Question about HP Laserjet M1319F Laser Multifunction Printer
We understand that your problem is: When scanning with HP laserjet m1319f, using Hp Scan to software or adobe the mfp lcd reads scanning to pc, the paper feeds through, but after that everything just hangs. The scanning to preview dialog box shows busy, but it doesn't go further than that. When I hit the cancel button in that box, i get a "unable to communicate with scanner" error, or something like that. Then, the only way to reset the printer is by powering off/on. I uninstalled and reinstalled the hp full solution driver (latest version) and firmware is up to date..
    Master:
  • 412 Answers
I've had similar problems with more than one HP MF machine over time. Software is lousy, even when it's working, and these kinds of intermittent problems are familiar to me. Suggest Canon or Epson when you decide to replace it. I will never buy another HP printer.
Posted on Apr 22, 2017
SOURCE: HP Officejet 6310 scans once but then says scanner failure
hi,
that error message is nothing to do with the software part, it actaully hardware issue try the following,
1) unplug the machine and connect it to wall outlet directly,
2) unplug the power cord from the printer and press and hold ON for 1 min and release the ON button and plug it back..
3) Disconnect the power cord from the product.Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons and if printer turns off, turn it back ON and wait until it cmopletes its instialization and if still persists, it a hardware failure...............
regards,  raj_p5983
Posted on Jan 22, 2009
  • 102 Answers
SOURCE: how to intalling network sanner HP LaserJet M1522nf MFP
If your printer is connected in the Network and you are able to print fine than there is no communication Error.
In htan case if you are not able to scan then you need to upgrade the firmware of the printer and install it and i m sure your printer wiill scan scanning on the Network.
Mentioned below is the link to download the latest firmware of the printer.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3442750&prodNameId=3442754&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-70811-2
However before you start sending firmware to the printer you need to make sure that printer driver is installed on the PC.
Thanks and Regards
Neeraj Sharma
Posted on Jul 01, 2009
SOURCE: HP laserjet M1319f MFP "no fax detected" error
I had the same problem and just solved it by going into Setup - then Fax Setup - then All Faxes - Then Speed - and lowering the speed from fast to medium. Sure it's a couple seconds slower, but it finally works!!!
Posted on Jul 24, 2009
Evildice
  • 222 Answers
SOURCE: HP Laserjet M1319f MFP - scanner not responding
check paper sensor, maybe he cant move
Posted on Sep 28, 2009
  • 38 Answers
SOURCE: I have an HP Laserjet M1319f MFP printer, when I
You can set the density lighter or put the printer in economode. You may not like the print quality as it will be extremely light. But the toner will last longer.
Save toner
1.
On the File menu in the software program, click Print.
2. Select the driver, and then click Properties or Preferences.
3. On the Paper/Quality tab, click EconoMode.
4. Click OK.
Posted on Nov 05, 2009
Testimonial: "THANX!! BIG HELP, so simple."
I have hp laserjet 500 MFP m525,there is no display in the panel.still can able to print from pc but cannot make photocopy,scan.
Panel LCD cable might be damaged or opened.Check the cable after disassembling the panel Side carefully.
Jul 31, 2014 | HP Office Equipment & Supplies
Unable to scan on laserjet m1132 MFP
Hello you have to open the HP LaserJet Scan.
In the HP program group, select Scan to start HP LaserJet Scan
Select a scanning destination
Click Scan.
Here is a user manual in more details:
http://images10.newegg.com/User-Manual/User_Manual_28-115-668.pdf
You need adobe reader to read the content.
Good luck
Dec 31, 2012 | HP LASERJET PRO M1132 MFP
How do i scan images using the hp 4730 mfp
check under general reference (link below). it should mention how to fax, e:mail and copy. if you copy to file / pc that should work as the scanner.
otherwise make sure the "scanner" facility is installed as some MFP's do not come with all facilities installed. (and therefore may not give the option on the screen.)
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&prodClassId=-1&contentType=SupportManual&prodTypeId=18972&prodSeriesId=468688
Jul 21, 2010 | HP LaserJet 4730 MFP Printer
HOW TO SCAN FROM SCAN TO BUTTON IN THE NETWORK FROM HP 2727MFP
You need to install the HP Scan software on each and every PC the MFP should scan to. In this software, you can create targets for the "Scan To" button. But: This is only useful when scanning with the ADF, because when scanning from the flatbed, you'd need for every page to hit the "Scan To"-button, press "Scan", wait for about a minute or two until the MFP has found the appropriate PC, and wait for the scan. So network scanning is unfortunately very limited with this machine.
Mar 12, 2009 | HP Laserjet M2727nf Multifunction Printer
HP Color LaserJet CM1017 MFP - won't scan
Please try installing software components for your MFP device.
Feb 12, 2009 | HP LaserJet CM1017 MFP All-In-One Color...
Hp laserjet m1319 mfp series
Are you using the software that shipped with the machine? I use the" HP Scan To" program which allows me to scan it to a slew of file types.
The only downer: I can't put the software on more than 1 computer. Apparently, it recognizes that the printer is hooked up to another machine and won't let me install any drivers on other computers (except the print driver).
Sep 25, 2008 | HP Laserjet M1319F Laser Multifunction...
HP Laserjet M1319F Laser Multifunction Printer Logo
76 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
