Question about Sanyo Vacuums
I need the circuit diagram with complete details of sanyo duel tube rechargable emergency light in witch 6 volt battery and 1 foot tube rods are used
  • Bio Hazard Jan 07, 2012
    i also need the same circuit diagram please. Cause i am working on modification.
I nee the ckt diagram
Posted on Dec 19, 2011
  • neelanand55 Dec 19, 2011
    pls sent me ckt diagram. Thankyou
Northwest queen air mattress
You can always make a plug. Get a piece of clear vinyl tubing about 1 inch long. The inner diameter of the tube should be the same size or just a bit wider then the width of the mattress plug your missing. Get a small tube of clear silicone rubber (make sure its pure silicone rubber) and completely fill the vinyl tube. Let it sit for 4 or 5 days to completely dry. Cut off the vinyl and your new plug emerges! Use your scissors to cut the tip at an angle so its easier to get it into the mattress tube.
Mar 24, 2015 | Vacuums
Brand new first charge The green light on the charger plug goes off after a short time. Is the unit still charging?
Once the green light goes off, it's done charging. Since it was first charge I know they say to charge it 8? hours (or 4? don't recall right offhand) but it does come charged (that's part of how they make the batteries). What you do want to do is remember not to always recharge it when your done using it. Use it till the battery goes flat, then recharge it; it will give you a longer battery life that way.
Jan 09, 2015 | Dyson DC34 Bagless Cordless Hand Vac -...
Need a wiring diagram to change batteries on an electolux zb2904X vacuum
Batteries are not usually replacement items in most rechargeables. Typically the batteries, if available, cost as much as the whole machine. These are intended to be disposable.
Jan 08, 2015 | Vacuums
How do you know when the battery is charge
Hi there, it's Jack at Dyson.
If your machine's charge has been completely depleted, it will take a maximum of 3.5 hours to recharge again completely. When it's fully charged, the light on the charger will go out. You can either plug the charger cord directly into the machine, or store and recharge the machine in its docking station.
I hope this helps, but if you'd like any further information you're welcome to contact us directly. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 29, 2014 | Dyson DC35 Handheld Vacuum
Hoover linx
How old is your battery? and did you keep it on charge when it was not in use?
Most rechargeable batteries require a spindown, where as you completely discharge the battery before recharging it again.
I know you aren't wanting to hear this but in all probability that battery is spent and will need to be reconditioned at a battery place, however, it will cost almost as much as a new one it would be your call.
if you have a ohm/volt meter it might be possible to look at the charger and get a volt/amp reading and then test it see if it is putting out the proper voltage it could be putting out a trickle charge and it would take forever to charge it.
there is one other situation to look at and if the beater brush or motor is causing a resistance it will pull a battery down quick.
I do not own this vaccum so I can only guess as to the possibilities.
Jul 02, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
I get a blinking yellow light when recharging my IRobot Roomba 550. What's wrong?
I am afraid you are having the problem of old or weak batteries. Old batteries at times tend to show such problems and do not show charge while charging properly. For this purpose, you can use a reliable Nicad Battery Repair Guide through which you can recharge the batteries without any problem and make them work like the new ones within no time, without anyone's help and you can do this all by sitting at home! I tried it and now I never buy new nicad batteries (http://www.nicadbatteryrepair.com/).
Jan 03, 2011 | iRobot Roomba 550 Vacuum
When to recharge batter
hi right to be honest both ways are correct, but if your using it every day then its best to put it back on the charger after every use, but the problem with this is that the battery never goes totally flat, so never does a full recharge this reduces the life of the battery by upto 50% so if you are using it regular and need it charged daily then its best to once a month let the battery go totally flat so that it wont even make a sound then do a full recharge.
Doing this will ensure the battery remains at peak performance and make it last longer.
If how ever your only using it say once a week then its best to only charge after the battery has gone flat due to the fact that it would remain on charge longer and cause the battery to over heat reducing the life span of the battery.
But witch ever method you use always let the battery go totally flat once a month then do full recharge this will prolong the life of the battery and ensure it keeps working at full power.
Let me know if you have further questions ok
Jan 18, 2010 | Euro-Pro Shark Cordless Stick Vacuum...
My dc 16 rechargeable vacuum won't work
far as i know the dyson dc 16 root 6 vacuum uses a lithium ion battery with a charge of 21.6 volts. it could be that either your battery isnt storing the right amount of power anymore and you may need to replace it. check on the specifications to confirm how much volts the battery is supposed to have. too little volts may be enough for things like lights to switch on, but not enough for the motor to start up.
Oct 27, 2009 | Vacuums
Vacuums Logo
451 people viewed this question
Top Sanyo Vacuums Experts
Gerry Harvey
Gerry Harvey
ray gallant
Roy May
Are you a Sanyo Vacuum Expert? Answer questions, earn points and help others
