Question about Canon PIXMA MX850 Multifunction Printer
My printer is fine when i am printing from my computer, but when i make a copy, there is a line down the page
  • 731 Answers
Be sure the glass is clean.
If the Canon is anything like HP and you are using the ADF there is a thin strip of glass on the left end of the flatbed. This is where scans are read when using the ADF (Automatic Document Feeder)
All it takes is a tiny speck on the glass to cause lines on the copy. Clean it by spraying a glass cleaner on a soft towel and wiping
Posted on Jan 03, 2011
Printer only prints top and bottom lines on page
All web based documents, especially bank statements, require a COLOUR cartridge, so if your cartridge is empty, it will print blank pages. Although the font may look black... it is normally NOT. Altentaively you may also need to instruct your printer to print "background images".
Jul 08, 2012 | HP Deskjet D1000 J110a Printer Catalog...
Black line on copy and fax functions
Clean the paper path for the scan/fax portion. The original goes in and as the document is "read" a spot of dirt is causing the black line down the page because it is picked up in the copy area.
Dec 16, 2011 | Dell 948 All-In-One InkJet Printer
My printer is not printing all the horizontal lines
First try to copy and if copy works fine, means the hardware is fine and issue with the driver.
Do right-click on printer icon and select delete.
Once deleted, run the installation disc and click on add a device, follow onscreen instructions to complete the installation. Open printers and faxes window and then do right click on printer icon and select properties, click on print test page.
Check if it prints fine, if yes try to print from other application. I hope it will work.
May 26, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
I have a black line down copied pages. Printed pages look fine. Problem is only on copies.
Clean the **** glass on the left side where u put the copies on the glass!Good Luck!
Apr 08, 2010 | Samsung SCX-4725FN All-In-One Laser...
Copy issue with a line from top to bottom
if printing is fine and copying causes line on page, I suspect that there is dirt on the scanner glass. Clean scanner glass.
Apr 01, 2010 | HP LaserJet 3050 All-In-One Printer
Prints fine but when I make a copy i get a 1inch line down the right side of the copy.
hi,
before printing, click file then click page setup and check the margin.
best regards,
kaybicks
Feb 23, 2010 | Lexmark X6570 InkJet Printer
Whenever I scan a picture or document I get a line going down the middle of the page. When I print the same document the line prints down the page. THIS only happens on the scan not when I print from the...
first of all try to make a copy..when you make a copy if you get lines..then clean the scanner glass and the rollers..if its still the same..connect the printer directlu to the wall outlet and then check
Mar 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
I have a thin line all the way down the page when making a copy.
Check scanner glass and clean. Further test - Scan from the computer. If the line is still present, the scanner CCD is failing and requires service as there is no user servicable part inside.
Nov 21, 2008 | HP LaserJet 3050 All-In-One Printer
Thick Black Line on my copies and faxes
Can't image it being anything but scan glass, if prints are fine, are you sure you cleaning scan glass(inside of where originals are fed)?
If so then scanner lamp faulty, but I've never come across it myself on this model.
Oct 26, 2007 | Brother MFC 8500 All-In-One Laser Printer
Canon PIXMA MX850 Multifunction Printer Logo
145 people viewed this question
old marine
old marine
