Question about Blitzz Technology BWA711 (B3WL000900) Wireless Router
Trying to do a firmware upgrade bwa711 wireless
Slow wireless connection
I think you can try to upgrade the firmware on the router.
Connect one compute to the router and download the firmware of the router.
Open the setup page and upgrade the firmware.
See How to upgrade firmware on the router
After upgrading the firmware reset the router and reconfigure it manually.
See if that helps you.
Watch video: How to reset linksys router
Feb 12, 2012 | Linksys WRT300N Wireless Router
Firmware upgrade was interrupted & now I can't connect to it. I have reset it 3 times & still nothing
TRY
Upgrading the router's firmware will give it numerous functions. This includes a more stable connection to the internet.
To upgrade the router's firmware, complete the following steps:
i. Downloading the Firmware
ii. Backing-Up the Router's Settings
iii. Upgrading the Router's Firmware
iv. Completing the Firmware Upgrade
v. Restoring the Router's Settings
vi. Completing the Firmware Upgrade Process
NOTE: Before proceeding with the upgrade, your computer must have an active Internet connection. It is also recommended that you use a wired computer in upgrading the router's firmware.
Sep 10, 2010 | Linksys Wireless-G WRT54G Router
Belkin n150 F6D4230 wireless router. lose ability to
try to upgrade the firmware of the router. that will help you.
For this you will need to connect the computer to the router. Do not upgrade the firmware of the router using the wireless computer.
You will need to download the new firmware from the manufacturer's web site. Then open the router set up page and upgrade the firmware of the router.
Click here for more information about routers and network
Jan 14, 2010 | Belkin Computers & Internet
I'm trying to upgrade the firmware on a belkin wireless router
upgrade of Firmware is at your risk...
never upgrade Firmwares....they are not ment for that....
your hardware may be rendered useless after firmware upgrades....the chip inside your hardware is programed to run based on a certian program installed as a firmware from the factory....sometimes upgrades will screwup your hardware....so be careful and do it at your own risk...
Dec 10, 2009 | Belkin (F5D7230-4) Router (587009)
Connection on again off again in 3 second
Hey ! it seems that there is a problem with the Firmware of the router.
The wireless connection is dropping.
You can try to upgrade the firmware.
Download the firmware from the support web site of the router manufacturer. and upgrade the firmware.
make sure that you will upgrade the firmware using the wired connection to the router NOT with the wireless connection.
Click Here for more info about the networking
Oct 07, 2009 | Linksys Wireless-G WRT54G Router
Getting Blitzz BWA 711 wireless router configured in my computer
Hi I need the router settings for BWA711 do you know what it is . Thank you, Linda
tnlmyers@comcast.net
Dec 24, 2008 | Blitzz Technology BWA711 (B3WL000900)...
NetGear RangeMax WPN824 Wireless Router (WPN824NAR) Wireless connection drops in and out regularly but frequency of this is unpredictable duration is usually a few seconds. Works find on direct ethernet...
Upgrade the Firmware of the router :
First you should check the version of you WPN824 (v1,v2 or v3). If there are no Version after the model number, it should be a version 1. Download the Firmware of your router given the correct version at this link :
http://kbserver.netgear.com/products/WPN824.asp
This is assuming that other wireless laptops has the same problem onyour wireless router. If other Laptops works great on your wirelessrouter without dropping any wireless connection, then you shouldconsider upgrading the wireless adapter on you own laptop.
***(If you haven't tried connecting otherwireless laptop wirelessly to the netgear, then you should try it firstto be sure that the netgear is the problem)
Steps on how to upgrade Netgear firmware :
  1. Download the correct file depending on your location and unzip the file to a convenient place such as your desktop.
  2. Log in the router at http://192.168.1.1 or http://192.168.0.1 (or www.routerlogin.net ) (Which ever will work)
  3. Default User name : admin / password : password
  4. Click Maintenance > Router Upgrade.
  5. Click Browse and locate the file you just downloaded.
  6. Click Upload. While the firmware is loading, do not interrupt the upgrade process.
***Therouter reboots when the upgrade is complete.
***Tocheck that the upgrade was successful, log in to the router again at http://192.168.1.1and check the firmware version.
***DONOT UPGRADE FIRMWARE USING A WIRELESS LAPTOP/PC
Oct 26, 2008 | Computers & Internet
Blitzz super g 108 model bwa711
So I try search with factory thw your wireless new driver for windows vista. Issues you have only 54 g because pc´s has wireless not same 108 super g.
Good luck.
Mar 22, 2008 | Blitzz Technology BWA711 (B3WL000900)...
Blitzz BWA711 connecting with game consoles
wel becouse the modem is older than the new ones and the conection would no longer be recieving upgrades,even if you conected the ps3 or your xbox you would not have a strong enough conection to be able to play online peacefully i recomend u get braodband wit 3-7 meg connection and then u should have no problem conecting either console to your router/modem
Mar 08, 2008 | Blitzz Technology BWA711 (B3WL000900)...
Blitzz Technology BWA711 (B3WL000900) Wireless Router Logo
Top Blitzz Technology Computers & Internet Experts
Michael Galve
Michael Galve
fred capra
fred capra
Are you a Blitzz Technology Computer and Internet Expert? Answer questions, earn points and help others
