the sound
Usually a sign of blown speakers. Using high volumes over long periods can damage the speakers, or part of the microchip amplifier. It may be worth checking all the connections are clean and sound first though
Posted on Jan 03, 2011
2000 Subaru Impreza Sedan; Couple different noises
the screaching noise is 1 of your belts needs to be tightened. noise from the right front tire sounds like a bad sturt or ball joint and that needs to looked at
Jan 07, 2013 | 2000 Subaru Impreza
Making a screaching noise very hard to turn,i checked the power steering fluid there was hardly any in there so i filled it up took it for a run still making a slight screaching noise and still very hard...
make sure the reservoir is full then turn the wheel hard right then hard left a few times,should clear any trapped air in system....otherwise check pump for leaks.....
Sep 18, 2010 | 2001 Hyundai Accent
I have a Sanyo DCTS760 surround system. A couple of weeks ago i got a loud static noise coming from the front left speaker. I tapped gently but forcefully on the top of the reciever cabinet and this ,...
if the left front channel is not working, first test the speaker with the right channel that is working to make sure the speaker is still good.
If the speaker is good, then it means the fuse of the left channel has burnt. Open the receiver and check the left channel fuse.
Good luck.
Jul 21, 2010 | Sanyo Televison & Video
What are the defects of the 4wheel drive?
gdi engines are prone to this idling problem, you can try dissconecting the battery and reconnect after a few minutes and see if the ecu rectafies it or try petrol additive
Apr 24, 2010 | 1999 Mitsubishi Galant
My whirlpool gas dryer makes a screaching noise turns off
your drum glides/rollers are defective on the front edge of dryer where the drum rests,sounds most like the glides are glazed,not roller bearings but check it could be either
Nov 02, 2009 | Whirlpool LGR5636L Gas Dryer
Need blower wheel replaCDED?
If it was your blower wheel it would not make that noise first cheak and see if thewheel has play on the shaft if so then it will need to be replace second turn blower wheel by hand back and forht if there is a screaching sounds if is a dry bearing on the motor .If so if you can live with the sound it will not go right away if not remove motor and replace.If there is play on the wheel you will need clip pliers and normal pliers and remove both clip[ on shaft and clip on shaft revers after install new blower wheel good luck:)
May 07, 2009 | Maytag PYE2300AY Electric Dryer
Sub woofer making a screaching loud noise when powered on
The pop from other electrical items makes me think it's a ground problem but I am do not have a clue as to what type of setup you are running over there. Did you try a surge protector?Is it 110volts with a seperate ground wire?
Have you tried running a UPS?
Sep 26, 2008 | Logitech X-230 Computer Speakers
1986 Toyota pickup stereo wiring COLOR CODES NEEDED
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Purple
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: 5 1/4′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Sep 01, 2008 | 1986 Toyota Pickup 4WD
No Sound Right Front Speaker
Sounds (forgive the pun) like that channel's power chip is gone. Take it to a Tech, I may advise...
Mar 29, 2017 | Audio Players & Recorders
 Grubhead
Grubhead
