Question about Food Mixers
We have a hansa canyon tap when we installed it everything seems ok but then we get a red flashing light and it turns off... help pls?
Have you solved this issue yet? I have the same problem with my basin and bath tap. Its driving me nuts trying to fix it!!!
Posted on Jan 23, 2011
  • jsaonline Apr 18, 2011
    Any joy fixing your tap yet?
Planetary Plummets!
go buy a bottle of lock tight also called thread locker (red bottle) and apply some then press it in place while still wet , let dry and it should stay on
Mar 20, 2017 | KitchenAid KP2671 Professional 6 Series...
Sparking at brushes
This isn't abnormal although cleaning the armature with fine emery or sandpaper can help.BTW, new brushes will always need a period of run-in before their contact with the armature has reached its best.
Nov 27, 2011 | Food Mixers
It is not working completely. all fuses and door switches are well pls help
check the power cord possible damage and the motor resistance if ok. also the pcb board
Mar 06, 2011 | Kenwood KM800 Major Classic Stand Mixer
No power after replacing worm gear in Kitchenaid KSM90 Mixer
Remove the rear cap from the unit. Power comes in from the black wire with the white being common. Hold a voltmeter lead on the white and check for power on the black. Power goes across the bottom of the speed control unit via a buss bar. Check for power on the right side, I think it is a red wire (may be a white one). Power is taken into the motor via that wire, goes thru the windings and the brushes and then out the other brush wire and back to the board. Check for power on the return wire. If it is dead then either the windings in the motor are burned out or one of the brushes is dirty and needs to be cleaned and reseated prpperly [note there is one and only one way the brush goes in!!!! Install it incorrectly and the brush will not touch the commutator.
Try that and see if it runs after cleaning the brushes.
Mar 31, 2010 | KitchenAid Food Mixers
My kitchen aid Artisan mixer doesn't seem to wanna work unless i toggle the switch back and forth from 1 to 10. If i wait long enough it goes on for about 10 seconds eventually if i go to the higher...
could be brushes, but if the machine keeps turning on and off you could be building up carbon burns on motor so be careful ok
estimate cost $29-$39.99 3-4day repair
Nov 21, 2009 | Food Mixers
Took brushes out to check and cannot get kitchenaid mixer to work.
Look at the brush from the side.. The surface that rides on the armature is curved> One leg is longer than the other leg. The long leg is the trailing and the short is the leading edge. Looking at the cooper end of the motor you can tell which way the motor rotates by the traces the brushes make. The leading edge will be on the clean side and the trailing edge is the side that is smeared black.on tthe copper. The long leg of the curve on each brush goes on the smearch side of those copper bars the brush rides on. Both brushes. Looking in the hole of the brush holders you will see what I mean. When you put the brushes in, you must make sure they are up against the copper and the springs are holding them down evenly.. You can lift the brush carefully and let it go to make sure it is working freely. Now, see if you can put an attachment on and turn it by hand. I'm not sure you will be able to so don't bend anything or hurt yourself.. Put the brush caps back on, remove the attachment and plug the mixer in.. Attachments off, fingers clear, turn it on. Does it run? If not, tap the mixer on its side with your hand.. Make sure the switch is on high. Tap it several times if need be. This is to straighten up the brushes to where the springs want them. When the motor starts turning, slight taps help. Keep it going until it picks up speed and let run for five minutes to seat the brushes. Let me know if it still won't run. I'll be watching for a comment from you.
Oct 26, 2009 | KitchenAid KSM150PS Artisan Series Stand...
How to fit POLO PULLOUT SPRAY KITCHEN SINK MIXER TAP 0119 **NDD**
hi i need to fix a pull out sink mixer...but i have no idea how to fix.pls help.thanks
Oct 05, 2009 | Food Mixers
Blade won't release from mixer
Try to push up while you turn the blade. Don't be afraiid to turn hard.
Dec 30, 2008 | KitchenAid K5SS Heavy Duty Commercial...
Silver ring off and can get it back on
It holds on by friction alone. There is no screw or anything. It should just push on maybe with a few light taps around the ring with a hammer.
Apr 08, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Mixer attachment
make sure attachment is turned full counter clockwise to release point give a good tug if doesnt work try a light tapping with a rubber hammer or lobster wooden hammer
Nov 20, 2007 | KitchenAid KSM150PS Artisan Series Stand...
Food Mixers Logo
138 people viewed this question
Top Food Mixers Experts
eyecam
Are you a Food Mixer Expert? Answer questions, earn points and help others
